I am truly frustrated. I was trying to upgrade from 23 to 24.10 of OpenWrt. I couldn’t use auc because of the bootloader being out of date. So I ended up flashing a new SD card with 24.10.0 and connecting in on the UART and flashed the SD card image into the NAND using the bootloader. Then booted in NAND and flashed emmc in the bootloader menu. I then re applied my saved configuration from 23. I attempted to run the upgrade to see if I could upgrade in the future with owut using this command.
owut upgrade
I got the following
root@home:/# owut upgrade ASU-Server https://sysupgrade.openwrt.org Upstream https://downloads.openwrt.org Target mediatek/filogic Profile bananapi_bpi-r3 Package-arch aarch64_cortex-a53 Version-from 24.10.0 r28427-6df0e3d02a (kernel 6.6.73) Version-to 24.10.0 r28427-6df0e3d02a (kernel 6.6.73) 19 packages are out-of-date Request hash: 961583e0f933423b806e0d8ff8bb9c851e4e30c6875588f17e520255c18927da
Status: done Progress: 0s total = 0s in queue + 0s in build
Build succeeded in 0s total = 0s in queue + 0s to build: Image saved : /tmp/firmware.bin ERROR: sysupgrade validation failed: stderr = Sat Mar 29 16:46:27 CDT 2025 upgrade: The device is supported, but the config is incompatible to the new image (1.1->1.2). Please upgrade without keeping config (sysupgrade -n). Sat Mar 29 16:46:27 CDT 2025 upgrade: SPI-NAND flash layout changes require bootloader update Image check failed.
So originally, when I tried to upgrade with auc I got the same error. Now after i have updated to 24.10.0 I am getting this same error message. I don’t know what to do to fix this upgrade error in owut. Everything I read about the bootloader says that the new 24.10.0 image I pulled from firmware.openwrt.org and applied through the SD card should have fixed the bootloader error. Any ideas what I do next?
