Hi, Just get BPI-R4 from Ali. Burn OpenWRT to sdcard and saw only this messages from UART.
Is that hardware malfunction or my curved hands?
Thanks.
Thanks.
it certainly looks like an HW issue … have you tried other non-openwrt builds ? … it may be an issue with openwrt snapshot (there were a few commits that changed u-boot)
U-boot doesn’t have anything to do with RAM detection.
same with ubuntu image.
Why new user?
Ram detection is done in atf (bl2). And because of the filogic is not supported by upstream atf,i guess all systems using code from mtk-atf.
I also guess it is a hardware issue. Have you changed anything on your board?
I’ve been waiting a long time for a confirmation email, and have signed up for my old mailbox ![]()
Didn’t change anything, just installed the fan, plugged in the BPI-R4-NIC-BE14 and set the sw4 to on.
I have something different.
DDR4 preloader -
NOTICE: EMI: Detected DRAM size: 0 MB
mt7988-DDR4.txt (102,3 КБ)
COMB preloader - booting, but unstable
NOTICE: EMI: Using DDR unknown settings
NOTICE: EMI: Detected DRAM size: 4096 MB
mt7988-COMB.txt (70,8 КБ)
UPDATE The fourth core is dead/unstable. So far, everything is fine without it.
+ cpus {
+ /delete-node/ cpu@3;
memory {
reg = <0x00 0x40000000 0x00 0x10000000>;
- &cpu3 {
- proc-supply = <&rt5190_buck3>;
