Banana Pi BPI-WiFi5 Router with Siflower SF19A2890S + AN8855R design
Banana Pi BPI-Wifi5 Router use Siflower SF19A2890S and AN8855R Gigabit switch chip design. the It is a high performance wireless router for small and micro businesses, homes and other networking environments.
BPI-Wifi5 Router dual-band wireless router, 2.4G 2T2R, 5.8G 2T2R coexist at the same time. The use of four omnidirectional high-gain antennas, with strong signal penetration and wider coverage, which makes the already strong signal more powerful, data transmission is also smoother. MU-MIMO multi-device transceiver technology has low latency and multiple devices are stably connected simultaneously, thus ensuring a good experience for multiple devices.
BPI-Wifi5 Router adopts the national silicon Chang chip SF19A2890S +AN8855R (Gigabit switch chip) solution, providing gigabit network interface, 1 gigabit WAN port and 3 gigabit LAN ports, supporting 2.4G and 5G, wireless transmission rate of 1200Mbps; Supports rich software features, providing the ideal high-performance product for small and micro businesses and families.
Banana Pi Work closely with Siflower to make this product a fully open source wireless routing product.
  • Supports a maximum 1.2Gbps wireless rate with full gigabit ports
  • supports IEEE802.11a /b/g/n/ac
  • Supports 4x5 dBi external omnidirectional high-gain antennas
  • 5.8G Uses an external independent FEM to increase the wireless coverage of 5.8G
  • Mini Size, light machine
  • Production-level system support, direct productization
    • Intelligent QoS policy
      • The Mac-based network traffic rate limiting mechanism can effectively control the upstream/downstream traffic of a single PC and limit the excessive use of network bandwidth by P2P software
      • Supports upstream and downstream QoS policies to meet flexible service configuration requirements
    • Comprehensive system monitoring
      • Monitors Intranet traffic in real time for traffic monitoring and statistics
      • provides a variety of security logs, including real-time logs of internal and external network attacks, address binding logs, traffic alert logs, and session logs, for network administrators to monitor the network in real time
      • Operating status and security status
  • OpenWRT support
  • Open Source ,free DIY
PCBA Hardware inerface
##Product design
full open soruce Router ,welcome for OEM&ODM
online wiki documents:
BPI-WIFI5 Specification English version_241028.pdf
https://drive.google.com/drive/folders/1ovXHQt4_WhqveVTUA6SsT7fRGosTeQ-V
Banana Pi BPI-Wifi5 Low cost Router use Siflower SF19A2890S2 design
where can I find a factory flash image?
RP
I have seen this, of course, but there is no ’ System Image’.
I noticed there is a system image now. thanks.
However, it seems different, it doesn’t show the MAC address:
Capture2
Here a few more details:
On a new Router the MAC address gets displayed:
Capture
Also, on the new router the LED changes from red to blue after booting. Using your image it stays red.
The timestamps from the syslog are:
Your image:
Linux version 4.14.90 (qubot@3f8d14fbe086) (gcc version 7.4.0 (OpenWrt GCC 7.4.0 r0-3cc0edbe4)) #4 SMP Thu Dec 12 10:09:22 Asia 2024
Factory image:
Linux version 4.14.90 (qubot@8ed2b095ea87) (gcc version 7.4.0 (OpenWrt GCC 7.4.0 r0-82e8382ca)) #13 SMP Thu Nov 21 18:37:55 Asia 2024
Update Jan 25:
apparently no one cares around here…
Sorry. We have already noticed this issue and will contact the relevant personnel to fix it and upload the new image to the official website later.
Hello, we have already made the necessary changes to this issue. The mirror version of the official website will be updated in the coming days. If you still have any questions, please start a new thread with the title “WiFi5” and post your query there. Thank you.
