Arduino for BPI:bit 15 : How to use MPU-9250 9-axis sensor
Banana Pi BPI:bit have a MPU-9250 9-axis sensor onboard , (triaxial acceleration Three-axis gyroscope and three-axis magnetic compass),
now we use BPI:bit + ArduinoIDE 1.8.9 learn to make a compass using the MPU9250 on the bpi-bit board
mainfunction
int MPU9250::setAccelRange(AccelRange range)
int MPU9250::setGyroRange(GyroRange range)
int MPU9250::setDlpfBandwidth(DlpfBandwidth bandwidth)
int MPU9250::calibrateMag()
double atan2(double y, double x)
Code
MPU9250 IMU(i2c0, 0x68);//V1.4
//we need to modify the I2C address according to the hardware.
//Hardware Version 1.2   >MPU9250 IMU(i2c0, 0x69);<
//Hardware Version 1.4   >MPU9250 IMU(i2c0, 0x68);<
Create an MPU9250 object.I2c0 is the pin of I2C, 0x68 is the address of I2C
(if bpi:bit hardware version 1.2, the address of I2C is 0x69)
Serial.printf("\r\n Yaw %.6f ", float(atan2(IMU.getMagY_uT(), IMU.getMagX_uT())) * RAD_TO_DEG);
  delay(20);
Print out the tilt in the x, y direction
To test your code, simply compile it using the Arduino IDE and upload it to the bpi:bit development board
#include "MPU9250.h"
int status;
void setup()
  // serial to display data
  Serial.begin(9600);
  while (!Serial)
  // start communication with IMU
  status = IMU.begin();
  if (status < 0)
    Serial.println("IMU initialization unsuccessful");
    Serial.println("Check IMU wiring or try cycling power");
    Serial.print("Status: ");
    Serial.println(status);
    while (1)
  // setting the accelerometer full scale range to +/-8G
  IMU.setAccelRange(MPU9250::ACCEL_RANGE_2G);
  // setting the gyroscope full scale range to +/-500 deg/s
  IMU.setGyroRange(MPU9250::GYRO_RANGE_250DPS);
  // setting DLPF bandwidth to 20 Hz
  IMU.setDlpfBandwidth(MPU9250::DLPF_BANDWIDTH_41HZ);
  // setting SRD to 19 for a 50 Hz update rate
  // IMU.setSrd(19);
  IMU.calibrateMag();
#define RAD_TO_DEG 57.295779513082320876798154814105  // 180/π
void loop()
  // read the sensor
  IMU.readSensor();
  delay(20);
test
The north-south Angle of the geomagnetic data obtained by the onboard MPU9250 magnetometer is returned through a serial port.
Angle and direction (LED panel up) :
方向 角度
东 +90
南 ±180
西 -90
北 ±0
reference ddocuments
MPU9250 lib
ESP32 chip
