Banana Pi BPI-R4 Pro Wifi7 Router board with Mediatek MT7988A, 8G RAM 8G eMMC, 4x2.5G and 2x10G network port
You should check your text using an AI grammar tool:
MediaTek MT7988 (Filogic 880)
The MediaTek Filogic 880 platform provides a 36 Gbps Wi-Fi 7 access point/router/gateway solution that delivers the fastest and most reliable connectivity experience.
The MediaTek MT7988A is a world-class network processor designed for high-performance and reliable networking in both wired and wireless applications. It offers a comprehensive set of connectivity interfaces, including four Gigabit Ethernet ports, two USXGMII interfaces, four PCIe interfaces, and two USB 3.2 Gen 1 ports.
The MT7988A further enables seamless tri-band Wi-Fi 7 connectivity across the 2.4 GHz, 5 GHz, and 6 GHz bands, with its Wi-Fi 7 companion chip featuring 320 MHz bandwidth, 4096-QAM, MLO, MRU and AFC.
To meet the needs of rapidly evolving tunneling applications, the MT7988A comes equipped with the MediaTek Tunnel Offload Processor System (TOPS), which facilitates the processing of a wide range of tunneling protocols. The MT7988A optimizes networking performance with a finely tuned ISA of MediaTek TOPS, delivering premium-level offloading capabilities.
looks great, i would instantly buy one. is there any information regarding a new case? thinking of BE19, good shielding, enough ports for antennas, better cooling etc.
Looks like an awesome exellent product!! How soon will these be ready?
you did it! ohhh you did it! soo glad i told myself to wait a little longer after the R4 was out to see if you would release a board like this… I legit couldnt have designed one any better!
Will there be a new PRO 2 model for BE19? I see that only BE14 fits on this PRO board in terms of size.
I guess you have to use this:
But not sure if be19 would fit into it.
Yes, I need this. Especially
  • 3x M.2 B-KEY slots with USB3.2 for 5G Module
That’s what I need. Several 2.5G RJ45, Wifi7, and if it truly can handle three 5G modules simultaneously, then I’m definitely looking forward to it.
As someone who just plan to use it as a router, front PD port is jank. 10G ports are nice but personally I probably prefer to have have SFP only instead of using combo, I suppose it is overall cheaper the current way. Curious about how be19 will work on this board. Will likely get one if the price is right, thermal is likely better too (and easier to work with) which is great.
Any plans about pocket sized (compact board+case ± xiaomi 15 non pro, or even less"; inside of pcb Ethernet ports, Li-ion UPS&PoE (build-in or available as option), few m.2 ports without space for them(for custom big sized cases), 2x+Ethernet(10G+?), +few!! microsd express ports => So, needed pcie 3.0+ port multiplier ic.
Ethernet hub as thin little module, max compact sized!
+also wifi 7be compact with single m.2 port be19k. +also wifi 7be compact without 6Ghz (not sh** 2x2 or 3x3, but 4x5 and so on!) with two 5Ghz (and with single m.2 port?).
+also gpio? Any plans for CNX?).
+Waterproof Case (not fully, but ±!) & Case-radiator from two-three sides.
BPi3 mini - good, but too small for all the tastes of the mt7988 chip!(.
Is there already a code repo and schematics? Have not found any yet.
Can somebody please explain to me how these “combo ports” work?. Can i use only either the SFP or RJ45 or can both be used at the same time?
Thanks!
The usual meaning for combo port is either-or, not both.
Hi, Where are these available for purchase?
I’m sure only one of both parts can be used at one time.
But based on the devicetree in mtk-feeds it looks like it can be switched using a gppio
https://git01.mediatek.com/plugins/gitiles/openwrt/feeds/mtk-openwrt-feeds/+/HEAD/autobuild/unified/filogic/24.10/files/target/linux/mediatek/files-6.6/arch/arm64/boot/dts/mediatek/mt7988a-bananapi-bpi-r4-pro.dts#127
@mytratom it is not yet for sale. There are only a few development samples to do the software support.
Any idea when these will be on sale?
No,still waiting for my sample board to try to get it working and make some first tests.
How are your first tests?
i have it booting and try to get the maxlinear switch and the aeonsemi phys working :slight_smile:
Software needs some work. i also found some hw issues which should be fixed in later versions (maybe it is already better in actual revision)…
i have a v00 board, not defined for sale, it is normal that not all is working in this state, so don’t worry :slight_smile:
Personally, I think the R4 pro is a direct match for the be19. Do you have any plans to test the be19 once prototypes start rolling out?
