There should be thermal pads shipped with the BE14 which connects it to the case. So the case is like a big heat sink.
just got today the be14 (thermal pads included) using frankâs debian 6.10-main branch on the assumption that the âtestâ firmware was included
dmesg | grep mt7996
[ 16.042496] mt7996e_hif 0001:01:00.0: vgaarb: pci_notify
[ 16.047873] mt7996e_hif 0001:01:00.0: assign IRQ: got 122
[ 16.053275] mt7996e_hif 0001:01:00.0: enabling device (0000 -> 0002)
[ 16.059673] mt7996e_hif 0001:01:00.0: enabling bus mastering
[ 16.065351] mt7996e_hif 0001:01:00.0: vgaarb: pci_notify
[ 16.070791] mt7996e 0000:01:00.0: vgaarb: pci_notify
[ 16.075800] mt7996e 0000:01:00.0: assign IRQ: got 119
[ 16.080854] mt7996e 0000:01:00.0: enabling device (0000 -> 0002)
[ 16.086902] mt7996e 0000:01:00.0: enabling bus mastering
[ 16.268599] mt7996e 0000:01:00.0: Direct firmware load for mediatek/mt7996/mt7996_rom_patch_233.bin failed with error -2
[ 16.279513] mt7996e 0000:01:00.0: Falling back to sysfs fallback for: mediatek/mt7996/mt7996_rom_patch_233.bin
[ 79.875329] mt7996e 0000:01:00.0: probe with driver mt7996e failed with error -110
[ 79.882915] mt7996e 0000:01:00.0: vgaarb: pci_notify
Where is the test firmware located ? any link out there ?
i used the firmware files from linux-firmware but obviously these donât work same with openwrt/mt76
sorry just found them on frankâs repo - under BPI-Router-Linux/utils/firmware/mediatek/mt7996
But you have to copy firmware file manually to your rootfsâŠit is not builtin in itb
EditâŠ6.10-main also contains the mt76 patch and firmware,but you need to manually copy firmware files to rootfs
yes did that thank you for your prompt reply ![]()
Since Mediatek released a new version of their (ancient) OpenWRT fork https://git01.mediatek.com/plugins/gitiles/openwrt/feeds/mtk-openwrt-feeds/+/refs/heads/master/autobuild/autobuild_5.4_mac80211_release/Release.md which no longer relies on the proprietary MT76 Programming Guide v4.0 (aka the SinoVoip image), I tried the included new firmware version but unfortunately it still does not show the correct 320MHz NSS etc.
Building and running the image, however, does show that it works correctly with the same firmware but their mt76 patches, any chance there are patches missing (not sure how much your 6.10-main already includes in terms of patches)?
root@OpenWrt:/# iw list
Wiphy phy2
wiphy index: 2
max # scan SSIDs: 4
max scan IEs length: 2177 bytes
max # sched scan SSIDs: 0
max # match sets: 0
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports RSN-IBSS.
