its looks like old and not updatedso how I can Install new one with a good specs and packages for BPI-R4I know only booting from SD by flashing by balenaEtcher
I fully agree that a serial console log of the boot process would be a much more useful report but due to the way the router is attached to the fiber (and where the fiber comes into the apartment), that means unhooking everything (incl. not having internet during the debugging phase which kind of makes debugging tricky, not to mention the SO screaming at me). I should probably get a second R4 for these situations.
It’s however very easy to reproduce: just flash the current sdcard.img from firmware selector and the router never actually comes up. So I doubt it is related to the upgrade process…
why? just connect serial connection while router is active and connected? my r2 is connected to serial adapter all the time and when i work on it (kernel upgrade) i use an usb extender cable (my router hangs ~2m from floor) to connect to laptop no need to unplug anything
sounds like the sdcard-image itself is broken and does not boot from it - so not upgrade related because it does not come to this point
That’s point, I don’t have a long enough USB cable (or an extension to fix it) to do it in place Fair enough that I should get one.
That’s what I am trying to say: the build itself is broken, not the update process, as it also happens with a fresh image of that build on a fresh sdcard.
@buz by broken was ment that you can’t create a running (sysupdate and/or sdcard) image right now and that will be fixed (hopefully within the next builds).
If you want to ensure your observation about broken image generation will be heard/solved soon then please open a bug ticket for openwrt imagebuilder at github.
