Banana BPI-R4 Pro 8X — No UART output on Debug Console
I have a “Banana Pi BPI-R4 Pro 8X (MT7988A, 8GB RAM)” The board powers on normally, but I get absolutely no output from the serial console during power-on or reset.
Setup:
Debug console: correct USB-C Debug Console port Boot switch: SW3 A=1, B=1 (SD boot) Serial: 115200 8N1, no flow control SD card tested/removed; issue remains PWR green LED is ON Other LEDs (R/B/W2G/W5G/W6G) also illuminate
Linux detects the onboard USB-UART correctly HOLTEK USB TO UART BRIDGE ID: 04d9:b534 /dev/ttyACM0 fuser /dev/ttyACM0` shows nothing using the port. I tested with: sudo picocom -b 115200 /dev/ttyACM0 and also: sudo cat /dev/ttyACM0
Then power-cycled and pressed RESET, but no characters appear at all — not even the expected early boot ROM messages such as F0:, FA:, or Jump to BL.
Things I have already tried
Correct USB-C Debug Console port 115200 8N1 No hardware/software flow control SW3 set to 1,1 for SD boot SD card inserted SD card removed Full power cycle RESET button picocom cat /dev/ttyACM0 Verified that no other process is using /dev/ttyACM0 Verified the Holtek USB-UART bridge is correctly detected by Linux
My main questions
  1. What could cause the BPI-R4 Pro to produce absolutely no output on the Debug Console even though the board is powered on?
  2. Is it possible that the board is actually booting normally despite producing no UART output?
  3. If the board can boot without UART output, what is the best way to verify that the boot process is actually working?
  4. Is there a way to verify whether the MT7988A BootROM is running without relying on the onboard USB-UART console?
  5. What is the correct hardware-level UART test point/pin for the MT7988A debug UART on the BPI-R4 Pro 8X?
  6. Can I safely connect my 3.3 V PL2303 USB-TTL adapter directly to the debug UART? If so, which exact TX and GND pins should I use?
  7. Are there any LED patterns, Ethernet link behavior, SD-card activity, or other indicators that can confirm whether the board has successfully reached U-Boot/OpenWrt when the serial console is silent?
  8. Is there a recommended recovery procedure for the BPI-R4 Pro if the Debug Console remains completely silent?
  9. Could a bad bootloader, incorrect boot configuration, eMMC/NAND state, or SD-card image cause the Debug Console to remain completely blank from the very beginning?
Note :- i am just testing so i have not even tried to used my own firmware just using the one provided on Banana pi website.
I recall that the serial port on the R4 is incredibly picky about USB<->RS232 converters and several of mine do not work. the one which does claims to have a “genuine” FT232RNL; avoid converters based on the CP2102N
As to “could it be booting OK” the best way to check is probably to put OpenWRT on an SD card and boot from that - once it is up you should be able to connect to one of the LAN ports and log in.
I’m having a similar problem with the Pro. Isn’t it supposed to be the case that a new serial port appears in Device Manager in Windows as soon as you connect to the Pro via USB-C? Nothing shows up for me at all. How can I do a clean reinstall from an SD card without seeing anything? Or do I need a serial-TTL converter for this as well, just like with the R4?
I don’t have a R4 Pro (just realised this is about he Pro and not the plain R4) - just the R4 but the documentation is clear that it has an onboard USB to serial chip connected to the “USB debug” port so (assuming the R4 Pro is powered up) I would expect to see the serial interface appear in Device Manager.
In fact that appears to be the *only* serial port on the board.
