Banana Pi BPI-R4-NIC-BE14 V2.1 Wifi module
Yes, i enabled firewall and it work. Sorry.
So all is working now with @frank-w branch? If so, great!!!
That is good news, frank-w, at least it works for someone else.
I just walked around the house and tested the Wi-Fi reception level, it was a little better (and in some places much better) than my current Xiaomi Redmi Router AX6000. Considering that it is located lower and in a further corner from the test point. But I bought high-quality pigtails with a thick conductor (SMA-female - U.FL (IPX), 30, on an RG-178 cable, but I also needed an S-A321 adapter with RP-SMA-female and SMA-male connectors) and spaced the antennas at a more or less optimal distance along the body of the BPI p4 pro.
I ran speed tests, but it doesn’t seem to be very stable yet (generally ok, but sometimes there were drops of up to 10 Mb/s. Usually 70-90 Mb/s). I tested the Internet, it is not very fast for me (100 Mb/s). Maybe due to the extremely low position of the router and the presence in the same room of a second router at 5G frequency on the same channels. Maybe the Ts on the chip will still grow? I haven’t been able to configure the fans on the router yet. How will it be which package is missing?
Yes. It works good. But MAY BE not very stable but need more tests. Maybe I’ll try to temporarily replace the main router with it for testing. It’s very annoying that if you need to install something, you have to assemble the firmware manually. I would like at least official snapshots.
I’m not behind a PC right now but you don’t really have to recompile the firmware, what you need to do is something like the below if the package isn’t in the OpenWrt repository:
  1. Modify .config to include the package you want.
  2. Run make defconfig.
  3. Do something like (I cannot remember the exact command) make package/docker/compile.
After that the package can be found in the bin directory. Copy that over to the router, then run apk add --allow-untrusted <file>.
If anyone knows a better way, please do share that and the exact commands to run.
Yes. I know it. example nano
select in make menuconfig like a Module.
make package/feeds/packages/nano/download #need also
make package/feeds/packages/nano/compile -j$(nproc) V=s
find bin/packages/ -name "nano*"
It’s very inconvenient.
Isn’t there an option to build all packages in .config? I am sure I saw it.
make defconfig download clean world
Build all in .config
Manual for make you can find there: https://openwrt.org/docs/guide-developer/toolchain/use-buildsystem
Who can tell me when they will send our board to the official OpenWrt? I expect 1-2 weeks, but I can’t understand whether all the problems have been resolved?
The R4Pro PR is open for a long time already…i hope too that it is merged soon,but i did not expect that…it is currently only for 8x without the phy support which we added recently in my fork so atm it will be very basic support. You are here in the be14 thread,so it is a kind of offtopic
I finally had time to play around with the new BE14 v2 which received a few weeks ago. A couple of (not that good) pictures of the board I got:
Due to some time constraints I decided to start with the upstream OpenWrt version 25.12.5 r33051-f5dae5ece4. I believe most people will also want to get the upstream version and not build their own
I been running this build in my lab, as a second router, for more than a week and been using it as my main Macbook and Iphone access point the whole time the experience has been very good, specially without any tweaks. I know the internet speed is not exactly the best test although, I been running a few tests here and there and comparing with the main router since that’s what people would usually care about.
A sample while using 5Ghz 2 rooms away.
I also run a lot of simple tests with iperf3 and you can find them bellow. A week with a “normal user” utilisation has been great so far but will try to run more tests and experiment other builds, including MLO support by @wozi
Let me known if there are any tests you would like to see or any specific settings I should try.
