Problems with PhoenixCard
(David Blakelock) #1
Hi, I have been trying to burn the SD card using Phoenixcard tool. I continue to get errors. Mostly Load Cardtool failed. From reading other forums, it appears that this is a common problem. Is there another tool that can be used? Or is there something I am doing wrong?
Thank you for your help.
David
(bpi team) #2
you can see here:
http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC
(d4t0r3k) #3
try bpi-copy. I used Linux mint and everything works fine. Phoenix failed me couple times.
(Jonny Gomes) #4
I am also facing this type of issue. This was happen for my internet connection. I get useful solution from https://netgearroutersupportnumber.com/how-to-reset-recover-change-netgear-router-password-or-login/.
#5
I think that you have upgraded poexixcard to the last versiĆ³n, try the previous version
