Banana Pi BPI-Wifi6 Mini public sale.
Banana Pi BPI-Wifi6 Mini Open source Router design with Triductor TR6560 + TR5220 wifi SOC, it is a mini size wifi6 router solution. Built-in high-performance dual-core ARM Cortec A9 processor for WIFI message forwarding or intelligent business processing, built-in high-performance LSW and hardware NAT, supporting up to 5Gbps message forwarding,Integrated 5GE PHY, provides 1000Mbps network access capability, and supports two WAN ports. Support hardware intelligent QoS. Support dual-band 2.4G 40M 22 +5G160M2.2 DBDC WIFI,Wifi protocol version support to IEEE 802.11ax, backward compatible 802.11a /b/g/n/ac, can support the highest rate of 3Gbps, 2G will reach 573.5Mbps, while 5G will reach 2401.9Mbp
BPI-Wifi6 mini support 4g/5G module ,you can add 4G/5G module let it support 4G/5G function.
sinoVoip aliexpress ship: https://www.aliexpress.com/item/1005007316957256.html?spm=5261.promotion_single_products.table.1.3bfb15d1tQ4Prf&gatewayAdapt=4itemAdapt
bipai aliexpress shop: https://www.aliexpress.com/item/1005007316915633.html?spm=5261.promotion_single_products.table.1.7faa4edfcV2VgX
Taobao shop:https://item.taobao.com/item.htm?ft=t&id=812076166951
OEM&ODM, please contact: [email protected]
Online wiki documents : Banana Pi BPI-WiFi6 Mini | BananaPi Docs
