Are there any new news about a release date?
You see how it has worked for new BE14.
ā released by surprise
as usual!
Still no ETA? Iām now thinking of buying the GL.iNet Flint 4 if that releases first.
I just bought a couple of the GL.iNet Fint 4 routers. Sorry but I could no longer wait for the BPI-R4 Pro set with the BE1900⦠Iāve been waiting for over a year. Best of luck to you guys.
Why is the GL.iNet Fint 4 better than the BPI-R4Pro with the BE1400, which is available now?
Probably because the GL.iNet Fint 4 works, whereas the R4 Pro and BE14 donāt? I mean, the R4 Pro + BE14 combination doesnāt perform as well.
Itās been so much time since last update. Letās be honest - the thing doesnāt work nor probably never will.
Any other options for openwrt, double sfp+ ports and WiFi 7 320mhz?
Thank you.
the r4 is ok, i would probably go with a separate AP like something from ubiquiti
R4 has been released for a long time, and the product is quite complete. Although there are indeed a few issues that need to be resolved, the SFP+ functionality should be fine.
Iāll ask this question again: when is the announcement for the BE19000? Or was that not an announcement, but merely a render of a non-existent device? If it actually exists (which I personally strongly doubt by now), then where are the benchmarks, specifications, real-world photos of it in action, and so onālike we saw with the BE14000?
lasciate ogni speranza ~Dante
Bravo! I suggest making this the companyās slogan.
