Asking for help regarding EM05G in BPI-R4
hi, i would like to replace my Fritzbox 6850 with OpenWRT. So i’d need a modem with 4G/LTE and Wifi 2GHZ and 5 GHz.
installation of version 25.12.0-rc2 worked well. I’ve learned: with one WifiCard only one band is possible. So i’m using two 8822CE cards in the mcpie slots (one for 2,4 GHZ, one for 5GHZ) - they are working well
for LTE connection I’ve bought a EM05G card (M.2 slot). with package “kmod-usb-net-cdc-mbim” OS recongizes the card and i was able to create an interface (MBIM and also Modemmanager) but card is not working.
Screenshot
as Modemmanager “says” “MM_MODEM_DISABLED” i tried to activate it with “mmcli -m 0 --enable” but got an error message “error: couldn’t enable the modem: ‘GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Retry: Retry: Invalid transition’”
here are some additional infos:
root@OpenWrt:~# mmcli -m 0
  General  |                    path: /org/freedesktop/ModemManager1/Modem/0
           |               device id: eb010b2f9e957c075cefb5f6002175b4f390aa87
  Hardware |            manufacturer: Quectel
           |                   model: Quectel EM05-G
           |       firmware revision: EM05GFAR07A07M1G
           |          carrier config: ROW_Generic_3GPP
           | carrier config revision: 05040820
           |            h/w revision: QUECTEL Mobile Broadband Modul
           |               supported: gsm-umts, lte
           |                 current: gsm-umts, lte
           |            equipment id: 016520001861276
  System   |                  device: /sys/devices/platform/soc/11200000.usb/usb1/1-1/1-1.1
           |                 physdev: /sys/devices/platform/soc/11200000.usb/usb1/1-1/1-1.1
           |                 drivers: cdc_mbim
           |                  plugin: quectel
           |            primary port: cdc-wdm0
           |                   ports: cdc-wdm0 (mbim), wwan0 (net)
  Status   |                   state: enabling
           |             power state: low
  Modes    |               supported: allowed: 3g; preferred: none
           |                          allowed: 4g; preferred: none
           |                          allowed: 3g, 4g; preferred: 4g
           |                          allowed: 3g, 4g; preferred: 3g
           |                 current: allowed: 3g, 4g; preferred: 4g
  Bands    |               supported: utran-1, utran-4, utran-6, utran-5, utran-8, utran-2,
           |                          eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7, eutran-8,
           |                          eutran-12, eutran-13, eutran-14, eutran-18, eutran-19, eutran-20,
           |                          eutran-25, eutran-26, eutran-28, eutran-38, eutran-39, eutran-40,
           |                          eutran-41, eutran-66, eutran-71, utran-19
           |                 current: utran-1, utran-4, utran-6, utran-5, utran-8, utran-2,
  IP       |               supported: ipv4, ipv6, ipv4v6
  3GPP     |                    imei: 016520001861276
  SIM      |        primary sim path: /org/freedesktop/ModemManager1/SIM/0
           |          sim slot paths: slot 1: none
           |                          slot 2: none (active)
root@OpenWrt:~#
then i wanted to check some stuff with AT command…but how to connect? Devices show only the /dev/cdc-wdm0, but there is no tty/usb device Package “kmod-usb-serial-qualcomm” is installed, what am i doing wrong?
and also a bit strange: i was able to switch to SimSlot 2 once, but now, when trying to switch back (mmcli -m 0 --set-primary-sim-slot=1) i get also an error: error: couldn’t request primary SIM switch: ‘GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Timeout: QMI core error: Transaction timed out’
Some hints would be great
thanks in advance an best regards
Depends on card…some support DBDC to have multiple interfaces like mt7615/7915 (and afaik their 16 variants).
Not sure about mlo ready cards like the be14 which can do virtual interfaces and select band inside driver independ of interface.
hmm, no reaction/hint regarding the EM05G…thats a bit frustrating…
It is detected by system (visible in nmcli) but i have not much experience in configuring modems. It seems somehow the sim is not detected (2 slots detected but both none).
I am using the EM05-CN module, but they are all EM05 modules. Here, I am using the MP4.1 image from the official website. It can be observed that it queries the /dev/ttyUSB device, which is necessary for conducting AT debugging with the EM05. I think it might be because the image didn’t include the necessary drivers.
can you tell me please, which drivers you are using (“kmod-usb-serial-qualcomm” seem not to be the correct ones)
still hoping for some answers/help
