Banana Pi BPI-F3 SpacemiT K1 8 core RISC-V chip run OpenWRT, are you want to do a NAS??
#bananapi #nas #riscv #sbc #automation #network #router
OpenWrt source code:
https://archive.spacemit.com/openwrt/releases/23.05.2/
image:
frome online documents: Banana Pi BPI-F3 | BananaPi Docs
With titantools_for_linux-1.0.35-beta.AppImage downloaded from the official wiki, I have burned the openWrt image to the F3 board(onboard emmc), but it can’t boot up. I also burned the Bianbu image to the SAME F3 board and it booted seamlessly. All images downloaded from the official wiki page. Anyone has the same problem as mine? Can anyone help me, please?
Have you tried it from SD-Card? Do you have the debug window open? and if so does it say anything?
RC
I tried booting from sd-card, still the same, it can boot from sd-card burned with Bianbu image, but can’t boot with the Openwrt image.
Hi there, I was able to start my BPI-F3 with openwrt installed on an SD card. I was also able using modemmanager to configure a 4G mini-pcie board and I am able to connect to internet if I connect a laptop to the lan port. Up to here all is good. Problems have started when I was trying to enable WIFI accesspoint using the realtech 8852bs wifi integrated on the board. This is what I have observed:
Wifi menu will not show up in luci.
doing a lsmod I can see “8852bs 7589888 0” show up
doing a lspci no wifi module shows up:
root@OpenWrt:~# lspci
0001:00:00.0 PCI bridge: ASR Microelectronics Device 3003 (rev 01)
0002:00:00.0 PCI bridge: ASR Microelectronics Device 3003 (rev 01)
doing lsusb no wifi shows up:
root@OpenWrt:~# lsusb
Bus 003 Device 002: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 001 Device 002: ID 1e0e:9001 SimTech, Incorporated SimTech, Incorporated
Bus 002 Device 003: ID 2109:8817 VIA Labs, Inc. USB Billboard Device
Bus 001 Device 001: ID 1d6b:0002 Linux 6.1.15 ehci_hcd Spacemit EHCI
Bus 002 Device 002: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 002 Device 001: ID 1d6b:0002 Linux 6.1.15 xhci-hcd xHCI Host Controller
Bus 003 Device 001: ID 1d6b:0003 Linux 6.1.15 xhci-hcd xHCI Host Controller
doing a ifconfig wlan0 shows up:
root@OpenWrt:~# ifconfig
br-lan Link encap:Ethernet HWaddr FE:FE:FE:B0:C6:0D
inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::fcfe:feff:feb0:c60d/64 Scope:Link
inet6 addr: fd89:ad32:c9fc::1/60 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1216464 errors:0 dropped:0 overruns:0 frame:0
TX packets:2546053 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:66457479 (63.3 MiB) TX bytes:3570974184 (3.3 GiB)
eth0 Link encap:Ethernet HWaddr FE:FE:FE:B0:C6:0D
RX packets:1216951 errors:0 dropped:11 overruns:0 frame:0
TX packets:2546679 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:84215980 (80.3 MiB) TX bytes:3571007856 (3.3 GiB)
Interrupt:67 Base address:0xd000
eth1 Link encap:Ethernet HWaddr FE:FE:FE:B0:C6:0E
UP BROADCAST MULTICAST MTU:1500 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:68 Base address:0x5000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:924 errors:0 dropped:0 overruns:0 frame:0
TX packets:924 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:77759 (75.9 KiB) TX bytes:77759 (75.9 KiB)
wlan0 Link encap:Ethernet HWaddr 5C:8A:AE:67:5A:C7
wwan0 Link encap:UNSPEC HWaddr 00-00-00-00xx.xx.xx.xx-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:xx.xx.xx.xx P-t-P: Mask:255.255.255.252
inet6 addr: fe80::901e:dec9:20a6:c1a/64 Scope:Link
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:2544549 errors:0 dropped:0 overruns:0 frame:0
TX packets:1212696 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3535476134 (3.2 GiB) TX bytes:65514842 (62.4 MiB)
if I launch wifi config the is no output
my /etc/config/wireless is empty
I am unable to understand what I am missing to make the LUCI gui present the wireless menu. can someon give me a hint?
Thanks S.
SOLVED: Found out that access point is not managed by openwrt standard wifi manager and that is why configuring /etc/config/wireless will mess everything up not making wifi work.
Acess point is managed by hostapd process and the configuration can be found in /etc/hostapd.conf.
Cheers S.
