Thanks Frank, Daniel and Norman for confirming that your boards are booting fine.
I have tried latest snapshot from 4/15 and still having same issue (please see full boot log below, I have checked/cross-referenced with the default one on openwrt.org for R4 and not seeing anything significantly different).
With the BPI R4 image, I see following data in the log:
[ 10.389760] mtk-soc-temp-lvts 1100a000.lvts: [lvts_cal] golden_temp = 60
[ 10.396459] mtk-soc-temp-lvts 1100a000.lvts: [lvts_cal] num:g_count:g_count_rc 0:19308:5249 1:19323:0 2:19321:0 3:19341:0 4:19558:5271 5:19595:0 6:19577:0 7:19616:0
[ 10.413025] mtk-soc-temp-lvts 1100a000.lvts: [COUNT_RC_NOW] 0:5238 1:5248 2:5239 3:5248 4:5268 5:5266 6:5267 7:5266
[ 10.423556] mtk-soc-temp-lvts 1100a000.lvts: set_polling_speed 0, LVTSMONCTL1_0= 0x10000c,LVTSMONCTL2_0= 0x10001
[ 10.433717] mtk-soc-temp-lvts 1100a000.lvts: set_hw_filter 0, LVTSMSRCTL0_0= 0xb6d
[ 10.441274] mtk-soc-temp-lvts 1100a000.lvts: lvts0: read all 4 sensors in 10080 us, one in 2404 us
[ 10.450238] mtk-soc-temp-lvts 1100a000.lvts: set_polling_speed 1, LVTSMONCTL1_0= 0x10000c,LVTSMONCTL2_0= 0x10001
[ 10.460397] mtk-soc-temp-lvts 1100a000.lvts: set_hw_filter 1, LVTSMSRCTL0_0= 0xb6d
[ 10.467954] mtk-soc-temp-lvts 1100a000.lvts: lvts1: read all 4 sensors in 10080 us, one in 2404 us
[ 10.476899] mtk-soc-temp-lvts 1100a000.lvts: set_tc_hw_reboot_threshold: LVTS0, the dominator sensing point= 0
[ 10.486886] mtk-soc-temp-lvts 1100a000.lvts: set_tc_hw_reboot_threshold: LVTS1, the dominator sensing point= 0
[ 10.497101] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
OpenWRT boot log from 4/15:
F0: 102B 0000
FA: 1042 0000
FA: 1042 0000 [0200]
F9: 1041 0000
F3: 1001 0000 [0200]
F3: 1001 0000
F6: 380E 5800
F5: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0600 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [3000]
MK: 0000 0000 [0000]
T0: 0000 01CF [0101]
Jump to BL
NOTICE: BL2: v2.9.0(release):OpenWrt v2023.10.13~0ea67d76-1 (mt7988-sdmmc-comb)
NOTICE: BL2: Built : 20:50:34, Apr 15 2024
NOTICE: WDT: Cold boot
NOTICE: WDT: disabled
NOTICE: CPU: MT7988
NOTICE: EMI: Using DDR unknown settings
NOTICE: EMI: Detected DRAM size: 4096 MB
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.9.0(release):OpenWrt v2023.10.13~0ea67d76-1 (mt7988-sdmmc-comb)
NOTICE: BL31: Built : 20:50:34, Apr 15 2024
U-Boot 2024.01-OpenWrt-r25940-8c3dfdc46b (Apr 15 2024 - 20:50:34 +0000)
CPU: MediaTek MT7988
Model: Bananapi BPI-R4
DRAM: 4 GiB
Core: 63 devices, 23 uclasses, devicetree: embed
spi-nand: spi_nand spi_nand@0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
MMC: mmc@11230000: 0
Loading Environment from MMC... OK
In: serial@11000000
Out: serial@11000000
Err: serial@11000000
reset button found
Net: eth0: ethernet@15100000
Cannot read EFI system partition
Failed to persist EFI variables
( ( ( OpenWrt ) ) ) [SD card] U-Boot 2024.01-OpenWrt-r25940-8c3dfdc46b (Apr 15 2024 - 20:50:34 +0000)