iperf3 tests
Setup
Server is running in the background
iperf3 -s -D --logfile /root/iperf3.log
Client runs the default command
$ iperf3 -c 192.168.10.1
My Wifi settings
uci show wireless
NOTE: Some output was redacted
wireless.radio0=wifi-device
wireless.radio0.type='mac80211'
wireless.radio0.radio='0'
wireless.radio0.band='2g'
wireless.radio0.channel='auto'
wireless.radio0.htmode='HE20'
wireless.radio0.country='**'
wireless.radio0.cell_density='0'
wireless.default_radio0=wifi-iface
wireless.default_radio0.device='radio0'
wireless.default_radio0.network='lan'
wireless.default_radio0.mode='ap'
wireless.default_radio0.ssid='OpenWrt 2.4Ghz'
wireless.default_radio0.encryption='sae'
wireless.default_radio0.ocv='0'
wireless.radio1=wifi-device
wireless.radio1.type='mac80211'
wireless.radio1.radio='1'
wireless.radio1.band='5g'
wireless.radio1.channel='auto'
wireless.radio1.htmode='EHT80'
wireless.radio1.country='**'
wireless.radio1.cell_density='0'
wireless.default_radio1=wifi-iface
wireless.default_radio1.device='radio1'
wireless.default_radio1.network='lan'
wireless.default_radio1.mode='ap'
wireless.default_radio1.ssid='OpenWrt 5Ghz'
wireless.default_radio1.encryption='sae'
wireless.default_radio1.ocv='0'
wireless.radio2=wifi-device
wireless.radio2.type='mac80211'
wireless.radio2.radio='2'
wireless.radio2.band='6g'
wireless.radio2.channel='auto'
wireless.radio2.htmode='EHT160'
wireless.radio2.country='**'
wireless.radio2.cell_density='0'
wireless.default_radio2=wifi-iface
wireless.default_radio2.device='radio2'
wireless.default_radio2.network='lan'
wireless.default_radio2.mode='ap'
wireless.default_radio2.ssid='OpenWrt 6Ghz'
wireless.default_radio2.encryption='sae'
wireless.default_radio2.ocv='0'
Results
2.4 GHz
Near by +/- 1m
Client Wifi reporting:
RSSI: -48 dBm
Noise: -91 dBm
Tx Rate: 229 Mbps
PHY Mode: 802.11ax
iperf results
Connecting to host 192.168.10.1, port 5201
[  5] local 192.168.10.121 port 63317 connected to 192.168.10.1 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  19.0 MBytes   159 Mbits/sec    0   1.93 MBytes
[  5]   1.00-2.01   sec  17.0 MBytes   142 Mbits/sec    0   2.70 MBytes
[  5]   2.01-3.00   sec  11.6 MBytes  97.6 Mbits/sec    8   1.72 MBytes
[  5]   3.00-4.00   sec  16.1 MBytes   136 Mbits/sec    0   1.81 MBytes
[  5]   4.00-5.01   sec  18.5 MBytes   154 Mbits/sec    0   1.90 MBytes
[  5]   5.01-6.01   sec  18.0 MBytes   151 Mbits/sec    0   1.94 MBytes
[  5]   6.01-7.00   sec  17.4 MBytes   146 Mbits/sec    0   1.93 MBytes
[  5]   7.00-8.00   sec  16.4 MBytes   137 Mbits/sec    0   1.93 MBytes
[  5]   8.00-9.01   sec  16.0 MBytes   134 Mbits/sec    0   1.92 MBytes
[  5]   9.01-10.00  sec  13.2 MBytes   112 Mbits/sec    0   1.73 MBytes
[  5]   0.00-10.00  sec   163 MBytes   137 Mbits/sec    8            sender
[  5]   0.00-10.07  sec   163 MBytes   136 Mbits/sec                  receiver
Next room +/- 5m with wall and door in between
RSSI: -69 dBm
Noise: -97 dBm
Tx Rate: 34 Mbps
PHY Mode: 802.11ax
iperf results
[  5] local 192.168.10.121 port 63700 connected to 192.168.10.1 port 5201
[  5]   0.00-1.01   sec  5.12 MBytes  42.8 Mbits/sec    0   1.75 MBytes
[  5]   1.01-2.01   sec   512 KBytes  4.19 Mbits/sec    0   1.51 MBytes
[  5]   2.01-3.00   sec  0.00 Bytes  0.00 bits/sec    0   1.14 MBytes
[  5]   3.00-4.00   sec  2.62 MBytes  22.0 Mbits/sec    0   1.39 MBytes
[  5]   4.00-5.00   sec  2.38 MBytes  19.9 Mbits/sec    0   1.50 MBytes
[  5]   5.00-6.00   sec  2.25 MBytes  18.9 Mbits/sec    0   1.07 MBytes
[  5]   6.00-7.00   sec  2.38 MBytes  19.9 Mbits/sec    0   1.45 MBytes
[  5]   7.00-8.01   sec  2.12 MBytes  17.8 Mbits/sec    0   1.07 MBytes
[  5]   8.01-9.00   sec  0.00 Bytes  0.00 bits/sec    0   1.41 MBytes
[  5]   9.00-10.00  sec  4.12 MBytes  34.6 Mbits/sec    0   1.07 MBytes
[  5]   0.00-10.00  sec  21.5 MBytes  18.0 Mbits/sec    0            sender
[  5]   0.00-10.70  sec  19.9 MBytes  15.6 Mbits/sec                  receiver
5 GHz
Near by +/- 1m
RSSI: -47 dBm
Noise: -92 dBm
Tx Rate: 1,080 Mbps
PHY Mode: 802.11ax
[  5] local 192.168.10.153 port 63260 connected to 192.168.10.1 port 5201
[  5]   0.00-1.00   sec  89.9 MBytes   750 Mbits/sec    0   7.97 MBytes
[  5]   1.00-2.00   sec  88.4 MBytes   743 Mbits/sec    0   2.90 MBytes
[  5]   2.00-3.00   sec  80.9 MBytes   678 Mbits/sec    0   3.03 MBytes
[  5]   3.00-4.00   sec  75.5 MBytes   633 Mbits/sec    0   3.14 MBytes
[  5]   4.00-5.00   sec  75.2 MBytes   631 Mbits/sec    0   3.23 MBytes
[  5]   5.00-6.00   sec  79.9 MBytes   671 Mbits/sec    0   3.29 MBytes
[  5]   6.00-7.01   sec  73.5 MBytes   615 Mbits/sec    0   3.33 MBytes
[  5]   7.01-8.00   sec  72.0 MBytes   606 Mbits/sec    0   3.36 MBytes
[  5]   8.00-9.01   sec  88.6 MBytes   741 Mbits/sec    0   3.36 MBytes
[  5]   9.01-10.01  sec  85.9 MBytes   720 Mbits/sec    0   3.37 MBytes
[  5]   0.00-10.01  sec   810 MBytes   679 Mbits/sec    0            sender
[  5]   0.00-10.02  sec   808 MBytes   676 Mbits/sec                  receiver
RSSI: -75 dBm
Noise: -93 dBm
Tx Rate: 68 Mbps
PHY Mode: 802.11ax
iperf results
[  5] local 192.168.10.153 port 63529 connected to 192.168.10.1 port 5201
[  5]   0.00-1.00   sec  4.25 MBytes  35.6 Mbits/sec    0   1.41 MBytes
[  5]   1.00-2.01   sec  1.25 MBytes  10.5 Mbits/sec    0   1.65 MBytes
[  5]   2.01-3.00   sec  3.00 MBytes  25.2 Mbits/sec    0   1.47 MBytes
[  5]   3.00-4.00   sec  2.00 MBytes  16.8 Mbits/sec    0   1.39 MBytes
[  5]   4.00-5.00   sec  1.12 MBytes  9.46 Mbits/sec    0   1.24 MBytes
[  5]   5.00-6.01   sec  5.50 MBytes  46.0 Mbits/sec    0   1.43 MBytes
[  5]   6.01-7.00   sec  2.62 MBytes  22.1 Mbits/sec    0   1.45 MBytes
[  5]   7.00-8.00   sec  2.62 MBytes  22.0 Mbits/sec    0   1.46 MBytes
[  5]   8.00-9.00   sec  3.75 MBytes  31.5 Mbits/sec    0   1.48 MBytes
[  5]   9.00-10.00  sec  1.50 MBytes  12.6 Mbits/sec    0   1.32 MBytes
[  5]   0.00-10.00  sec  27.6 MBytes  23.2 Mbits/sec    0            sender
