Banana Pi BPI-6202 Embedded single board industrial computer provides rich expansion interfaces, All boards are connected via internal bus(485 or SPI) in the box
The BPI-6202 supports modular design, provides rich expansion interfaces, and can use the basic unit + 5 expansion units to support on-demand configuration. Extended IO unit modules include:
- 7 x RS485 module with isolation
- 16 x DI module (switch input module), passive input (up to 5 modules can be mixed)
- 16 x DO module (switch output module), relay output (up to 5 modules can be mixed)
- 8 x DI+8 x DO O module (switch input/output module), relay output (up to 5 modules can be mixed)
- 8 x AI + 4 x AO module (analog input/output module), support 0-5V, 0-20mA input
- Customized Lora, ZigBee, 433M wireless transmission modules, power line carrier modules, and other functional modules,
- The function board can be customized by third parties and can communicate with BPI-6202
