Impossible to boot BPI M3
dear all
maybe somebody facing the same issue … i m using etcher (and Win32DiskImager) to create ma SD card img, and whatever is the img, my bpiM3 doesn t boot… I change the SD card … still the issue…
i can see the blue BPI welcome screen then reboot… etc
Anybody can provide a small advise ?
Christophe
Did you try different images and what adapter you are using for power Banana Pi M3?
yep … thanks for your answer and correct it was a power supply issue… need to find a stronger power supply… thanks a lot for your help
christophe
No problem, i am happy i helped you :slight_smile: I recommend you to buy this Power supply: https://www.ebay.com/itm/DC-5V-3A-Orange-pi-Banana-pi-M3-ac-to-dc-Power-supply-adapter/172384149910?hash=item2822e56196:g:ibwAAOSwx2dYDDLJ
is the plug the right size for the B Pi M3 board?
i also have same problem, i use samsung 64GB evo+, 8 GB class 6 memmory card and 5v 2A power mobile adapter , only show bpi welcome screen after few seconds RBG light are off, if i not using hdmi cable RBG light not off.
img are 1. 2017-07-13-ubuntu-16.04-mate-desktop-beta-bpi-m3-ov8865-sd-emmc.img, 2. 2018-01-04-ubuntu-16.04-mate-desktop-v1.0-bpi-m3-sd-emmc.img_2
You need to use 3A power suply! 2A is too week. And don’t power banana pi with Micro usb. Power Banana Pi with the Barrel power conector.
I m waiting the power Supply 5v-3A… I will update this post for sharing experience
I’m powering my m2 Berry with an atx power supply through molex to usb adapter. And it works fine even under heavy loads.