Device supports AP-side u-APSD.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
* CCMP-256 (00-0f-ac:10)
* GCMP-128 (00-0f-ac:8)
* GCMP-256 (00-0f-ac:9)
* CMAC (00-0f-ac:6)
* CMAC-256 (00-0f-ac:13)
* GMAC-128 (00-0f-ac:11)
* GMAC-256 (00-0f-ac:12)
Available Antennas:
6G band: TX 0x7 RX 0x7
Configured Antennas:
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
* P2P-client
* P2P-GO
Band 4:
HE Iftypes: managed
HE MAC Capabilities (0x08011a000040):
+HTC HE Supported
Trigger Frame MAC Padding Duration: 2
OM Control
Maximum A-MPDU Length Exponent: 3
A-MSDU in A-MPDU
HE PHY Capabilities: (0x4c70ce926d12f3164e3f00):
HE40/HE80/5GHz
HE160/5GHz
242 tone RUs/5GHz
Device Class: 1
LDPC Coding in Payload
HE SU PPDU with 1x HE-LTF and 0.8us GI
NDP with 4x HE-LTF and 3.2us GI
STBC Tx <= 80MHz
STBC Rx <= 80MHz
Full Bandwidth UL MU-MIMO
Partial Bandwidth UL MU-MIMO
DCM Max Constellation: 2
DCM Max Constellation Rx: 2
SU Beamformer
SU Beamformee
Beamformee STS <= 80Mhz: 3
Beamformee STS > 80Mhz: 3
Sounding Dimensions <= 80Mhz: 2
Sounding Dimensions > 80Mhz: 2
Codebook Size SU Feedback
Codebook Size MU Feedback
Triggered CQI Feedback
Partial Bandwidth Extended Range
Partial Bandwidth DL MU-MIMO
PPE Threshold Present
Power Boost Factor ar
HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
Max NC: 2
20MHz in 40MHz HE PPDU 2.4GHz
20MHz in 160/80+80MHz HE PPDU
80MHz in 160/80+80MHz HE PPDU
DCM Max BW: 1
Longer Than 16HE SIG-B OFDM Symbols
Non-Triggered CQI Feedback
TX 1024-QAM
RX 1024-QAM
RX Full BW SU Using HE MU PPDU with Compression SIGB
RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
HE RX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
HE TX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
HE RX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
HE TX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
PPE Threshold 0x3a 0x1c 0xc7 0x71 0x1c 0xc7 0x71 0x1c
EHT Iftypes: managed
EHT MAC Capabilities (0x8200):
EHT OM Control Supported
EHT PHY Capabilities: (0xea6d921e20600c00):
320MHz in 6GHz Supported
NDP With EHT-LTF And 3.2 Ôs GI
SU Beamformer
SU Beamformee
Beamformee SS (80MHz): 3
Beamformee SS (160MHz): 3
Beamformee SS (320MHz): 3
Number Of Sounding Dimensions (80MHz): 2
Number Of Sounding Dimensions (160MHz): 2
Number Of Sounding Dimensions (320MHz): 2
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Codebook size (4, 2) SU Feedback
Codebook size (7, 5) MU Feedback
Max Nc: 2
Common Nominal Packet Padding: 2
Maximum Number Of Supported EHT-LTFs: 17
Support of MCS 15: 1
EHT MCS/NSS: (0x33333333333333333300000000):
EHT bw <= 80 MHz, max NSS for MCS 8-9: Rx=3, Tx=3
EHT bw <= 80 MHz, max NSS for MCS 10-11: Rx=3, Tx=3
EHT bw <= 80 MHz, max NSS for MCS 12-13: Rx=3, Tx=3
EHT bw=160 MHz, max NSS for MCS 8-9: Rx=3, Tx=3
EHT bw=160 MHz, max NSS for MCS 10-11: Rx=3, Tx=3
EHT bw=160 MHz, max NSS for MCS 12-13: Rx=3, Tx=3
EHT bw=320 MHz, max NSS for MCS 8-9: Rx=3, Tx=3
EHT bw=320 MHz, max NSS for MCS 10-11: Rx=3, Tx=3
EHT bw=320 MHz, max NSS for MCS 12-13: Rx=3, Tx=3
HE Iftypes: AP
HE MAC Capabilities (0x00051a081044):
+HTC HE Supported
TWT Responder
BSR
OM Control
BQR
A-MSDU in A-MPDU
OM Control UL MU Data Disable RX
HE PHY Capabilities: (0x0c20ce926f12afd0000c00):
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
