Anyone using AI app builders with a Banana Pi as the local backend?
I’m planning a small maker project in Orlando where a BPI board runs a local service and I want something quick to build the front end and simple API routes. I’ve been reading about AI app builders like Rocket and how they handle pricing and export options, but I’m unsure whether the generated code is clean enough to point at a board on my own network. My concern is mostly vendor lock-in and whether I can self-host the result on the BPI instead of relying on their cloud. Has anyone here tried generating a small dashboard this way and then hosting it on a Banana Pi? I’d like to hear how the export and pricing actually worked out in practice, and whether the backend was simple enough to swap for a local endpoint.
Still comparing options before committing anything to the Banana Pi. I came across Rocket.new Review (2026): Pricing, Pros & Cons while checking how export and pricing actually work, but I’m not sure the generated backend would be clean enough to swap for a local endpoint.
