Are there any plans for an hardware design upgrade to increase the speed of the LAN port? I’m not using the wifi function, so the speed on the LAN ( home ) side of the router is limited to 1Ghz , not utilising the full speed of the WAN port.
How about using the BPI-R3?
Only 2.5G via sip’s , not that great
Sfp I think you mean. There are rtl8221b modules available, where the chip is fully accessible, practically the same as if it were build in and connected to mdio bus.