[  5]   0.00-10.61  sec  27.5 MBytes  21.7 Mbits/sec                  receiver
6 GHz
Near by +/- 1m
RSSI: -78 dBm
Noise: -92 dBm
Tx Rate: 72 Mbps
PHY Mode: 802.11ax
iperf results
[  5] local 192.168.10.147 port 63402 connected to 192.168.10.1 port 5201
[  5]   0.00-1.00   sec  39.0 MBytes   327 Mbits/sec  132   1.98 MBytes
[  5]   1.00-2.00   sec  49.4 MBytes   414 Mbits/sec    0   2.11 MBytes
[  5]   2.00-3.01   sec   108 MBytes   908 Mbits/sec    0   2.21 MBytes
[  5]   3.01-4.00   sec   117 MBytes   987 Mbits/sec    0   2.28 MBytes
[  5]   4.00-5.01   sec   120 MBytes  1.01 Gbits/sec    0   2.33 MBytes
[  5]   5.01-6.01   sec   129 MBytes  1.09 Gbits/sec    0   2.37 MBytes
[  5]   6.01-7.01   sec   131 MBytes  1.10 Gbits/sec    0   2.39 MBytes
[  5]   7.01-8.00   sec   125 MBytes  1.05 Gbits/sec    0   2.40 MBytes
[  5]   8.00-9.00   sec   120 MBytes  1.00 Gbits/sec    0   2.41 MBytes
[  5]   9.00-10.01  sec   116 MBytes   975 Mbits/sec    0   2.41 MBytes
[  5]   0.00-10.01  sec  1.03 GBytes   885 Mbits/sec  132            sender
[  5]   0.00-10.01  sec  1.03 GBytes   883 Mbits/sec                  receiver
RSSI: -46 dBm
Noise: -91 dBm
Tx Rate: 1,921 Mbps
PHY Mode: 802.11ax
iperf results
[  5] local 192.168.10.147 port 63475 connected to 192.168.10.1 port 5201
[  5]   0.00-1.01   sec  2.38 MBytes  19.8 Mbits/sec    2    345 KBytes
[  5]   1.01-2.00   sec  3.62 MBytes  30.4 Mbits/sec    0    378 KBytes
[  5]   2.00-3.00   sec  5.50 MBytes  46.3 Mbits/sec    0    398 KBytes
[  5]   3.00-4.00   sec  5.12 MBytes  43.1 Mbits/sec    0    408 KBytes
[  5]   4.00-5.00   sec  5.62 MBytes  47.1 Mbits/sec    0    412 KBytes
[  5]   5.00-6.00   sec  5.25 MBytes  44.0 Mbits/sec    0    412 KBytes
[  5]   6.00-7.01   sec  5.50 MBytes  46.1 Mbits/sec    0    418 KBytes
[  5]   7.01-8.01   sec  4.50 MBytes  37.7 Mbits/sec    0    433 KBytes
[  5]   8.01-9.01   sec  2.25 MBytes  18.9 Mbits/sec    0    442 KBytes
[  5]   9.01-10.00  sec   768 KBytes  6.31 Mbits/sec    2   1.41 KBytes
[  5]   0.00-10.00  sec  40.5 MBytes  34.0 Mbits/sec    4            sender
[  5]   0.00-10.01  sec  39.5 MBytes  33.1 Mbits/sec                  receiver
Noise seen by the client is below -92 dBm in all cases. What are your channel bandwidth settings for 5GHz and 6GHz ?
I shared “My Wifi settings” in the post, is this what you are asking?
5Ghz
6Ghz
My fault. I overlooked the fact that you shared your wifi config.
Hello everyone! Now i test it in snapshot openwrt (today we can get it in official chanels openwrt like firmware selector) on bpi r4 pro 4e. I can see that default config in snapshot not correct. Where need send correct /etc/config/wireless?
What’s the conclusion now? Is the new BE14 better in range and connectivity?
Signal quality seems noticeably better based on the reports in this thread.
Do you also have measured the noise level reported by the bpi-R4-nic?
e.g.: iw phy-2g survey dump ?
