[Banana Pi BPI-R4] Can you plan a wired expansion module with one 10G and four 2.5G
Can you plan a wired expansion module with one 10G and four 2.5G? BPI-R4 It only needs to be responsible for wired connections.
Then buy nice 10gig plus 2.5 gig switch?
4 2.5G ports? Then SinoVoip needs to add a switch chip and increase the price by $30, are you willing to pay for that?
One 10g, four 2.5s, no hesitation worth it
Anyway, it’s worth it After all, switches with 10G interfaces are more than just that price
We have discussed the feasibility of four 2.5G with MTK,and MTK is currently verifying it, but it will take some time.
There are also many 2xSFP+ with four 2.5G switches on the market now, such as TPlink, which can be added to R4 with fibre or DAC cable.
Ordered this one some time ago for 38€ (black week)
https://de.aliexpress.com/item/1005005992916169.html
But have not done much tests as i need more than one 2g5 client and 10g support on R4 (rss/lro).
Die 2x2L Schnittstelle sollte ausreichen, um gleichzeitig einen 10G Netzwerkport und vier 2,5G Netzwerkports zu erweitern
I have one just like this but different brand, with heave load over 10 gig and aome of 2.5gig port it just works, tested it with 10 and 25 gig dac/fibers and all good. Hope next bpi r5 or 6 wilnhave 25gig ports and nice mediatek cpu with npu.
No I disagree. An 8 port 2.5G with one 10G uplink should be less than $50 using Realtek chip. A 4 port 2.5G should be less than $30. Charging you more than that is ripping you off.
Anyway, these are the prices for a “dumb” switch. If you need managed switch using ip suite commands, then that is non-existent right now. I don’t even know anyone makes multigigabit switches with DSA capabilities. Probably Marvell Link Street will be the first.
MaxLinear has a 8 port 2.5G + two 10G managed switch chip, but that is $80 I believe. I don’t even know how the host CPU would control this chip.
I am more curious as to when any of these CPUs would have multigigabit crypto performance. Dual 8Gbps is the maximum home Internet I could get from two ISPs, one’s PON line supports up to 40Gbps though.
RK3588 should be able to handle 4 x 2.5G. The M7 is a good start with 2 x 2.5 G. Then just add an ASM2812 with a few more RTL8125 or I-226.
The problem there is we need to manually patch the Realtek driver to support multi-queue or use the more expensive I-226. The last time I tested it, RK3568, r2-pro could do full 2.35G routing, only using 2 cores full and other 2 cores around 33%.
It’s pretty easy to find a mini-pcie adapter having 2 2.5g ports, if you buy 2 of them, don’t you have exactly what you need?
EDIT: this is how it shows on my bpi-r64, underperforming because it’s limited to the board’s pcie 1.1 interface:
0000:01:00.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
0000:02:03.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
0000:02:07.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
0000:03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 04)
0000:04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 04)
