Banana BPI-R4 Pro MT76-OpenWrt24.10 DSA image
BPI-R4 Pro-8X-BE14-MT76-OpenWRT24.10-DSA-251120
Baidu Could: https://pan.baidu.com/s/1_h0JLKi-Bms7pLfGfLX1EA?pwd=8888 (pincode: 8888)
Google drive: BPI-R4Pro-8X-BE14-MT76-OpenWRT24.10-DSA-251120 - Google Drive
more ,please see: Banana Pi BPI-R4 Pro Wifi7 Router board design with Mediatek MT7988A | BananaPi Docs
Good morning Sinovoip,
Could you please indicate whether there is any repository where we can compile our own images? I look forward to your news.
Also, will the BE19000 finally be put on sale? The board has already arrived at my home, and I have seen that the case has been released for sale, which I have also purchased.
However, since the BE14000 has had so many problems, I would like to know whether, for the moment, we will have to continue using this WQIFI7 board, or whether we will soon be able to use the new BE19000.
And above all, can we have the source code so we can make our own builds?
Thank you for your work — I look forward to your reply.
Best regards,
Here is the source code of R4Pro.
Good morning, thank you very much for the repository. I need to run some tests to see which patches can be applied.
Regards