Sorry for the late reply but was away and without access to my lab
iw dev phy0.0-ap0 survey dump
Survey data from phy0.0-ap0
	frequency:			2412 MHz
	noise:				-90 dBm
	channel active time:		110 ms
	channel busy time:		7 ms
	channel receive time:		7 ms
	channel BSS receive time:	0 ms
	channel transmit time:		0 ms
	frequency:			2417 MHz
	noise:				-63 dBm
	channel active time:		114 ms
	channel busy time:		11 ms
	channel receive time:		4 ms
	frequency:			2422 MHz
	noise:				-91 dBm
	channel busy time:		9 ms
	channel receive time:		8 ms
	frequency:			2427 MHz
	noise:				-92 dBm
	channel busy time:		14 ms
	channel receive time:		14 ms
	frequency:			2432 MHz
	noise:				-91 dBm
	channel busy time:		13 ms
	channel receive time:		10 ms
	frequency:			2437 MHz
	noise:				-92 dBm
	channel busy time:		17 ms
	channel receive time:		11 ms
	frequency:			2442 MHz
	noise:				-90 dBm
	channel receive time:		12 ms
	frequency:			2447 MHz
	noise:				-86 dBm
	channel active time:		124 ms
	channel busy time:		6 ms
	channel receive time:		5 ms
	frequency:			2452 MHz
	noise:				-91 dBm
	channel busy time:		1 ms
	channel receive time:		1 ms
	frequency:			2457 MHz
	noise:				-92 dBm
	channel active time:		113 ms
	channel busy time:		0 ms
	channel receive time:		0 ms
	frequency:			2462 MHz [in use]
	noise:				-92 dBm
	channel active time:		2928767292 ms
	channel busy time:		376578990 ms
	channel receive time:		329468320 ms
	channel BSS receive time:	1576421 ms
	channel transmit time:		44504450 ms
	frequency:			2467 MHz
	noise:				-91 dBm
	channel receive time:		3 ms
	frequency:			2472 MHz
	noise:				-91 dBm
	channel active time:		220 ms
	channel busy time:		5 ms
	frequency:			5180 MHz
	noise:				-92 dBm
	channel active time:		8571 ms
	frequency:			5200 MHz
	channel active time:		0 ms
	frequency:			5220 MHz
	frequency:			5240 MHz
	frequency:			5260 MHz
	frequency:			5280 MHz
	frequency:			5300 MHz
	frequency:			5320 MHz
	frequency:			5500 MHz
	frequency:			5520 MHz
	frequency:			5540 MHz
	frequency:			5560 MHz
	frequency:			5580 MHz
	frequency:			5600 MHz
	frequency:			5620 MHz
	frequency:			5640 MHz
	frequency:			5660 MHz
	frequency:			5680 MHz
	frequency:			5700 MHz
	frequency:			5720 MHz
	frequency:			5745 MHz [in use]
	noise:				-91 dBm
	channel active time:		2928766297 ms
	channel busy time:		16551130 ms
	channel receive time:		2034705 ms
	channel BSS receive time:	13155 ms
	channel transmit time:		14452095 ms
	frequency:			5765 MHz
	noise:				-92 dBm
	channel active time:		196 ms
	frequency:			5785 MHz
	frequency:			5805 MHz
	frequency:			5825 MHz
	frequency:			5955 MHz
	noise:				-92 dBm
	channel active time:		117 ms
	frequency:			5975 MHz
	noise:				-91 dBm
	channel active time:		111 ms
	channel busy time:		16 ms
	channel receive time:		16 ms
	frequency:			5995 MHz
	noise:				-91 dBm
	frequency:			6015 MHz
	noise:				-92 dBm
	frequency:			6035 MHz
	noise:				-92 dBm
	frequency:			6055 MHz
	noise:				-92 dBm
	frequency:			6075 MHz
	noise:				-92 dBm
	frequency:			6095 MHz
	noise:				-92 dBm
	frequency:			6115 MHz [in use]
	noise:				-89 dBm
	channel active time:		2928748276 ms
	channel busy time:		27326458 ms
	channel receive time:		13107069 ms
	channel BSS receive time:	9722533 ms
	channel transmit time:		13756701 ms
	frequency:			6135 MHz
	noise:				-92 dBm
	frequency:			6155 MHz
	noise:				-92 dBm
	channel active time:		122 ms
	frequency:			6175 MHz
	noise:				-92 dBm
	frequency:			6195 MHz
	noise:				-92 dBm
	frequency:			6215 MHz
	noise:				-92 dBm
	channel active time:		121 ms
	frequency:			6235 MHz
	noise:				-92 dBm
	frequency:			6255 MHz
	noise:				-92 dBm
	frequency:			6275 MHz
	noise:				-92 dBm
	frequency:			6295 MHz
	noise:				-92 dBm
	frequency:			6315 MHz
	noise:				-92 dBm
	frequency:			6335 MHz
	noise:				-92 dBm
	frequency:			6355 MHz
	noise:				-92 dBm
	channel active time:		112 ms
	frequency:			6375 MHz
	noise:				-92 dBm
	frequency:			6395 MHz
	noise:				-92 dBm
	frequency:			6415 MHz
	noise:				-92 dBm
	channel active time:		205 ms
