has anyone used one on a BPI-R3? Any reason if i had 4 of them my wifi signal would be degraded?
2.4GHZ/5GHZ DIPLEXER
- Combine the 2.4GHz and 5GHz signals to one single dual-band antenna
- LTE coexistence option are with High Rejection in LTE bands especially B7/B30/B40 and B41
- Low insertion loss <1.3dB
- 2412MHz~2472MHz, 4900MHz~5950MHz
| PRODUCT TYPE | Diplexer interface board (U.FL to SMA) |
| HOST INTERFACE | 1×1 2.4GHz U.FL connector |
| 1×1 5GHz U.FL connector | |
| 1×1 2.4/5GHz SMA connector | |
| FREQUENCY RANGE | 2412MHz~2472MHz |
| 4900MHz~5950MHz | |
| INSERTION LOSS | SMA-DP-LTE |
| 2412MHz~2472MHz: 1.2dB | |
| 4900MHz~5950MHz: 1.2dB | |
| SMA-DP | |
| 2412MHz~2472MHz: 0.9dB | |
| 4900MHz~5950MHz: 1.3dB | |
| VSWR | SMA-DP-LTE |
| 2412MHz~2472MHz: 1.6:1 | |
| 4900MHz~5950MHz: 1.6:1 | |
| SMA-DP | |
| 2412MHz~2472MHz: 1.2:1 | |
| HUMIDITY | Operating: 5% to 95% (non-condensing) |
| Storage: Max. 90% (non-condensing) | |
| TEMPERATURE RANGE | Operating: -20ºC to 70ºC |
| Storage: -40ºC to 90ºC | |
| IMPEDANCE | 50 Ω |