1. Run default boot command.
2. Boot system via TFTP.
3. Boot production system from SD card.
4. Boot recovery system from SD card.
5. Load production system via TFTP then write to SD card.
6. Load recovery system via TFTP then write to SD card.
7. Install bootloader, recovery and production to NAND.
8. Reboot.
9. Reset all settings to factory defaults.
0. U-Boot console
MMC read: dev # 0, block # 131072, count 256 ... 256 blocks read: OK
MMC read: dev # 0, block # 131072, count 25744 ... 25744 blocks read: OK
## Loading kernel from FIT Image at 50000000 ...
Using 'config-mt7988a-bananapi-bpi-r4' configuration
Description: ARM64 OpenWrt Linux-6.1.86
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x50001000
Data Size: 5659774 Bytes = 5.4 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x46000000
Entry Point: 0x46000000
Hash algo: crc32
Hash value: 38424592
Hash algo: sha1
Hash value: 773e6c32356e8d48d9281d2abad9058ed6a7acea
## Loading fdt from FIT Image at 50000000 ...
Trying 'fdt-1' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x50567000
Data Size: 43107 Bytes = 42.1 KiB
Load Address: 0x45f00000
Hash algo: crc32
Hash value: 590fea91
Hash algo: sha1
Hash value: b3b8e5ec9316baee4c5420fbd4209e44ccd83339
Loading fdt from 0x50567000 to 0x45f00000
Using 'mt7988a-bananapi-bpi-r4-sd' configuration
Trying 'fdt-mt7988a-bananapi-bpi-r4-sd' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd
Data Start: 0x50574000
Data Size: 1482 Bytes = 1.4 KiB
Hash algo: crc32
Hash value: d0a3ad77
Hash algo: sha1
Hash value: 4ddb0442509f1e0e66f70270ad0aad5b57894599
Could not find configuration node
load of <NULL> failed
Booting using the fdt blob at 0x45f00000
Working FDT set to 45f00000
## Loading loadables from FIT Image at 50000000 ...
Trying 'rootfs-1' loadables subimage
Description: ARM64 OpenWrt bananapi_bpi-r4 rootfs
Type: Filesystem Image
Data Start: 0x50576000
Data Size: 7454720 Bytes = 7.1 MiB
Hash algo: crc32
Hash value: 75ef7d6b
Hash algo: sha1
Hash value: fb2a5960fa520d19a99a32bcea3676ae1ae0403f
Uncompressing Kernel Image
Loading Device Tree to 00000000fe7b4000, end 00000000fe7c0b0f ... OK
Working FDT set to fe7b4000
set /chosen/rootdisk to bootrom media: rootdisk-sd (phandle 0x0000009c)
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.1.86 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.2.0 r25940-8c3dfdc46b) 13.2.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Mon Apr 15 20:50:34 2024
[ 0.000000] Machine model: Bananapi BPI-R4
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004304ffff]
[ 0.000000] node 0: [mem 0x0000000043050000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 18 pages/cpu s33896 r8192 d31640 u73728
[ 0.000000] pcpu-alloc: s33896 r8192 d31640 u73728 alloc=18*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa7b4000-0x00000000fe7b4000] (64MB)
[ 0.000000] Memory: 4034372K/4194304K available (8576K kernel code, 894K rwdata, 2472K rodata, 448K init, 304K bss, 159932K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000063] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000069] pid_max: default: 32768 minimum: 301
[ 0.000271] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000285] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000857] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.001067] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001070] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.001142] rcu: Hierarchical SRCU implementation.
[ 0.001144] rcu: Max phase no-delay instances is 1000.
[ 0.001408] smp: Bringing up secondary CPUs ...
[ 0.001623] Detected VIPT I-cache on CPU1
[ 0.001672] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 0.001678] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.001698] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.001927] Detected VIPT I-cache on CPU2
[ 0.001959] cacheinfo: Unable to detect cache hierarchy for CPU 2
[ 0.001964] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.001973] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.002198] Detected VIPT I-cache on CPU3
[ 0.002230] cacheinfo: Unable to detect cache hierarchy for CPU 3
[ 0.002233] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002242] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.002270] smp: Brought up 1 node, 4 CPUs
[ 0.002274] SMP: Total of 4 processors activated.
