BPI-R2 New image : Openwrt/LEDE 2017-09-08
A new test image is available…
Summary
The linux kernel from LEDE does’t work on banana-pi R2 board so far, so we are using the banana-pi R2 Linux 4.4.70 kernel and LEDE file system to make this image.
How to use this image
Please note that this image is used to copy the bootable image from SD to EMMC, so it just works at u-boot phase. Finally the LEDE system will boot from EMMC, instead of SD card.
  1. Download this image to your host PC
  2. Copy it to your SD card by executing below command dd if= of=/dev/
  3. Move this SD card from host PC to R2 board
  4. Power on this board by pressing power button a few seconds
  5. Please turn power off and remove SD card when you see U-boot prompt Before u-boot prompt occurs, all parts(pre-loader/u-boot/kernel image/ramdisk iamge) will be copied from SD card to EMMC.
  6. Power on this board by press power button a few seconds
  7. The LEDE system will boot successfually
Baidu drive link:
http://pan.baidu.com/s/1eS1pRCA
MD5: e6483762a47336eab45beefcf030cd8f
Let me know if you have any question, and any suggestion is appreciated.
I followed the instructions but can’t get the R2 to boot without an SD card. Any ideas?
Same here. Sd-card is written to emmc but emmc will not be bootet. Why can’t we start lede from sd-card? Would be the easiest way … I finally tried to build a new lede-image from lede-repository, that seems to be successfull, but I wonder how to to create my own sd-card-image and boot from it ?! Would be nice if someone could explain how to do it. Another thing to be explained is the kernel-configuration (I have choosen Mediatek Ralink ARM / 32bit) but what modules are needed in detail? (network, switch, wireless, sata, usb, and maybe gfx and sound). I seems the design of the board is now much better than bpi-r1 (much better power-supply) but documentation and software are still in very early state which is a little bit sad …
@pdoyle003 @balou1974 I’m sorry for this, we test this image on two boards, looks like it’s working fine. So to dig out what happens on your board, can you please share us the console log which is collected when SD is installed(to program image to EMMC) and booting from EMMC.
I tried to get it working but i get red/purple screen instead of uboot splash, any suggestions?
Hello!
Here is the boot-log:
[USBD] USB PRB0 LineState: 0
[USBD] USB cable/ No Cable inserted!
[PLFM] Keep stay in USB Mode
Platform initialization is ok
wait for frequency meter finish, CLK26CALI = 0x81
mt_pll_post_init: mt_get_cpu_freq = 1040000Khz
wait for frequency meter finish, CLK26CALI = 0x90
mt_pll_post_init: mt_get_bus_freq = 273000Khz
mt_pll_post_init: mt_get_mem_freq = 133250Khz
[PWRAP] pwrap_init_preloader
[PWRAP] pwrap_init
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=0,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=1,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=2,rdata=800
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=3 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=4 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=5 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=6 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=7 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=8 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=9 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=10,rdata=1001
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=11,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=12,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=13,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=14,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=15,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=16,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=17,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=18,rdata=2003
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=19,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=20,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=21,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=22,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=23,rdata=6A97
[PWRAP] _pwrap_init_reg_clock
[PMIC_WRAP]wrap_init pass,the return value=0.
[pmic6323_init] Preloader Start..................
[pmic6323_init] PMIC CHIP Code = 0x2023
INT_MISC_CON: 0  TOP_RST_MISC: 0
pl pmic powerkey Press
[pmic6323_init] powerKey = 1
[pmic6323_init] is USB in = 0xB004
[pmic6323_init] Reg[0x11A]=0x1B
pmic setup LED
[pmic6323_init] Done...................
mt7623 disable long press reset ->>>>>
mt7623 disable long press reset <<<<<-
mt7623 VPA supplied by 1.0V to MT7530 ->
mt7623 VPA supplied by 1.0V to MT7530 <-
mt7623 enables RG_VGP1_EN for LCM ->
mt7623 enables RG_VGP1_EN for LCM <-
MT7623 E2 setting =>
MT7623 E2 setting <=
[PLFM] Init I2C: OK(0)
[PLFM] Init PWRAP: OK(0)
[PLFM] Init PMIC: OK(0)
[PLFM] chip[CA00]
[BLDR] [Support SD/eMMC] Build Time: 20170905-112929
==== Dump RGU Reg ========
RGU MODE:     4D
RGU LENGTH:   FFE0
RGU STA:      0
RGU INTERVAL: FFF
RGU SWSYSRST: 0
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
 mtk_wdt_mode_config  mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3)
kpd read addr: 0x0040: data:0x4001
Enter mtk_kpd_gpio_set!
kpd debug column : 0, 0, 0, 0, 0, 0, 0, 0
kpd debug row : 0, 0, 0, 0, 0, 0, 0, 0
after set KP enable: KP_SEL = 0x0 !
