Banana Pi BPI-CM5 is a computer module with Amlogic A311D2 quad-core Cortex-A73 and quad-core Cortex-A53 SOC, Mali-G52 GPU MP8 GPU,4GB LPDDR4/LPDDR4x (Max 8G),16G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
Features:
- Amlogic A311D2,quad-core Cortex-A73 and quad-core Cortex-A53 SOC
- Mali-G52 GPU MP8 GPU
- 4GB LPDDR4/LPDDR4x (Max 8G)
- 16G eMMC flash (Max 128G)
- Designed with Board to Board connectors for enhanced stability same as RasPi CM4
- One on-board Gigabit Ethernet
- One PCIe2.0 interface expansion, can flexibly add related modules
- One USB3.0 port up to 5Gbps
- One USB2.0 high-speed USB/IO witch support USB OTG
- Three HDMI2.1 receiver ports
- one HDMI2.1 transmitter port with CEC
- two 8-lane V-by-One output can support up to 4Kx2K resolution(Multiplexing with MIPI-DSI/eDP/LVDS)
- two 4-lane MIPI-CSI camera interface with 16Mp ISP
Hardware interface:
BPI-CM5 core board also can use BPI-CM4 base board ,but not support full function:
wiki online documents ,will keep update:
