I have four P2 Zero boards that I’m having a very hard time with. I can not get any of them to boot, despite a range of os images, different SD cards, different power sources, etc. I chose these boards because I want a compact PoE rasPi-ish solution. I am ignorant of some Bpi details, and I’ve tried to read through the forums to no avail, so I’m reaching a point of frustration.
- Are the M2 and P2 essentially the same (can I use the same images)?
- Is there a central place to look for the actual latest known good images for the P2 board?
- I’ve assumed that I can set the device up headless, but it’s looking more and more like that’s not actually possible with the Bpi images. On Rpi I would burn an image, drop a wpa_supplicant.conf file and ssh file on the boot partition, then go.
- Is there a central guide to the LED boot codes on Bpi? The last one I tried has a double red flash, but I can’t find what this means. It’s not the power supply.
I’m on Apple MacOS and don’t have a PC. I’m using BalenaEtcher to image the SD cards.