MTK_PMIC_RST_KEY is used for this project!
[RTC] get_frequency_meter: input=0x0, ouput=5
[RTC] get_frequency_meter: input=0x0, ouput=3967
[RTC] get_frequency_meter: input=0x0, ouput=0
[RTC] bbpu = 0x6, con = 0xB9BA
rtc_first_boot_init
rtc_2sec_stat_clear
rtc_2sec_reboot_check cali=1280
rtc_2sec_stat_clear
[RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0xC0, spar1 = 0x800
[RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1
[RTC] bbpu = 0x6, con = 0x426, cali = 0x500
pl pmic powerkey Release
[PLFM] Power key boot!
[RTC] rtc_bbpu_power_on done
[EMI] mcp_dram_num:0,discrete_dram_num:1,enable_combo_dis:0
[EMI] PCDDR3
[Check]mt_get_mdl_number 0x0
[EMI] eMMC/NAND ID = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[EMI] MDL number = 0
[EMI] emi_set eMMC/NAND ID = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[EMI][Vcore]0x21E=0x48,0x220=0x48
[EMI][Vmem]0x554=0x0
[EMI] PCDDR3 DRAM Clock = 1599912 KHz, MEMPLL MODE = 2
[EMI] PCDDR3 RXTDN Calibration:
Start REXTDN SW calibration...
drvp=0xB,drvn=0x8
[EMI] pinmux = 4
        dramc_write_leveling_swcal
delay  byte0  byte1  byte2  byte3
0    0    0    0    0
1    0    0    0    1
2    0    0    0    1
3    0    1    0    1
4    0    1    1    1
5    0    1    1    1
6    0    1    1    1
7    0    1    1    1
8    0    1    1    1
9    0    1    1    1
10    1    1    1    1
11    1    1    1    1
12    1    1    1    1
13    1    1    1    1
14    1    1    1    1
15    1    1    1    1
pass bytecount = 4
byte_i    status    best delay
0    2    10
1    2    3
2    2    4
3    2    1
[write leveling]DQS: 0x143A, DQM: 0x143A
[write leveling after remap]DQ byte0 reg: 0x200 val: 0xAAAA3333
[write leveling after remap]DQ byte1 reg: 0x204 val: 0x3333AAAA
[write leveling after remap]DQ byte2 reg: 0x208 val: 0x44441111
[write leveling after remap]DQ byte3 reg: 0x20C val: 0x11114444
X-axis: DQS Gating Window Delay (Fine Scale)
Y-axis: DQS Gating Window Delay (Coarse Scale)
          0    8   16   24   32   40   48   56   64   72   80   88   96  104  112  120
0000:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0001:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0002:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0003:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0004:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0005:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0006:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0007:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0008:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0009:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
000A:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
000B:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
000C:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
000D:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
000E:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
000F:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0010:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    1    1
0011:|    0    0    0    0    0    0    0    0    0    1    1    1    1    1    1    1
0012:|    0    0    0    1    1    1    1    1    1    1    1    1    1    0    0    0
0013:|    1    1    1    1    1    1    1    1    0    0    0    0    0    0    0    0
0014:|    1    1    1    0    0    0    0    0    0    0    0    0    0    0    0    0
0015:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0016:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0017:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0018:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0019:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
001A:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
001B:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
001C:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
001D:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
001E:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
001F:|    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
Rank 0 coarse tune value selection : 18, 18
18
64
rank 0 coarse = 18
rank 0 fine = 64
00:|    0    0    0    0    0    0    0    0    1    1    1    0
opt_dle value:13
                RX      DQS perbit delay software calibration
1.0-31 bit dq delay value
bit|     0  1  2  3  4  5  6  7  8  9
0 |    0 0 0 0 0 0 0 0 0 0
10 |    0 0 0 0 0 0 0 0 0 0
20 |    0 0 0 0 0 0 0 0 0 0
30 |    0 0
2.dqs window
x=pass dqs delay value (min~max)center
y=0-7bit DQ of every group
input delay:DQS0 =48 DQS1 = 39 DQS2 =50 DQS3 = 43
bit     DQS0     bit      DQS1     bit     DQS2     bit     DQS3
0  (18~67)42  8  (9~58)33  16  (23~67)45  24  (17~60)38
1  (19~68)43  9  (9~58)33  17  (24~68)46  25  (16~60)38
2  (19~66)42  10  (11~62)36  18  (25~70)47  26  (19~63)41
3  (19~65)42  11  (11~61)36  19  (21~67)44  27  (18~64)41
4  (22~70)46  12  (17~62)39  20  (27~74)50  28  (23~64)43
5  (19~69)44  13  (15~61)38  21  (27~69)48  29  (19~64)41
6  (22~67)44  14  (13~58)35  22  (25~70)47  30  (17~62)39
7  (24~72)48  15  (15~63)39  23  (29~72)50  31  (19~63)41
3.dq delay value last
0 |    6 5 6 6 2 4 4 0 6 6
10 |    3 3 0 1 4 0 5 4 3 6
20 |    0 2 3 0 5 5 2 2 0 2
30 |    4 2
*DQIDLY1 = 0x6060506
*DQIDLY2 = 0x40402
*DQIDLY3 = 0x3030606
*DQIDLY4 = 0x40100
*DQIDLY5 = 0x6030405
*DQIDLY6 = 0x30200
*DQIDLY7 = 0x2020505
*DQIDLY8 = 0x2040200
*DRAMC_R0DELDLY = 0x2B322730
[MEM]CONA:F3A2,conf1:F07486A3
DM4BitMux = 1
DQSO 0 in TX per-bit = 0 <= DQSO 0 in WL = 10
DQSO 1 in TX per-bit = 0 <= DQSO 1 in WL = 3
[Warning] DQSO 2 in TX per-bit = 8 > DQSO 2 in WL = 4
[Warning] DQSO 3 in TX per-bit = 6 > DQSO 3 in WL = 1
Tx DQM dly  = 0x17A
Tx DQM dly bit4 = 0x0
DRAMC_DQODLY1=AABB8889h
DRAMC_DQODLY2=8967CABCh
DRAMC_DQODLY3=2101012h
DRAMC_DQODLY4=10003023h
Tx DQ dly bit4 = 0x0
Tx DQS dly = 0x683A
Tx DQS dly bit4 = 0x0
TX Byte0: DQ - 18, DQS - 17. win_sum= 34
TX Byte1: DQ - 19, DQS - 11. win_sum= 29
TX Byte2: DQ - 9, DQS - 22. win_sum= 30
TX Byte3: DQ - 8, DQS - 20. win_sum= 27
DRAMC calibration takes 651979284 CPU cycles
[EMI] DRAMC calibration passed
[MEM] complex R/W mem test pass
0:dram_rank_size:80000000
[Dram_Buffer] dram size:-2147483648
[Dram_Buffer] structure size: 1725560
[Dram_Buffer] MAX_TEE_DRAM_SIZE: 0
Load u-boot from SD Card...
[PLFM] Init Boot Device: OK(0)
[PART] blksz: 512B
[PART] [0x0000000000000000-0x000000000003FFFF] "PRELOADER" (512 blocks)
[PART] [0x0000000000000000-0x000000000003FFFF] "MBR" (512 blocks)
[PART] [0x0000000000040000-0x00000000000BFFFF] "UBOOT" (1024 blocks)
[PART] [0x00000000000C0000-0x00000000000FFFFF] "CONFIG" (512 blocks)
[PART] [0x0000000000100000-0x000000000013FFFF] "FACTORY" (512 blocks)
[PART] [0x0000000000140000-0x000000000213FFFF] "BOOTIMG" (65536 blocks)
[PART] [0x0000000002140000-0x000000000413FFFF] "RECOVERY" (65536 blocks)
[PART] [0x0000000004140000-0x000000004413FFFF] "ROOTFS" (2097152 blocks)
[PART] [0x0000000044140000-0x000001FFC413FFFF] "USER" (-4194304 blocks)
[platform_vusb_on] PASS
[TOOL] PMIC not dectect usb cable!
[TOOL] <UART> listen  ended, receive size:0!
