Secure Boot Support
I wonder if there is support for secure/trusted boot on any Banana Pi board? And how to use it?
+1 Is it possible? Iā€™m interested too for Secure IoT projects. Thanks
Hello, Bpi-W2 could support secure boot
After a little research, I managed to read the SID Key (128bits), the OEM and the temperature calibration data for the BPI-M2 Zero. The rest of the records always return ā€œ0ā€ s.
For reading, I modified devmem2.c using memory mapping but adding a modification of ā€œsid_read_keyā€ from sunxi-uboot.
The problem is writing. I have implemented the ā€œsid_program_keyā€ too and it runs fine, but it does not do anything. It gives the same reading value (0s). I have tried with records like SN, NV1 or ROTPK_HASH.
To rule out possible paging / user space problems, I have tested directly by writing logs from u-boot (via UART Debug) and from sunxi-fel. Nothing.
I have also seen that according to the schematic of BPI M2 Zero. The pins of the fuses (VDD_EFUSE and VDD_EFUSEBP) seems to be configured but I do not know if this configuration is the correct one to be able to do OTP programming.
Any idea?
Thanks!
