How to make it go to sleep 3.5inch HDD that connected with BPI-M2 Ultra by SATA?
hi…
im using 3.5 inch 4TB hdd by sata connection i managed power by disassemble usb 3.0 hdd case… my problem is…i uses my bananapi as media server…i rans it 24/7… but i only uses it 2~4 hours per day.
and you probably know 3.5inch HDD 7200rpm makes a lot of noise and heat!( and of course consumes noticeable electricity too)
how can i make HDD go to sleep when I or BANANAPI is not using HDD? please help me…
summer is coming
For the 3.5 "HDD you need a 12V power supply
i do have 12v power for my 3.5’’ HDD. it is fully operational
what i want to do is make my HDD go to sleep when no one is using
Hi
hdparm
https://www.foxplex.com/sites/festplatten-standby-im-leerlauf-mit-hdparm-und-hd-idle/
When you mount external drive - system olways (one ping per second) check if drive is mounted. It’s procedure always bring up a drive. If you want make this process more silent - use ssd.
