Banana Pi BPI-R4 cannot see QCA9880
Hi all! Today I received this long-awaited board and decided to immediately try it out, but the problem with the QCA9880 is not detected by the board in any way, lpci command does not write anything even though all the packages are installed. There is no mention of loading firmware in dmesg, please help! Firmware taken from openvrt snapshots, booted from sdcard.
It’s strange that my question remains unanswered for so long. Maybe this is because it is impossible to launch any other cards except the mediatek? Maybe then somewhere there is a list of recommended and compatible ones for this board?
17h are too long? I know that are issues with qca cards on bpi routers in past,no idea about r4
i also have 3 of those qualcom modules and an intel, none works. i use now a mediatek (mt76), that works. seems like there are some incompatibilities between the pins.
This is more a question of prestige, such things as support for boards from other manufacturers are very important and now I’m not speaking for myself, but I assume that similar questions from other enthusiasts will soon follow + your WiFi 7 board still cannot be purchased, but I really want it. Plus questions with support for SFP modules: none of the ones I have (Fiber Trade) worked.
You cannot expect that we have all hardware an can give a valid answer for all hardware…i can only talk about hardware i have…
Just to be clear, i’m no employee of bpi or mtk,i do all in my (limited) free time like some others (e.g. eric,daniel).
If you do not want to dig into these things a bit,just buy a ready to use product and no developer board.
I apologize if I unwittingly offended you with my message. I had no idea that you were an employee, there is simply no information collected in one place about supported hardware, release dates, etc.
I’m no employee here…as i said i answer and work on support/wiki in my freetime.
It is impossible to test all combinations of different hardware.
Realease-dates depend on multiple things…at least on test-results which needs software support.
Then you should post more information if nobody has a full answer…
For pci issues at least dmesg and lspci are a minimum.
As oli and me said there are issues with these atheros cards, we have no idea whats the cause for it.
And please be patient…there are only a few people here answering questions.
I installed AR9287 now - it works great.
Good day everyone! Can someone please tell me where to start looking for the problem?
root@BPI-R4:~# dmesg | grep ath10k
root@BPI-R4:~# dmesg | grep pci
[    0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[    0.018999] /soc/pcie@11280000: Fixed dependency cycle(s) with /soc/pcie@11280000/interrupt-controller
[    0.019098] /soc/pcie@11290000: Fixed dependency cycle(s) with /soc/pcie@11290000/interrupt-controller
[    0.019189] /soc/pcie@11300000: Fixed dependency cycle(s) with /soc/pcie@11300000/interrupt-controller
[    0.019281] /soc/pcie@11310000: Fixed dependency cycle(s) with /soc/pcie@11310000/interrupt-controller
[    0.076693] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    0.076708] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    0.076722] mtk-pcie-gen3 11280000.pcie:       IO 0x0020000000..0x00201fffff -> 0x0020000000
[    0.076736] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[    0.076833] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[    0.076844] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[    0.076855] mtk-pcie-gen3 11290000.pcie:       IO 0x0028000000..0x00281fffff -> 0x0028000000
[    0.076866] mtk-pcie-gen3 11290000.pcie:      MEM 0x0028200000..0x002fffffff -> 0x0028200000
[    0.076885] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[    0.076894] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[    0.076957] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[    0.076967] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[    0.076978] mtk-pcie-gen3 11300000.pcie:       IO 0x0030000000..0x00301fffff -> 0x0030000000
[    0.076987] mtk-pcie-gen3 11300000.pcie:      MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[    0.077004] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[    0.077012] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[    0.077085] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[    0.077095] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[    0.077105] mtk-pcie-gen3 11310000.pcie:       IO 0x0038000000..0x00381fffff -> 0x0038000000
[    0.077114] mtk-pcie-gen3 11310000.pcie:      MEM 0x0038200000..0x003fffffff -> 0x0038200000
[    0.077131] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[    0.077139] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[    1.959948] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    1.967277] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    1.973561] mtk-pcie-gen3 11280000.pcie:       IO 0x0020000000..0x00201fffff -> 0x0020000000
[    1.982009] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[    2.311446] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    2.320243] mtk-pcie-gen3 11280000.pcie: probe with driver mtk-pcie-gen3 failed with error -110
[    2.329266] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[    2.336579] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[    2.342850] mtk-pcie-gen3 11290000.pcie:       IO 0x0028000000..0x00281fffff -> 0x0028000000
[    2.351283] mtk-pcie-gen3 11290000.pcie:      MEM 0x0028200000..0x002fffffff -> 0x0028200000
[    2.671451] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    2.680232] mtk-pcie-gen3 11290000.pcie: probe with driver mtk-pcie-gen3 failed with error -110
[    2.689107] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[    2.696416] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[    2.702683] mtk-pcie-gen3 11300000.pcie:       IO 0x0030000000..0x00301fffff -> 0x0030000000
[    2.711113] mtk-pcie-gen3 11300000.pcie:      MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[    3.031445] mtk-pcie-gen3 11300000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    3.040224] mtk-pcie-gen3 11300000.pcie: probe with driver mtk-pcie-gen3 failed with error -110
[    3.049070] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[    3.056379] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[    3.062644] mtk-pcie-gen3 11310000.pcie:       IO 0x0038000000..0x00381fffff -> 0x0038000000
[    3.071073] mtk-pcie-gen3 11310000.pcie:      MEM 0x0038200000..0x003fffffff -> 0x0038200000
[    3.391438] mtk-pcie-gen3 11310000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    3.400217] mtk-pcie-gen3 11310000.pcie: probe with driver mtk-pcie-gen3 failed with error -110
root@BPI-R4:~# dmesg | grep clk
[    0.076101] mtk-xsphy soc:xs-phy@11e10000: failed to get ref_clk(id-1)
[    3.934685] clk: Disabling unused clocks
Edit: moderated: please use code tags
