I am trying to put to work a radio with a **Multi-AP STA interface** (EasyMesh l…ink), the connectivity at Layer 1/2 seems to work well but at least **IP traffic is not being forwarded to/from the Multi-AP WDS link**. The UCI configuration is:
wireless.bh_sta=wifi-iface
wireless.bh_sta.device='radio1'
wireless.bh_sta.mode='sta'
wireless.bh_sta.network='lan'
wireless.bh_sta.ssid='SMBackhaulSSID_54:af:97:c5:c0:8d'
wireless.bh_sta.key='tFKUEAtQ4zwV3uk6'
wireless.bh_sta.macaddr='2c:11:52:4f:41:04'
wireless.bh_sta.encryption='psk2+ccmp'
wireless.bh_sta.multi_ap='1'
wireless.bh_sta.wps_pushbutton='1'
wireless.bh_sta.ifname='sta0'
The MAC address should be overrided because the default value was "00:00:00:00:00:00" and that leads to a failure. As I said, **with wpa_cli all seems to work well and also the bridge shows the interface**:
<3>Trying to associate with 60:a4:b7:7c:6c:8f (SSID='SMBackhaulSSID_54:af:97:c5:c0:8d' freq=5260 MHz)
<3>Associated with 60:a4:b7:7c:6c:8f
<3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
<3>WPA: Key negotiation completed with 60:a4:b7:7c:6c:8f [PTK=CCMP GTK=CCMP]
<3>CTRL-EVENT-CONNECTED - Connection to 60:a4:b7:7c:6c:8f completed [id=0 id_str=]
root@OpenWrt:~# brctl show
bridge name bridge id STP enabled interfaces
br-lan 7fff.d4772b555557 no lan1
lan2
lan3
p-1905
sta0
wan
In LUCI:
But a ping to the IP of the device working as a WDS AP fails (and also, any kind of traffic expected to go through that link):
root@OpenWrt:~# ping -I sta0 192.168.0.44
PING 192.168.0.44 (192.168.0.44): 56 data bytes
^C
--- 192.168.0.44 ping statistics ---
5 packets transmitted, 0 packets received, 100% packet loss
With a tcpdump in the client interface (sta0) and br-lan, **we can see ARP requests from the device which runs the Multi-AP WDS AP (192.168.0.44), but no response**:
root@OpenWrt:~# tcpdump -vvv -i sta0 | grep 192.168.0.44
tcpdump: listening on sta0, link-type EN10MB (Ethernet), capture size 262144 bytes
09:19:36.413026 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:37.452643 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:38.492548 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:39.533129 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:40.573055 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:41.613377 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:42.653261 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:43.692417 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:44.732137 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:47.904990 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:48.972169 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:50.013555 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:51.862394 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:52.892419 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:53.932962 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:19:56.222445 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
^C264 packets captured
266 packets received by filter
0 packets dropped by kernel
root@OpenWrt:~# ^C
root@OpenWrt:~# tcpdump -vvv -i br-lan | grep 192.168.0.44
tcpdump: listening on br-lan, link-type EN10MB (Ethernet), capture size 262144 bytes
09:20:02.492561 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:03.532611 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:04.579466 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:05.612608 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:06.651959 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:07.692552 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:08.732910 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:09.773520 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:10.812390 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:11.852520 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:12.892041 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
09:20:13.932065 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.0.1 tell 192.168.0.44, length 28
^C216 packets captured
229 packets received by filter
This shows that t**he inbound traffic is being received but the system is unable to forward it properly**. Also the outbound traffic won't go out for the same reason, the system can't forward properly to the WDS link to send it out.
**Regarding the monitor mode,** simply there is no capability using an **iw list** command. **There is only "managed" and "AP"** modes.
Wiphy phy0
wiphy index: 0
max # scan SSIDs: 8
max scan IEs length: 1000 bytes
max # sched scan SSIDs: 0
max # match sets: 0
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Available Antennas: TX 0 RX 0
Supported interface modes:
* managed
* AP
And also by creating one interface in monitor mode does not work.
**Am I doing something wrong? There will be support for MultiAP links? And what about monitor mode?**
Thanks in advance.
Pablo.