[ 0.002276] CPU features: detected: 32-bit EL0 Support
[ 0.002279] CPU features: detected: CRC32 instructions
[ 0.002295] spectre-bhb mitigation disabled by compile time option
[ 0.002306] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.002309] CPU: All CPU(s) started at EL2
[ 0.002310] alternatives: applying system-wide alternatives
[ 0.005799] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005810] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.005915] pinctrl core: initialized pinctrl subsystem
[ 0.006455] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006734] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.006843] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006939] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.007178] thermal_sys: Registered thermal governor 'fair_share'
[ 0.007181] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.007182] thermal_sys: Registered thermal governor 'step_wise'
[ 0.007184] thermal_sys: Registered thermal governor 'user_space'
[ 0.007227] ASID allocator initialised with 65536 entries
[ 0.007679] printk: console [ramoops-1] enabled
[ 0.007714] pstore: Registered ramoops as persistent store backend
[ 0.007719] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.015839] cryptd: max_cpu_qlen set to 1000
[ 0.016574] SCSI subsystem initialized
[ 0.016624] libata version 3.00 loaded.
[ 0.017357] clocksource: Switched to clocksource arch_sys_counter
[ 0.017774] NET: Registered PF_INET protocol family
[ 0.017919] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.019802] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.019825] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.019838] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.019939] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.020354] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.020440] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.020497] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.020673] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.020708] PCI: CLS 0 bytes, default 64
[ 0.021487] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.023488] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.023498] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.042563] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.043346] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[ 0.043827] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.043846] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.043857] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 0.043869] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 0.043957] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 0.043969] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 0.043978] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 0.043987] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 0.044006] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[ 0.044014] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[ 0.044076] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 0.044086] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 0.044095] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 0.044103] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 0.044119] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[ 0.044126] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[ 0.044197] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 0.044207] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 0.044215] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 0.044223] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 0.044239] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[ 0.044246] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[ 0.048172] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.049515] printk: console [ttyS0] disabled
[ 0.069657] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 0.947375] printk: console [ttyS0] enabled
[ 0.972151] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[ 1.001846] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
[ 1.011623] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.019421] loop: module loaded
[ 1.023738] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.029072] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 1.037286] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.043652] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.050526] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.057514] Creating 2 MTD partitions on "spi0.0":
[ 1.062297] 0x000000000000-0x000000200000 : "bl2"
[ 1.068345] 0x000000200000-0x000008000000 : "ubi"
[ 1.140954] ubi0: default fastmap pool size: 50
[ 1.145477] ubi0: default fastmap WL pool size: 25
[ 1.150265] ubi0: attaching mtd1
[ 1.954759] ubi0: scanning is finished
[ 1.967913] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[ 1.973391] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 1.980260] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 1.987034] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 1.993985] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
[ 2.000069] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
[ 2.007278] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1697192243
[ 2.016401] ubi0: available PEBs: 105, total reserved PEBs: 903, PEBs reserved for bad PEB handling: 20
[ 2.025787] ubi0: background thread "ubi_bgt0d" started, PID 253
[ 2.033394] block ubiblock0_1: created from ubi0:1(rootfs)
[ 2.038878] ubiblock: device ubiblock0_1 (rootfs) set to be root filesystem
[ 2.178753] i2c_dev: i2c /dev entries driver
[ 2.198311] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 2.208022] mtk-msdc 11230000.mmc: Got CD GPIO
[ 2.208196] NET: Registered PF_INET6 protocol family
[ 2.217843] Segment Routing with IPv6
[ 2.221508] In-situ OAM (IOAM) with IPv6
[ 2.225447] NET: Registered PF_PACKET protocol family
[ 2.230512] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.243521] 8021q: 802.1Q VLAN Support v1.8
[ 2.248556] pstore: Using crash dump compression: deflate
[ 2.261980] phy phy-soc:[email protected]: type_sw - reg 0x218, index 0
[ 2.269000] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 2.276312] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 2.282583] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 2.291016] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 2.310070] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.320522] mmc0: new high speed SDHC card at address 9777
[ 2.326538] mmcblk0: mmc0:9777 SU16G 14.8 GiB
[ 2.336637] Alternate GPT is invalid, using primary GPT.
