Banana Pi BPI-Wifi6 router board with Triductor TR6560 + TR5220 wifi SOC , support OpenWRT ,we also design it support PoE function
Banana Pi BPI-Wifi6 Router design with Triductor TR6560 + TR5220 wifi SOC, it is a standard wifi6 router solution. Built-in high-performance dual-core ARM Cortec A9 processor for WIFI message forwarding or intelligent business processing, built-in high-performance LSW and hardware NAT, supporting up to 5Gbps message forwarding,Integrated 5GE PHY, one RGMII,Supports one RGMII expansion port, provides 1000Mbps network access capability, and supports two WAN ports. Support hardware intelligent QoS. Support dual-band 2.4G 40M 2*2 +5G160M2.2 DBDC WIFI,Wifi protocol version support to IEEE 802.11ax, backward compatible 802.11a /b/g/n/ac, can support the highest rate of 3Gbps, 2G will reach 573.5Mbps, while 5G will reach 2401.9Mbps, support PoE interface ,add PoE module to support PoE function.
Key Features:
- Dual core ARM cortec A9 1.2G Hz
- Integrated 5GE PHY, one RGMII
- Supports 6 GE MACs,1000M/100M/10M rate mode and standard MIB statistics
- Supports IEEE802.11a/b/g/n/ac/ax wireless LAN communication protocol
- Support Wifi AP mode and STA mode
- Support WPA,WPA2, WPA3 encryption and decryption, pay Chinese WAPI standard
Why did Banana Pi community develop this product:
wifi6 has been widely popularized in the market, and the telecom operators have large-scale applications. The current router is provided as a finished product, and users cannot add their own special applications on it. The wifi6 board developed by Banana Pi community. In close cooperation with chip manufacturers, apart from the industry and telecom carrier market, we adopt a relatively open source approach and open complete code, so that users can do a variety of self-defined applications on the router. Promote the development of the Internet of Things market
Hardware interface:
PS: we also to do a case for this board , So it can also be sold as a standard wifi6 router
online wiki documents , we will keep update:
https://wiki.banana-pi.org/Banana_Pi_BPI-Wifi6_Router
source code on github:
