I was running openwrt from sdcard using autopart and it works fine.
Than I started to use eMMC and uvol can´t create a volume.
Looks like it´s trying to create the volume on NAND.
Is it possible to target mmcblk0 instead of mtdblock0 on uvol ?
# uvol create storage 3000000000 rw
ubimkvol: error!: UBI device does not have free logical eraseblocks
# uvol total
124436480
# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mtdblock0 31:0 0 122.5M 0 disk
mtdblock1 31:1 0 2M 1 disk
mtdblock2 31:2 0 3M 0 disk
mtdblock3 31:3 0 512K 1 disk
mmcblk0 179:0 0 7.3G 0 disk
|-mmcblk0p1 179:1 0 4M 0 part
|-mmcblk0p2 179:2 0 512K 0 part
|-mmcblk0p3 179:3 0 2M 0 part
|-mmcblk0p4 179:4 0 4M 0 part
|-mmcblk0p5 179:5 0 32M 0 part
|-mmcblk0p6 179:6 0 20M 0 part
|-mmcblk0p7 179:7 0 104M 0 part
|-mmcblk0p65 259:0 0 33.4M 1 part /rom
`-mmcblk0p66 259:1 0 65.4M 0 part /overlay
mmcblk0boot0 179:8 0 4M 1 disk
mmcblk0boot1 179:16 0 4M 1 disk
ubiblock0_2 254:0 0 10.3M 0 disk
`-ubiblock0_2p1 259:2 0 5M 1 part
Strange, it looks like autopart didn’t create the partition for the LVM2 physical volume. Maybe this was due to
Can you try with a more recent snapshot which includes this change (ie. version of uvol and autopart should be 0.9)?
If that doesn’t help, I would like to debug why autopart doesn’t work for you.
Once autopart succeeds uvol will then automatically use the LVM2 backend once it becomes available.
Hi @ned14, can you tell me which Openwrt Image version you use to get your fibre SFP devices working? I’m currently using latest Openwrt Snapshot and I’m not able to get my Optical Transceiver Modules working.
I can confirm that the fibre modules reported receiving packets, and moreover, the count of packets sent by one exactly equalled the count of packets received by the other.
Mine are < 1w modules with only a 2km range, so your issues could be simply due to insufficient power? I agree it seems weird yours can transmit and not receive if it were insufficient power. I hope you figure it out.
Relatedly, besides this topic, is there anywhere that documents what the LEDs mean?
I typically get a red power LED followed by solid then blinking green as OpenWRT starts up, but this morning I was seeing the red power LED followed by solid blue and the green LED was off. The device responded to pings but it didn’t appear any of the services were started.
I haven’t looked at debug UART, but is there any obvious meaning to the blue LED during startup?
blue LED on startup means the device has started the recovery image. This happens (intentionally) in case there has been a kernel crash. Check /sys/fs/pstore for details.
root@OpenWrt:/mnt/sda1# ls
System Volume Information openwrt-mediatek-filogic-bananapi_bpi-r3-nor-preloader.bin
openwrt-mediatek-filogic-bananapi_bpi-r3-initramfs-recovery.itb openwrt-mediatek-filogic-bananapi_bpi-r3-squashfs-sysupgrade.itb
openwrt-mediatek-filogic-bananapi_bpi-r3-nor-bl31-uboot.fip
root@OpenWrt:/mnt/sda1# modprobe mtd-rw i_want_a_brick=1
failed to find a module named mtd-rw
root@OpenWrt:/mnt/sda1# mtd write openwrt-mediatek-filogic-bananapi_bpi-r3-nor-preloader.bin bl2
Could not open mtd device: bl2
Can't open device for writing!
Thank you for my firmware lack of many dependency packages, how to use the serial port to brush openwrt official firmware
root@OpenWrt:~# opkg install mmc-utils kmod-mtd-rw
Package mmc-utils (2019-10-10-73d6c59a-2) installed in root is up to date.
Unknown package ‘kmod-mtd-rw’.
Collected errors:
As you have the serial port connected, why don’t you just use the bootloader menu to install to whatever bootmedia you like?
Edit: Now I understand The version of mmc-utils was a clear hint that this is impossibly official OpenWrt you are currently running – it’s from 2019 and hence you must be running SinoVoip’s build of MediaTek SDK and not really OpenWrt.
To start using the real OpenWrt, please follow the instructions further up in this thread: Banana Pi BPI-R3 OpenWRT image
For the initial installation you will need a microSD card and use that microSD to boot the R3. As you have the serial port connected you can then use the bootloader menu to install OpenWrt to NAND or NOR, and when booting from NAND you can install to eMMC (you cannot install directly from microSD to eMMC as they cannot be accessed at the same time).