[ 2.342620] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.637366] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 2.646168] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 2.653210] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 2.660525] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 2.666788] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 2.675224] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 3.017361] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.026140] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[ 3.032989] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 3.040296] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 3.046555] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 3.054989] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 3.207360] thermal thermal_zone0: cpu-thermal: critical temperature reached, shutting down
[ 3.215699] reboot: HARDWARE PROTECTION shutdown (Temperature too high)
[ 3.222376] reboot: Failed to start orderly shutdown: forcing the issue
[ 3.229052] Emergency Sync complete
[ 3.300024] mtk-pcie-gen3 11300000.pcie: set IO trans window[0]: cpu_addr = 0x30000000, pci_addr = 0x30000000, size = 0x200000
[ 3.311405] mtk-pcie-gen3 11300000.pcie: set MEM trans window[1]: cpu_addr = 0x30200000, pci_addr = 0x30200000, size = 0x200000
[ 3.322869] mtk-pcie-gen3 11300000.pcie: set MEM trans window[2]: cpu_addr = 0x30400000, pci_addr = 0x30400000, size = 0x400000
[ 3.334332] mtk-pcie-gen3 11300000.pcie: set MEM trans window[3]: cpu_addr = 0x30800000, pci_addr = 0x30800000, size = 0x800000
[ 3.345794] mtk-pcie-gen3 11300000.pcie: set MEM trans window[4]: cpu_addr = 0x31000000, pci_addr = 0x31000000, size = 0x1000000
[ 3.357344] mtk-pcie-gen3 11300000.pcie: set MEM trans window[5]: cpu_addr = 0x32000000, pci_addr = 0x32000000, size = 0x2000000
[ 3.368895] mtk-pcie-gen3 11300000.pcie: set MEM trans window[6]: cpu_addr = 0x34000000, pci_addr = 0x34000000, size = 0x4000000
[ 3.380561] mtk-pcie-gen3 11300000.pcie: PCI host bridge to bus 0000:00
[ 3.387163] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.392643] pci_bus 0000:00: root bus resource [io 0x400000-0x5fffff] (bus address [0x30000000-0x301fffff])
[ 3.402459] pci_bus 0000:00: root bus resource [mem 0x30200000-0x37ffffff]
[ 3.409325] pci_bus 0000:00: scanning bus
[ 3.413343] pci 0000:00:00.0: [14c3:7988] type 01 class 0x060400
[ 3.419356] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 3.426191] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.432278] pci 0000:00:00.0: PME# disabled
[ 3.437633] pci_bus 0000:00: fixups for bus
[ 3.441808] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 3.448501] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.456497] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 3.463236] pci_bus 0000:01: scanning bus
[ 3.467258] pci 0000:01:00.0: [14c3:7915] type 00 class 0x000280
[ 3.473280] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 3.480507] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00003fff 64bit pref]
[ 3.487732] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00000fff 64bit pref]
[ 3.495043] pci 0000:01:00.0: supports D1 D2
[ 3.499305] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.505910] pci 0000:01:00.0: PME# disabled
[ 3.537391] pci_bus 0000:01: fixups for bus
[ 3.541564] pci_bus 0000:01: bus scan returning with max=01
[ 3.547126] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.553736] pci_bus 0000:00: bus scan returning with max=01
[ 3.559309] pci 0000:00:00.0: BAR 9: assigned [mem 0x30200000-0x303fffff 64bit pref]
[ 3.567040] pci 0000:00:00.0: BAR 0: assigned [mem 0x30400000-0x30407fff 64bit]
[ 3.574344] pci 0000:01:00.0: BAR 0: assigned [mem 0x30200000-0x302fffff 64bit pref]
[ 3.582088] pci 0000:01:00.0: BAR 2: assigned [mem 0x30300000-0x30303fff 64bit pref]
[ 3.589831] pci 0000:01:00.0: BAR 4: assigned [mem 0x30304000-0x30304fff 64bit pref]
[ 3.597575] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.602531] pci 0000:00:00.0: bridge window [mem 0x30200000-0x303fffff 64bit pref]
[ 3.610273] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.618718] pci 0000:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 3.627197] pcieport 0000:00:00.0: assign IRQ: got 112
[ 3.632334] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 3.638428] pcieport 0000:00:00.0: enabling bus mastering
