Learn how to use the buttons on bpibit with LED panel ,The following example USES the NeoPixelBus library, so you need to download it from the Arduino library management
test with BPI:bit + Arduino IDE 1.8.9
about WS2812b LED
main function:
RgbColor(uint8_t r, uint8_t g, uint8_t b) : R(r), G(g), B(b) { };
void SetPixelColor(uint16_t indexPixel, typename T_COLOR_FEATURE::ColorObject color)
| Parameter | function |
| indexPixel | Labels of LED panels (see resources for labels below)) |
| color | Custom colors |
Code interpretation
NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin)Configure the NeoPixelBus object
sample code
#include <NeoPixelBus.h>
const uint16_t PixelCount = 25;
const uint8_t PixelPin = 4;
#define colorSaturation 128
#define delay_ms 500
NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin);
RgbColor red(colorSaturation, 0, 0);
RgbColor green(0, colorSaturation, 0);
RgbColor blue(0, 0, colorSaturation);
RgbColor white(colorSaturation);
RgbColor black(0);
RgbColor num1(0.8 * colorSaturation, 0, 0.2 * colorSaturation);
RgbColor num2(0.5 * colorSaturation, 0, 0.5 * colorSaturation);
RgbColor num3(0.25 * colorSaturation, 0, 0.75 * colorSaturation);
#define ledPower 2 //It's very important for the v1.2, if you use the v1.4 ,you can delete it
// #define BottomA 35
// #define BottomB 27
void setup()
Serial.begin(115200); //Serial Port Config 115200-8-N-1
//while (!Serial); // wait for serial attach
Serial.println();
Serial.println("Initializing...");
Serial.flush();
// this resets all the neopixels to an off state
strip.Begin();
strip.Show();
//You can also use BUTTON_A / BUTTON_B
pinMode(BUTTON_A, INPUT);//Botton A Pin Mode :Digital Input
pinMode(BUTTON_B, INPUT);//Botton B Pin Mode :Digital Input
pinMode(ledPower,OUTPUT);
digitalWrite(ledPower, HIGH);
void loop()
if (digitalRead(BUTTON_A) == LOW)
delay(10);
strip.SetPixelColor( 6, num1);
strip.SetPixelColor( 7, num1);
strip.SetPixelColor( 8, num1);
strip.SetPixelColor( 9, num1);
strip.SetPixelColor(10, num1);
strip.SetPixelColor(13, num1);
strip.SetPixelColor(16, num1);
strip.SetPixelColor(17, num1);
strip.SetPixelColor(18, num1);
strip.SetPixelColor(19, num1);
strip.Show();
else
int i;
Serial.println("Turn Off");
for (i = 0; i <= PixelCount - 1; i++)
strip.SetPixelColor(i, black);
strip.Show();
if (digitalRead(BUTTON_B) == LOW)
delay(10);
//strip.SetPixelColor( 5, num2);
strip.SetPixelColor( 6, num2);
strip.SetPixelColor( 7, num2);
strip.SetPixelColor( 8, num2);
strip.SetPixelColor( 9, num2);
strip.SetPixelColor(10, num2);
strip.SetPixelColor(12, num2);
strip.SetPixelColor(14, num2);
strip.SetPixelColor(15, num2);
strip.SetPixelColor(16, num2);
strip.SetPixelColor(17, num2);
strip.SetPixelColor(18, num2);
strip.SetPixelColor(19, num2);
strip.Show();
else
int i;
strip.Show();
Run
Press button A, LED panel displays letter A; Press button B and the LED panel displays the letter B
Note
- On the Arduino IDE, select bpi-bit for the development board
