Banana Pi BPI-M5 Pro adopts the second-generation 8nm high-performance AIOT platform Rockchip RK3576, with a 6 TOPS computing power NPU and support for up to 32GB of large memory. It supports 8K video encoding and decoding, offers rich interfaces including dual gigabit Ethernet ports, WiFi 6 & BT5, and various video outputs. Compatible with multiple operating systems, it is suitable for ARM-based PCs, edge computing devices, personal mobile internet devices, and other digital multimedia applications.
Key Specifications
SOC: Rockchip RK3576
CPU: Integrates quad-core Cortex-A72 @ 2.2GHz, quad-core Cortex-A53 @ 1.8GHz, and a dedicated NEON co-processor.
GPU: ARM Mali G52 MC3 GPU.
NPU: Up to 6 TOPS (INT8) computing power, supporting INT4/INT8/INT16 mixed precision computation.
VPU/Video Codec:
- Decoding: Supports H.264, H.265, VP9, AV1, and AVS2 up to 8K@30fps or 4K@120fps, and high-quality JPEG decoding up to 4K@60fps.
- Encoding: Supports H.264 and H.265,JPEG up to 4K@60fps.
RAM: 8/16GB 32bit LPDDR5, default is 8GB, with RK3576 supporting up to 16GB.
Flash: 32/64/128GB eMMC, default is 64GB eMMC.
Operating Voltage: Wide input voltage range from 4.5V to 23V (voltage tolerance ±5%).
Operating Temperature: 0℃ ~ 80℃
Weight: 12g
Dimensions:
- CM5: 55 x 40 mm
- CM5-IO: 100 x 80 x 29 mm (3.94 x 3.15 x 1.14 inches)
Hardware interface:
Banana Pi BPI-CM5 Pro with IO board
IO Board interface:
more please see online documents:
