Banana pi bpi-r4 POE version case
Hello everyone. I took a board with a poe module.Without thinking, I also bought a standard case. It turned out that the front panel is incompatible. What to do now? I buy this case Aluminum case for Banana Pi BPI-R4 I assembled everything, the front panel was screwed tightly, I looked, but it did not fit completely.
I would also like to know if there is alternative case you can buy or if you could order just the plate that dose not fit!
I also ordered the case whiteout thinking about this…
I printed the plate on a 3D printer, the seller said that there is no alternative cover for the POE version
I had the same experience. The only real option is to 3D print a case right now. There is an acrylic case that you can buy but you’d need to use a Dremel to make space for the port.
just wondering, the POE is enable when bouhgt with the module already soldered? Do I have to solder the RJ45 connector? or any of the other 3 are enable to use POE in this case to power in the router