[ 3.644076] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 3.652511] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[ 3.660941] mtk-pcie-gen3 11300000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11300c00 data 2
[ 3.669367] mtk-pcie-gen3 11300000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11300c00 data 3
[ 3.677794] mtk-pcie-gen3 11300000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11300c00 data 4
[ 3.686217] mtk-pcie-gen3 11300000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11300c00 data 5
[ 3.694643] mtk-pcie-gen3 11300000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11300c00 data 6
[ 3.703068] mtk-pcie-gen3 11300000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11300c00 data 7
[ 3.711492] mtk-pcie-gen3 11300000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11300c00 data 8
[ 3.719918] mtk-pcie-gen3 11300000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11300c00 data 9
[ 3.728345] mtk-pcie-gen3 11300000.pcie: msi#0xa address_hi 0x0 address_lo 0x11300c00 data 10
[ 3.736855] mtk-pcie-gen3 11300000.pcie: msi#0xb address_hi 0x0 address_lo 0x11300c00 data 11
[ 3.745366] mtk-pcie-gen3 11300000.pcie: msi#0xc address_hi 0x0 address_lo 0x11300c00 data 12
[ 3.753878] mtk-pcie-gen3 11300000.pcie: msi#0xd address_hi 0x0 address_lo 0x11300c00 data 13
[ 3.762390] mtk-pcie-gen3 11300000.pcie: msi#0xe address_hi 0x0 address_lo 0x11300c00 data 14
[ 3.770902] mtk-pcie-gen3 11300000.pcie: msi#0xf address_hi 0x0 address_lo 0x11300c00 data 15
[ 3.779416] mtk-pcie-gen3 11300000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11300c00 data 16
[ 3.788015] mtk-pcie-gen3 11300000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11300c00 data 17
[ 3.796612] mtk-pcie-gen3 11300000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11300c00 data 18
[ 3.805211] mtk-pcie-gen3 11300000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11300c00 data 19
[ 3.813809] mtk-pcie-gen3 11300000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11300c00 data 20
[ 3.822408] mtk-pcie-gen3 11300000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11300c00 data 21
[ 3.831006] mtk-pcie-gen3 11300000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11300c00 data 22
[ 3.839606] mtk-pcie-gen3 11300000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11300c00 data 23
[ 3.848205] mtk-pcie-gen3 11300000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11300c00 data 24
[ 3.856801] mtk-pcie-gen3 11300000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11300c00 data 25
[ 3.865399] mtk-pcie-gen3 11300000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11300c00 data 26
[ 3.873998] mtk-pcie-gen3 11300000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11300c00 data 27
[ 3.882596] mtk-pcie-gen3 11300000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11300c00 data 28
[ 3.891195] mtk-pcie-gen3 11300000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11300c00 data 29
[ 3.899795] mtk-pcie-gen3 11300000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11300c00 data 30
[ 3.908394] mtk-pcie-gen3 11300000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11300c00 data 31
[ 3.917287] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 3.925776] pcieport 0000:00:00.0: PME: Signaling with IRQ 113
[ 3.931689] pcieport 0000:00:00.0: AER: enabled with IRQ 113
[ 3.937368] pcieport 0000:00:00.0: saving config space at offset 0x0 (reading 0x798814c3)
[ 3.945533] pcieport 0000:00:00.0: saving config space at offset 0x4 (reading 0x100406)
[ 3.953556] pcieport 0000:00:00.0: saving config space at offset 0x8 (reading 0x6040001)
[ 3.961636] pcieport 0000:00:00.0: saving config space at offset 0xc (reading 0x10000)
[ 3.969541] pcieport 0000:00:00.0: saving config space at offset 0x10 (reading 0x30400004)
[ 3.977794] pcieport 0000:00:00.0: saving config space at offset 0x14 (reading 0x0)
[ 3.985436] pcieport 0000:00:00.0: saving config space at offset 0x18 (reading 0x10100)
[ 3.993427] pcieport 0000:00:00.0: saving config space at offset 0x1c (reading 0x1f1)
[ 4.001244] pcieport 0000:00:00.0: saving config space at offset 0x20 (reading 0xfff0)
[ 4.009149] pcieport 0000:00:00.0: saving config space at offset 0x24 (reading 0x30313021)
[ 4.017404] pcieport 0000:00:00.0: saving config space at offset 0x28 (reading 0x0)
[ 4.025046] pcieport 0000:00:00.0: saving config space at offset 0x2c (reading 0x0)
[ 4.032690] pcieport 0000:00:00.0: saving config space at offset 0x30 (reading 0x0)