MU Beamformer
Triggered SU Beamforming Feedback
Triggered MU Beamforming Feedback
Max NC: 2
STBC Tx > 80MHz
STBC Rx > 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
EHT Iftypes: AP
EHT MAC Capabilities (0xa200):
EHT PHY Capabilities: (0xea6d927e20600c7e):
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Triggered MU Beamforming Partial BW Feedback
Max Nc: 2
Non-OFDMA UL MU-MIMO (80MHz)
Non-OFDMA UL MU-MIMO (160MHz)
Non-OFDMA UL MU-MIMO (320MHz)
MU Beamformer (80MHz)
MU Beamformer (160MHz)
MU Beamformer (320MHz)
HE Iftypes: mesh point
HE MAC Capabilities (0x00011a000040):
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE PHY Capabilities: (0x0c200c0000000000008000):
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
EHT Iftypes: mesh point
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5955.0 MHz [1] (12.0 dBm)
* 5975.0 MHz [5] (12.0 dBm)
* 5995.0 MHz [9] (12.0 dBm)
* 6015.0 MHz [13] (12.0 dBm)
* 6035.0 MHz [17] (12.0 dBm)
* 6055.0 MHz [21] (12.0 dBm)
* 6075.0 MHz [25] (12.0 dBm)
* 6095.0 MHz [29] (12.0 dBm)
* 6115.0 MHz [33] (12.0 dBm)
* 6135.0 MHz [37] (12.0 dBm)
* 6155.0 MHz [41] (12.0 dBm)
* 6175.0 MHz [45] (12.0 dBm)
* 6195.0 MHz [49] (12.0 dBm)
* 6215.0 MHz [53] (12.0 dBm)
* 6235.0 MHz [57] (12.0 dBm)
* 6255.0 MHz [61] (12.0 dBm)
* 6275.0 MHz [65] (12.0 dBm)
* 6295.0 MHz [69] (12.0 dBm)
* 6315.0 MHz [73] (12.0 dBm)
* 6335.0 MHz [77] (12.0 dBm)
* 6355.0 MHz [81] (12.0 dBm)
* 6375.0 MHz [85] (12.0 dBm)
* 6395.0 MHz [89] (12.0 dBm)
* 6415.0 MHz [93] (12.0 dBm)
* 6435.0 MHz [97] (12.0 dBm)
* 6455.0 MHz [101] (12.0 dBm)
* 6475.0 MHz [105] (12.0 dBm)
* 6495.0 MHz [109] (12.0 dBm)
* 6515.0 MHz [113] (12.0 dBm)
* 6535.0 MHz [117] (12.0 dBm)
* 6555.0 MHz [121] (12.0 dBm)
* 6575.0 MHz [125] (12.0 dBm)
* 6595.0 MHz [129] (12.0 dBm)
* 6615.0 MHz [133] (12.0 dBm)
* 6635.0 MHz [137] (12.0 dBm)
* 6655.0 MHz [141] (12.0 dBm)
* 6675.0 MHz [145] (12.0 dBm)
* 6695.0 MHz [149] (12.0 dBm)
* 6715.0 MHz [153] (12.0 dBm)
* 6735.0 MHz [157] (12.0 dBm)
* 6755.0 MHz [161] (12.0 dBm)
* 6775.0 MHz [165] (12.0 dBm)
* 6795.0 MHz [169] (12.0 dBm)
* 6815.0 MHz [173] (12.0 dBm)
* 6835.0 MHz [177] (12.0 dBm)
* 6855.0 MHz [181] (12.0 dBm)
* 6875.0 MHz [185] (12.0 dBm)
* 6895.0 MHz [189] (12.0 dBm)
* 6915.0 MHz [193] (12.0 dBm)
* 6935.0 MHz [197] (12.0 dBm)
* 6955.0 MHz [201] (12.0 dBm)
* 6975.0 MHz [205] (12.0 dBm)
* 6995.0 MHz [209] (12.0 dBm)
* 7015.0 MHz [213] (12.0 dBm)
* 7035.0 MHz [217] (12.0 dBm)
* 7055.0 MHz [221] (12.0 dBm)
* 7075.0 MHz [225] (12.0 dBm)
* 7095.0 MHz [229] (12.0 dBm)
* 7115.0 MHz [233] (12.0 dBm)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* set_tx_bitrate_mask
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* tdls_mgmt
* tdls_oper
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* testmode
* connect
* disconnect
* channel_switch
* set_qos_map
* set_multicast_to_unicast
* set_sar_specs
software interface modes (can always be added):
* AP/VLAN
* monitor
valid interface combinations:
* #{ IBSS } <= 1, #{ AP, mesh point } <= 48, #{ managed } <= 57,
total <= 57, #channels <= 3, STA/AP BI must match, radar detect widths: { 20 MHz (no HT), 20 MHz, 40 MHz, 80 MHz, 160 MHz }
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Device supports TX status socket option.
Device supports HT-IBSS.
Device supports SAE with AUTHENTICATE command
Device supports scan flush.
Device supports per-vif TX power setting
Driver supports full state transitions for AP/GO clients
Driver supports a userspace MPM
Device supports active monitor (which will ACK incoming frames)
Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
Device supports configuring vdev MAC-addr on create.
max # scan plans: 1
max scan plan interval: -1
max scan plan iterations: 0
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0x40 0xb0 0xc0 0xd0
* managed: 0x40 0xb0 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* mesh point: 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-device: 0x40 0xd0
Supported extended features:
* [ VHT_IBSS ]: VHT-IBSS
* [ RRM ]: RRM
* [ MU_MIMO_AIR_SNIFFER ]: MU-MIMO sniffer
* [ BEACON_RATE_LEGACY ]: legacy beacon rate setting
* [ BEACON_RATE_HT ]: HT beacon rate setting
* [ BEACON_RATE_VHT ]: VHT beacon rate setting
* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
* [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records
* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
* [ ACK_SIGNAL_SUPPORT ]: ack signal level support
* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
* [ CAN_REPLACE_PTK0 ]: can safely replace PTK 0 when rekeying
* [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
* [ AQL ]: Airtime Queue Limits (AQL)
* [ BEACON_PROTECTION ]: beacon protection support
* [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
* [ DEL_IBSS_STA ]: deletion of IBSS station support
* [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
* [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
* [ OPERATING_CHANNEL_VALIDATION ]: Operating Channel Validation (OCV) support
* [ FILS_DISCOVERY ]: FILS discovery frame transmission support
* [ UNSOL_BCAST_PROBE_RESP ]: unsolicated broadcast probe response transmission support
* [ BEACON_RATE_HE ]: HE beacon rate support (AP/mesh)
* [ BSS_COLOR ]: BSS coloring support
* [ POWERED_ADDR_CHANGE ]: can change MAC address while up
* [ PUNCT ]: preamble puncturing in AP mode
Wiphy phy1
wiphy index: 1
max # scan SSIDs: 4
max scan IEs length: 2135 bytes
max # match sets: 0
Retry long limit: 4
Supported Ciphers:
* TKIP (00-0f-ac:2)
* CMAC (00-0f-ac:6)
Available Antennas:
5G band: TX 0x7 RX 0x7
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
* P2P-client
* P2P-GO
Band 2:
Capabilities: 0x9ff
RX LDPC
HT20/HT40
SM Power Save disabled
RX Greenfield
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 7935 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 1 usec (0x03)
HT TX/RX MCS rate indexes supported: 0-23
VHT Capabilities (0x339a79f6):
Max MPDU length: 11454
Supported Channel Width: 160 MHz
RX LDPC
short GI (80 MHz)
short GI (160/80+80 MHz)
TX STBC
SU Beamformer
SU Beamformee
MU Beamformer
MU Beamformee
RX antenna pattern consistency
TX antenna pattern consistency
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: MCS 0-9
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
VHT extended NSS: supported
HE Iftypes: managed
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
242 tone RUs/5GHz
Device Class: 1
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
Max NC: 2
DCM Max BW: 1
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
EHT PHY Capabilities: (0xe80d121e20600c00):
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
EHT MCS/NSS: (0x33333333333300000000000000):
HE Iftypes: AP
+HTC HE Supported
TWT Responder
BSR
OM Control
BQR
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
MU Beamformer
Max NC: 2
STBC Tx > 80MHz
STBC Rx > 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
EHT Iftypes: AP
EHT PHY Capabilities: (0xe80d127e20600c36):
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5180.0 MHz [36] (20.0 dBm)
* 5200.0 MHz [40] (20.0 dBm)
* 5220.0 MHz [44] (20.0 dBm)
* 5240.0 MHz [48] (20.0 dBm)
* 5260.0 MHz [52] (20.0 dBm) (no IR, radar detection)
* 5280.0 MHz [56] (20.0 dBm) (no IR, radar detection)
* 5300.0 MHz [60] (20.0 dBm) (no IR, radar detection)
* 5320.0 MHz [64] (20.0 dBm) (no IR, radar detection)
* 5340.0 MHz [68] (disabled)
* 5360.0 MHz [72] (disabled)
* 5380.0 MHz [76] (disabled)
* 5400.0 MHz [80] (disabled)
* 5420.0 MHz [84] (disabled)
* 5440.0 MHz [88] (disabled)
* 5460.0 MHz [92] (disabled)
* 5480.0 MHz [96] (disabled)
* 5500.0 MHz [100] (20.0 dBm) (no IR, radar detection)
* 5520.0 MHz [104] (20.0 dBm) (no IR, radar detection)
* 5540.0 MHz [108] (20.0 dBm) (no IR, radar detection)
* 5560.0 MHz [112] (20.0 dBm) (no IR, radar detection)
* 5580.0 MHz [116] (20.0 dBm) (no IR, radar detection)
* 5600.0 MHz [120] (20.0 dBm) (no IR, radar detection)
* 5620.0 MHz [124] (20.0 dBm) (no IR, radar detection)
* 5640.0 MHz [128] (20.0 dBm) (no IR, radar detection)
* 5660.0 MHz [132] (20.0 dBm) (no IR, radar detection)
* 5680.0 MHz [136] (20.0 dBm) (no IR, radar detection)
* 5700.0 MHz [140] (20.0 dBm) (no IR, radar detection)
* 5720.0 MHz [144] (20.0 dBm) (no IR, radar detection)
* 5745.0 MHz [149] (20.0 dBm) (no IR)
* 5765.0 MHz [153] (20.0 dBm) (no IR)
* 5785.0 MHz [157] (20.0 dBm) (no IR)
* 5805.0 MHz [161] (20.0 dBm) (no IR)
* 5825.0 MHz [165] (20.0 dBm) (no IR)
* 5845.0 MHz [169] (20.0 dBm) (no IR)
* 5865.0 MHz [173] (20.0 dBm) (no IR)
* 5885.0 MHz [177] (20.0 dBm) (no IR)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* tdls_mgmt
* tdls_oper
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* testmode
* connect
* disconnect
* channel_switch
* set_qos_map
* set_sar_specs
* AP/VLAN
* monitor
max # scan plans: 1
* [ RRM ]: RRM
Had to split the iw list ^^
Wiphy phy0
wiphy index: 0
max # scan SSIDs: 4
max scan IEs length: 2145 bytes
max # match sets: 0
Retry long limit: 4
Supported Ciphers:
* TKIP (00-0f-ac:2)
* CMAC (00-0f-ac:6)
Available Antennas:
2G band: TX 0x3 RX 0x3
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
* P2P-client
* P2P-GO
Band 1:
Capabilities: 0x9ff
RX LDPC
HT20/HT40
RX Greenfield
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
Minimum RX AMPDU time spacing: 2 usec (0x04)
HT TX/RX MCS rate indexes supported: 0-15
HE Iftypes: managed
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE PHY Capabilities: (0x2270ce926d09f30e4e3f00):
HE40/2.4GHz
242 tone RUs/2.4GHz
Device Class: 1
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
Sounding Dimensions <= 80Mhz: 1
Sounding Dimensions > 80Mhz: 1
Max NC: 1
DCM Max BW: 1
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: not supported
1 streams: MCS 0-11
2 streams: MCS 0-11
PPE Threshold 0x39 0x1c 0xc7 0x71 0x1c 0x07
EHT PHY Capabilities: (0xe80d091e10600c00):
SU Beamformer
SU Beamformee
Number Of Sounding Dimensions (80MHz): 1
Number Of Sounding Dimensions (160MHz): 1
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 1
EHT MCS/NSS: (0x22222200000000000000000000):
EHT bw=20 MHz, max NSS for MCS 0-7: Rx=2, Tx=2
EHT bw=20 MHz, max NSS for MCS 8-9: Rx=2, Tx=2
EHT bw=20 MHz, max NSS for MCS 10-11: Rx=2, Tx=2
EHT bw=20 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
HE Iftypes: AP
+HTC HE Supported
TWT Responder
BSR
OM Control
BQR
A-MSDU in A-MPDU
HE PHY Capabilities: (0x0220ce926f09afc8000c00):
HE40/2.4GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
MU Beamformer
Max NC: 1
STBC Tx > 80MHz
STBC Rx > 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
EHT Iftypes: AP
EHT PHY Capabilities: (0xe80d097e10600c36):
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 1
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE PHY Capabilities: (0x02200c0000000000008000):
HE40/2.4GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 1
Bitrates (non-HT):
* 1.0 Mbps (short preamble supported)
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412.0 MHz [1] (20.0 dBm)
* 2417.0 MHz [2] (20.0 dBm)
* 2422.0 MHz [3] (20.0 dBm)
* 2427.0 MHz [4] (20.0 dBm)
* 2432.0 MHz [5] (20.0 dBm)
* 2437.0 MHz [6] (20.0 dBm)
* 2442.0 MHz [7] (20.0 dBm)
* 2447.0 MHz [8] (20.0 dBm)
* 2452.0 MHz [9] (20.0 dBm)
* 2457.0 MHz [10] (20.0 dBm)
* 2462.0 MHz [11] (20.0 dBm)
* 2467.0 MHz [12] (20.0 dBm) (no IR)
* 2472.0 MHz [13] (20.0 dBm) (no IR)
* 2484.0 MHz [14] (20.0 dBm) (no IR)
Band 2:
Capabilities: 0x9ff
RX LDPC
HT20/HT40
RX Greenfield
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
RX LDPC
short GI (80 MHz)
TX STBC
SU Beamformer
SU Beamformee
MU Beamformer
MU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: MCS 0-9
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: MCS 0-9
HE Iftypes: managed
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
242 tone RUs/5GHz
Device Class: 1
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
Max NC: 2
DCM Max BW: 1
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
HE Iftypes: AP
+HTC HE Supported
TWT Responder
BSR
OM Control
BQR
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
MU Beamformer
Max NC: 2
STBC Tx > 80MHz
STBC Rx > 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
EHT Iftypes: AP
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
Band 4:
HE Iftypes: managed
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
242 tone RUs/5GHz
Device Class: 1
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
Max NC: 2
DCM Max BW: 1
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
HE Iftypes: AP
+HTC HE Supported
TWT Responder
BSR
OM Control
BQR
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
MU Beamformer
Max NC: 2
STBC Tx > 80MHz
STBC Rx > 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
EHT Iftypes: AP
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: MCS 0-11
SU Beamformer
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Max Nc: 2
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* tdls_mgmt
* tdls_oper
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* testmode
* connect
* disconnect
* channel_switch
* set_qos_map
* set_sar_specs
* AP/VLAN
* monitor
max # scan plans: 1
* [ RRM ]: RRM
i compiled the main branch of hostapd in order to test wifi7/be however I noticed that regdomain always defaults country 98! in spite of having country setup on the conf file or even forcing with iw ⊠canât use BE all others work but still country 98! has anyone seen this behavior? thank you
Maybe try setting the regdom for the cfg80211 kernel module. Just write the setting in /etc/modprobe.d/wifi.conf or other file in that dir, for example:
options cfg80211 ieee80211_regdom=COUNTRY_INITIALS_HERE
yes that is done ⊠I am using the default that comes with Frankâs build of DE ⊠but also tried changing to US, TW etc and doesnât take effect⊠systool -vm shows DE
I suspect this a firmware issue but being new with the bpi-r4 and seeing that there are already people using mt7996 / be14 board thought to ask.