[TOOL] <UART> wait sync time 150ms->5ms
[TOOL] <UART> receieved data: ()
Device APC domain init setup:
 bootloader load uboot ,the address of uboot is 81E00000
[PART]partition name UBOOT
[PART]partition start block 0x200
[PART]partition size 0x80000
[PART]partition blks 0x400
[PART]partition flags 0x0
[PART]partition name 0x8
[bean] part->startblk(0x200) bdev->blksz(0x200) part->part_id(8) hdr(0xFFB50000)
[BlkDev.c 101 ]partition block size 0x200 ,blks:0x3CA00
[BlkDev.c 101 ]partition block erase size 0x200
[PART] load "UBOOT" from 0x0000000000050000 (dev) to 0x81E00000 (mem) [SUCCESS]
[PART] load speed: 4577KB/s, 300000 bytes, 64ms
[BT_SD_PG] device info 0x8590 0x8A00 0xCB01 0x102
[PLFM] md_type[0] = 255
[PLFM] md_type[1] = 255
[PLFM] boot reason: 0
[PLFM] boot mode: 0
[PLFM] META COM0: 0
[PLFM] <0xFFB7CC10>: 0x0
[PLFM] boot time: 2934ms
[PLFM] DDR reserve mode: enable = 0, success = 0
[BLDR] jump to 0x81E00000
[BLDR] <0x81E00000>=0xEA00000F
[BLDR] <0x81E00004>=0xE59FF014
U-Boot 2014.04-rc1 (Sep 05 2017 - 12:43:27)
g_nr_bank = 1.
g_total_rank_size = 0x80000000
DRAM:  2 GiB
WARNING: Caches not enabled
MMC:     emmc: 0,  sdcard: 1
dev_num = 1
***size=16384, offset=1048576, blk_start=2048, blk_cnt=32
In:    serial
Out:   serial
Err:   serial
Net:   Eth0
Uip activated
dev_num = 1
mmc1 is current device
dev_num = 1
MMC read: dev # 1, block # 25856, count 512 ... 512 blocks read: OK
dev_num = 0
mmc0 is current device
dev_num = 0
eMMC write: part # 1, block # 0, count 512 ... 512 blocks write: OK
dev_num = 1
dev_num = 1
MMC read: dev # 1, block # 26368, count 512 ... 512 blocks read: OK
dev_num = 0
dev_num = 0
MMC write: dev # 0, block # 640, count 512 ... 512 blocks write: OK
dev_num = 1
dev_num = 1
MMC read: dev # 1, block # 4096, count 21760 ... 21760 blocks read: OK
dev_num = 0
dev_num = 0
MMC write: dev # 0, block # 4096, count 21760 ... 21760 blocks write: OK
BPI-R2>
the link is dead. Or am I doing something wrong… ?
link works again … sorry
We guess this problem is caused by wrong partition configuration of EMMC, please following below steps to corret it:
  1. install the SD card with LEDE test image
  2. Power on the R2 board,
  3. After the u-boot prompt “BPI-R2>” occurs, please enter the command “emmc ecsd” to check partition configuration, on your board, the partition configuration should be 0h
       [EXT_CSD] Partition config      : 0h
  4. Then run command “emmc pconf 0x48” to change it
  5. Power off this board, remove SD card, and then power it on
Please let me know if you have any question…
I can’t get the image to work, possibly because of a special situation with my BPI-R2. The Power-Switch was broken when I received my board, so I soldered in a bridge for this switch.
Loading Ubuntu 16.04 image from SD card works for me with that workaround.
I’m wondering if that might cause the problem when booting OpenWRT, because I get only a “greenish” screen during boot and nothing else happens.
Any ideas on this issue?
Can you please share us the log? We’d like to see what happens on your board?
Unfortunately no, because I have neither local nor remote access to the board. NICs do not even come up.
Please confirm if you removed SD card after progamming LEDE image to EMMC completed.
If yes, the board is still not working, please follow steps to change a configuration:
Hello. I write image to sd card. But fdisk doesn`t see any partition on Sd-card. After install sd-card to board i get the pink(or red, or purple) screen at boot. Like a pkalemba.
What am I doing wrong?
UPD: command “emmc pconf 0x48” will help!
@garywang: Thanks a lot!!!
Your description worked like charm! LEDE/OpenWrt has booted from emmc after fixing the partitioning!
Hi i found none of packages i tried to install are not working. Any solution? Im a kinda newbie in LEDE
Do you see something on serial port when you install SD card on which the lede image is intalled? if yes, can you please share us the log? @pkalemba
@garywang i was able to run Lede on my board, but installing packages with opkg shows command not found if trying to run swconfig but its marked as installed
Can somebody give me instructons how to build own image with R2 support?
You need bleeding edge lede buildsystem to have the option to create mediatek arm 32bit kernel and lede distribution - search for lede project and use git clone to get the latetest development version. After that cd to lede and configure the buildsystem for the mentioned mediatek system(make menuconfig). After that start building with make.