[ 4.040334] pcieport 0000:00:00.0: saving config space at offset 0x34 (reading 0x80)
[ 4.048065] pcieport 0000:00:00.0: saving config space at offset 0x38 (reading 0x0)
[ 4.055707] pcieport 0000:00:00.0: saving config space at offset 0x3c (reading 0x20170)
[ 4.063957] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 4.071264] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 4.077528] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 4.085956] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 4.247357] thermal thermal_zone0: cpu-thermal: critical temperature reached, shutting down
[ 4.255695] reboot: HARDWARE PROTECTION shutdown (Temperature too high)
[ 4.330014] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[ 4.341398] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[ 4.352863] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[ 4.364327] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[ 4.375789] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[ 4.387339] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[ 4.398888] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[ 4.410522] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[ 4.417125] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.422604] pci_bus 0001:00: root bus resource [io 0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[ 4.432419] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[ 4.439283] pci_bus 0001:00: scanning bus
[ 4.443296] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[ 4.449306] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 4.456138] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.462224] pci 0001:00:00.0: PME# disabled
[ 4.467513] pci_bus 0001:00: fixups for bus
[ 4.471687] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 4.478380] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.486375] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 4.493104] pci_bus 0001:01: scanning bus
[ 4.497125] pci 0001:01:00.0: [14c3:0616] type 00 class 0x028000
[ 4.503147] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 4.510374] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 4.517267] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 4.523354] pci 0001:01:00.0: PME# disabled
[ 4.557392] pci_bus 0001:01: fixups for bus
[ 4.561565] pci_bus 0001:01: bus scan returning with max=01
[ 4.567125] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.573734] pci_bus 0001:00: bus scan returning with max=01
[ 4.579303] pci 0001:00:00.0: BAR 8: assigned [mem 0x38200000-0x382fffff]
[ 4.586080] pci 0001:00:00.0: BAR 9: assigned [mem 0x38300000-0x383fffff 64bit pref]
[ 4.593814] pci 0001:00:00.0: BAR 0: assigned [mem 0x38400000-0x38407fff 64bit]
[ 4.601118] pci 0001:01:00.0: BAR 0: assigned [mem 0x38300000-0x383fffff 64bit pref]
[ 4.608862] pci 0001:01:00.0: BAR 2: assigned [mem 0x38200000-0x38207fff 64bit]
[ 4.616169] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 4.621126] pci 0001:00:00.0: bridge window [mem 0x38200000-0x382fffff]
[ 4.627904] pci 0001:00:00.0: bridge window [mem 0x38300000-0x383fffff 64bit pref]
[ 4.635643] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.644086] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 4.652553] pcieport 0001:00:00.0: assign IRQ: got 115
[ 4.657688] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[ 4.663777] pcieport 0001:00:00.0: enabling bus mastering
[ 4.669409] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 4.677847] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 4.686272] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[ 4.694698] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[ 4.703124] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[ 4.711550] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[ 4.719974] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[ 4.728399] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[ 4.736822] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[ 4.745247] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[ 4.753672] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[ 4.762184] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[ 4.770696] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[ 4.779208] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[ 4.787720] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[ 4.796230] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[ 