Banana Pi BPI-RV2 OpenWrt support
OpenWrt snapshot support is already available at
https://downloads.openwrt.org/snapshots//targets/siflower/sf21/
please see my post Banana Pi BPI-RV2 Risc-V gateway board design with Siflower SF21H8898 chip design - #12 by grrguu
To fix USB for OpenWrt snapshot please add the following diff to OpenWrt:
diff --git a/target/linux/siflower/dts/sf21h8898_bananapi_bpi-rv2.dtsi b/target/linux/siflower/dts/sf21h8898_bananapi_bpi-rv2.dtsi
index aa309e37c1..6904cf3048 100644
--- a/target/linux/siflower/dts/sf21h8898_bananapi_bpi-rv2.dtsi
+++ b/target/linux/siflower/dts/sf21h8898_bananapi_bpi-rv2.dtsi
@@ -185,6 +185,7 @@
 &usb {
        status = "okay";
+       vbus-supply = <&usb_vbus>;
 &dpns {
Still looking into how to fix NVMe. Maybe the issue is related to power regulator, too ? The following is missing in OpenWrt Snapshot sf21h8898-bpi-rv2.dtsi
	m2keyb_pwren: regulator@1 {
		compatible = "regulator-fixed";
		regulator-name = "m2keyb_pwren";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		gpio = <&gpio 38 GPIO_ACTIVE_HIGH>;
		enable-active-high;
		regulator-always-on;
…but adding the above alone does not bring NVMe up. Any hints ?
Thank you for your help.
Hi @sinovoip and thank you very much for your products! Already have BPI-F3 and happy with it!
I just received my BPI-RV2. It seems I cannot find full uboot source code tree of it. Can you please point me to it? I could not find it anywhere.
Thanks!
Do you looking for this?
I’ve been here and even successfully built openwrt from this repo but still not able to find any u-boot. This source tree contains build recipe only for OpenSBI with related patches, but u-boot is missing from there
After getting a B-key to M-key adapter I could test some other NVMe.
The issue experienced is only with the B-key NVMe, it’s not detected at all. This B-Key NVMe does work in x86 PC fine.
Not working: B-Key KIOKIA KBG50ZNS512G NVMe SSD
Using M-key NVMe via adapter the NVMe is detected (stock OpenWrt and OpenWrt snapshot):
root@bpirv2:~# lspci
0000:00:00.0 PCI bridge: Device 1a0a:abcd (rev 01)
0001:00:00.0 PCI bridge: Device 1a0a:abcd (rev 01)
0001:01:00.0 Non-Volatile memory controller: Sandisk Corp PC SN530 NVMe SSD (DRAM-less) (rev 01)
root@bpirv2:~# hdparm -t /dev/nvme0n1
/dev/nvme0n1:
Timing buffered disk reads: 1144 MB in  3.00 seconds = 380.88 MB/sec
root@bpirv2:~# hdparm -T /dev/nvme0n1
/dev/nvme0n1:
Timing cached reads:   1908 MB in  2.00 seconds = 953.73 MB/sec
0001:01:00.0 Non-Volatile memory controller: Sandisk Corp SanDisk Ultra 3D / WD Blue SN550 NVMe SSD (rev 01)
/dev/nvme0n1:
Timing buffered disk reads: 1108 MB in  3.00 seconds = 369.30 MB/sec
/dev/nvme0n1:
Timing cached reads:   1820 MB in  2.00 seconds = 909.89 MB/sec
So this is good news! Perhaps this is related to max W the PCIe slot can handle ? The older NVMe seem to draw more power…
I want to use the second SPI on the 26 pin header. I dissabled xgmac5 in a dts and configured the SPI1 interface, however I’m not able to make it work, doesn’t matter how many times I reconfigure the dtsi file and recompile. I suspect the problem is the U-Boot as it still inits the xgmac5 and this messes up with pinmuxing later in the linux kernel. This means that I have to disable the xgmac in U-Boot, but I need to recompile it. Which means we need the U-Boot source code, and as it is GPL, you should provide it.
