Realtek RTD1296 Intelligent voice, video processing platform
this is a BPI 4.0 customization project base on Banana Pi BPI-W2,it with 8G eMMC flash ,and 4G DDR on board, support HDMI in and HDMI out , You can collect the audio and video data of HDMI in, and send them to the display terminal after processing by HDMI out to complete the audio and video services you want to process,also support HDMI bypass funtion, use TS3DV642A0RUAR HDMI bypass chip. Direct connection between IN and OUT when shutdown (continuous electricity). After booting, HDMI IN and HDMI OUT function respectively
Main spec:
  • Realtek RTD1296, Quad-core ARM Cortex-A53
  • Mali T820 MP3 GPU
  • 4G DDR4 SDRAM
  • 8G eMMC flash (Max to 32 G)
  • Realtek rtl8275 b/g/n wifi and BT 4.0 support
  • M.2 Key E interface
  • MicroSD slot supports up to 256GB expansion
  • 1 SATA interface
  • 1XGigabit LAN
  • 1xUSB 3.0 1xUSB 2.0
  • HDMI in & HDMI out support HDMI bypass function
  • TYPE C /Power
  • IR support
Hardware interface:
Exterior industrial design
mare about this project ,please see wiki page , we will keeping update:
http://wiki.banana-pi.org/Realtek_RTD1296_Intelligent_voice,_video_processing_platform
if you want to do some on this hardware or OEM & ODM ,please contact:
judyhuang@banana-pi.com
Banana Pi BPI-W2 Realtek RTD1296 Intelligent voice, video processing platform, Test real-time video stream speech to text,So that the hearing impaired can easily watch the video
BPI:4.0 base on Banana Pi BPI-W2 ,real-time video stream speech to text Technical solution
Banana Pi BPI:4.0 project : base on BPI-W2 Realtek RTD1296 hdmi bypass function test