4.804743] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[ 4.813343] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[ 4.821942] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[ 4.830541] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[ 4.839139] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[ 4.847738] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[ 4.856335] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[ 4.864933] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[ 4.873531] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[ 4.882130] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[ 4.890728] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[ 4.899327] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[ 4.907925] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[ 4.916522] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[ 4.925122] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[ 4.933721] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[ 4.942607] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 4.951086] pcieport 0001:00:00.0: PME: Signaling with IRQ 116
[ 4.957009] pcieport 0001:00:00.0: AER: enabled with IRQ 116
[ 4.962689] pcieport 0001:00:00.0: saving config space at offset 0x0 (reading 0x798814c3)
[ 4.970858] pcieport 0001:00:00.0: saving config space at offset 0x4 (reading 0x100406)
[ 4.978852] pcieport 0001:00:00.0: saving config space at offset 0x8 (reading 0x6040001)
[ 4.986928] pcieport 0001:00:00.0: saving config space at offset 0xc (reading 0x10000)
[ 4.994834] pcieport 0001:00:00.0: saving config space at offset 0x10 (reading 0x38400004)
[ 5.003086] pcieport 0001:00:00.0: saving config space at offset 0x14 (reading 0x0)
[ 5.010730] pcieport 0001:00:00.0: saving config space at offset 0x18 (reading 0x10100)
[ 5.018721] pcieport 0001:00:00.0: saving config space at offset 0x1c (reading 0x1f1)
[ 5.026538] pcieport 0001:00:00.0: saving config space at offset 0x20 (reading 0x38203820)
[ 5.034789] pcieport 0001:00:00.0: saving config space at offset 0x24 (reading 0x38313831)
[ 5.043043] pcieport 0001:00:00.0: saving config space at offset 0x28 (reading 0x0)
[ 5.050687] pcieport 0001:00:00.0: saving config space at offset 0x2c (reading 0x0)
[ 5.058332] pcieport 0001:00:00.0: saving config space at offset 0x30 (reading 0x0)
[ 5.065974] pcieport 0001:00:00.0: saving config space at offset 0x34 (reading 0x80)
[ 5.073705] pcieport 0001:00:00.0: saving config space at offset 0x38 (reading 0x0)
[ 5.081349] pcieport 0001:00:00.0: saving config space at offset 0x3c (reading 0x20173)
[ 5.090293] FIT: Detected U-Boot 2024.01-OpenWrt-r25940-8c3dfdc46b
[ 5.096464] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4" (OpenWrt bananapi_bpi-r4)
[ 5.105511] FIT: kernel sub-image 0x00001000..0x00566c7d "kernel-1" (ARM64 OpenWrt Linux-6.1.86)
[ 5.115276] FIT: flat_dt sub-image 0x00567000..0x00571862 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4 device tree blob)
[ 5.126487] FIT: flat_dt sub-image 0x00572000..0x00572611 "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[ 5.142819] FIT: flat_dt sub-image 0x00573000..0x0057311c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[ 5.158979] FIT: flat_dt sub-image 0x00574000..0x005745c9 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd)
[ 5.174963] FIT: flat_dt sub-image 0x00575000..0x005758eb "fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a)
[ 5.192678] FIT: filesystem sub-image 0x00576000..0x00c91fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4 rootfs)
[ 5.203478] block mmcblk0p7: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[ 5.211168] block mmcblk0p7: mapped remaing space as /dev/fitrw
[ 5.287355] thermal thermal_zone0: cpu-thermal: critical temperature reached, shutting down
[ 5.295692] reboot: HARDWARE PROTECTION shutdown (Temperature too high)
[ 5.348743] mtk_soc_eth 15100000.ethernet: generated random MAC address <removed>
[ 5.356915] mtk_soc_eth 15100000.ethernet: generated random MAC address <removed>
[ 5.365089] mtk_soc_eth 15100000.ethernet: generated random MAC address <removed>
[ 5.373653] mdio_bus mdio-bus:0f: error -16 loading PHY driver module for ID 0x00339c11
[ 5.381842] mtk_soc_eth: probe of 15100000.ethernet failed with error -16
[ 5.389316] UBI: auto-attach mtd1
[ 5.392623] ubi: mtd1 is already attached to ubi0
[ 5.397315] UBI error: cannot attach mtd1
[ 5.401872] reboot: Power down
PANIC at PC : 0x00000000430048c4