Have you tried changing this?
Change there and remove module option I guess.
And then no use to check with systoolâŠ
i let my pipeline build an bookwork image with kernel 6.10 including the be14 patch and testing-firmware
would be great if anyone can test and report back
@schuschu any response from mtk yet? have not seen one, but maybe they answered only youâŠ
have you looked which firmware is loaded? afair the sdk worked because they use kernel 5.4 and havily patched mt76 to get their firmware workingâŠthe problem was getting the interfaces up with mainline mt76 and only small patch ![]()
let me try it ⊠in terms of upgrading an existing sdcard can I just use the deb packages to upgrade ?
I made it work with 2.4g/5gâŠthe issue is BE although I am using the main branch of hostapd that should support it perhaps there are still improvements on the mt76 code.
i have not done any upgrading mechanism yet as my image can be updated step by step (upgrading debian by apt, updating kernel by build.sh, but firmware has to be copied manually)
if you have not yet done much changes just reflash the new imageâŠyou need to do same changes again after flashâŠor just copy kernel (BPI-BOOT/bpi-r4.itb),modules (BPI-ROOT/lib/modules) and firmware (BPI-ROOT/lib/firmware/mediatek/mt7996)
sadly nothing but since the same firmware for the card only shows the issue with the mainline kernel and not with their current sdk (sure its kernel 5.4 not 6.10 and the tool versions are likely different but I think the mt76 is a backport of a fairly recent version), I would assume that some of their patches (say autobuild/autobuild_5.4_mac80211_release/mt7988_wifi7_mac80211_mlo/package/kernel/mt76/patches/0004-mtk-mt76-mt7996-fix-HE-and-EHT-phy-cap.patch - openwrt/feeds/mtk-openwrt-feeds - Gitiles which claims to fix the EHT capabilities of the card) might be the solution, not the firmware.
The question is, what is easier, compile their version of mt76 against our kernel or try if the patches still apply to mainline I donât want to try to cherry pick 199 patches if there is a way to avoid it though.
Do you have any patches applied of your own or how do you usually handle this?
The use nearly mainline mt76 but with a bunch of patches changing the internal data structure,but you can try porting the fix youâve found to my 6.10-main tree and test again
edit: seems no porting neededâŠi could apply the patch directly, pushed branch
will the linux kernel used in your image builder be updated automatically once CI has passed?
EDIT: is your gdrive pipeline automatic/public or only individual images?
Hello, Iâm trying to test this last image, but I donât have access through luci, I donât have internet through sfp+rj45 or through 1gb wan, I canât access through ssh either, I donât know the password.
I have everything set up above and the wifi 7 module that arrived yesterday, could you tell me an image that I can access through luci, with wifi 7 module, sfp+rj45, and the access password.
The images I have tried have access through luci, internet through sfp+rj45 and through the 1gb wan, but the wifi 7 module doesnât appear, and I canât create wifi interface.
I hope for your help
the image is not rebuilt automatcly when kernel-ci passedâŠit has to be started by me manually, or you just build yourselfâŠor replace kernel on your existing sdcardâŠit is only unpacking ![]()
@Francisco debian has no luciâŠit is accessable only through ssh/uart, see configs for IP-adresses
- wan (dhcp): BPI-Router-Images/conf/generic/etc/systemd/network/15-wan.network at gdrive-test · frank-w/BPI-Router-Images · GitHub
- lanbr0: BPI-Router-Images/conf/generic/etc/systemd/network/25-lanbr.network at gdrive-test · frank-w/BPI-Router-Images · GitHub
edit: updated the image with the HT patch
Debian have webmin but i think there is no plugins for wifi config, firewall is there for sure.
