Banana Pi BPI-CM4 computer module with raspberyypi CM4 base board run android demo
Banana Pi BPI-CM4 computer module with raspberyypi CM4 base board run android demo Banana Pi BPI-CM4 is a computer module with Amlogic A311D, same size asm Raspberry Pi CM4 module ,it also features the same connection pins, which means that it should work with carrier boards designed for the Raspberry Pi CM4
https://wiki.banana-pi.org/BPI-CM4_Computer_module_and_development_Kit
