@spikerguy @igorpec
Ok, lima does work, on the armbian kernel. Tested with kmscube and weston-launch.
@igorpec, I have a strange bluetooth issue. I can’t get it to work on the armbian kernel, and I don’t know why. Here are the changes that I made:
/lib/firmware/brcm/BCM43430A1.hcd -> /lib/firmware/ap6212/bcm43438a1.hcd
/lib/firmware/brcm/brcmfmac43430-sdio.sinovoip,bpi-m2-zero.txt
(I think I can just link that last one to /lib/firmware/ap6212/nvram.txt)
I’ve compiled my own kernel based on sunxi-next, and there bluetooth works without further configuration. On the armbian kernel, basically nothings happens, not even when I manually load the hci_uart module. Also, the bluetooth rfkill device doesn’t show up, whereas with my own kernel config, it does. (Conversely, I can’t get lima to work with my sunxi-next config).
@igorpec, if you have any suggestions for getting bluetooth working, I’d be very happy to hear them! I would love to get the above changes in armbian as well…
Finally, I can play a sound file with aplay, but I can’t hear it… Any suggestions more than welcome!
root@bananapim2zero:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: allwinnerhdmi [allwinner,hdmi], device 0: 1c22800.i2s-i2s-hifi i2s-hifi-0 [1c22800.i2s-i2s-hifi i2s-hifi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
root@bananapim2zero:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
default:CARD=allwinnerhdmi
allwinner,hdmi, 1c22800.i2s-i2s-hifi i2s-hifi-0
Default Audio Device
sysdefault:CARD=allwinnerhdmi
dmix:CARD=allwinnerhdmi,DEV=0
Direct sample mixing device
dsnoop:CARD=allwinnerhdmi,DEV=0
Direct sample snooping device
hw:CARD=allwinnerhdmi,DEV=0
Direct hardware device without any conversions
plughw:CARD=allwinnerhdmi,DEV=0
Hardware device with all software conversions
usbstream:CARD=allwinnerhdmi
allwinner,hdmi
USB Stream Output
