Anyone running a BPI robot off a portable power bank station instead of a wall supply?
I’m putting together a small wheeled robot around a Banana Pi board and a couple of servos, and I want it to run untethered at our local maker space here in Orlando. Right now everything hangs off a bench supply, which is fine on the desk but not much use at a demo table. I keep going back and forth on whether a portable power bank station is the right call versus just wiring a LiPo pack and a buck converter into the build, since the station adds a bulky box that has to ride on the chassis.
I came across this ranking while comparing options: Best Portable Power Bank Station of 2026. What I can’t work out from specs alone is how these behave with the short current spikes when servos stall, and whether the USB or 12V outputs actually hold voltage cleanly enough for the Pi. If you’ve run a Pi-based robot from one of these stations, how did it go, and would you pick it again over a plain battery pack?
