I don’t fully understand step 3. I’ve downloaded u-boot.bin using my Windows PC, but I’m not sure where to put it for this step. Can you please clarify for me. Thanks.
This is my result of executing tftp:
BPI-W2> tftp 0x1500000 u-boot.bin
Using r8168#0 device
TFTP from server 192.168.100.2; our IP address is 192.168.100.1
Filename 'u-boot.bin'.
Load address: 0x1500000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
BPI-W2>
Here is full output of reboot with ESC key:
C1:80000000
C2
C3hswitch frequency to 0x00000046
frequency divider is 0x00000080
frequency divider is 0x00000004
switch to SDR 8 bit
switch bus width to 0x00000008 bits success
hwsetting size: 00000BE4
C4
f
5-5
s_f
5-5-2
Goto FSBL: 0x10100000
emmc_cid[3] = 0xE9547849 emmc_cid[2] = 0xDD650152 emmc_cid[1] = 0x34454D47 emmc_
cid[0] = 0x38000115
DEVICE_TYPE = 00000057
emmc_sec_count = 00E90000
switch speed to 0x00000002 success
switch frequency to 0x000000A6
frequency divider is 0x00000000
1st TX_window = 0xFFFFFFDE
1st phase TX VP0= 0x00000012
RX_window = 0xFFFFFC03
phase RX VP1= 0x00000015
Welcome to FSBL ...
[FSBL] Warm Boot: 0x00000000
[FSBL] Secure: 0x0000BEEE
[FSBL] Flash Type: 0x00000002
[FSBL] DCache Enable: 0x00000000
[FSBL] SVP = N
********** FW_TYPE_GOLD_TEE **********
FW Image to 0x10200000, size=0x0007BDA0 (0x1027BDA0)
FW Image fr 0x000B0600
********** FW_TYPE_GOLD_BL31 **********
FW Image to 0x10120000, size=0x000062A0 (0x101262A0)
FW Image fr 0x0012C400
********** FW_TYPE_BOOTCODE **********
FW Image to 0x00020000, size=0x0007DC20 (0x0009DC20)
FW Image fr 0x00020E00
md copy audio bin
VERBOSE: bl31_setup
NOTICE: BL31: v1.2(debug):a6c9ab6
NOTICE: BL31: Built : 15:16:22, Apr 27 2017
INFO: BL31: Initializing runtime services
INFO: Start to init service std_svc
INFO: Finish to init service std_svc
INFO: Start to init service opteed_fast
INFO: Finish to init service opteed_fast
INFO: BL31: Initializing BL32
INFO: TEE-CORE: TEE OS v2.1
INFO: TEE-CORE: TA RAM slim vesion.
INFO: TEE-CORE: Skipping to check tee os version.
INFO: TEE-CORE: Initializing (9a5884c #1 四 12月 7 17:26:20 CST 2017 aarch
64)
MESSAGE: [0x0] TEE-CORE:tee_otp_get_hw_unique_key:70: ************************
tee_otp_get_hw_unique_key chip id: 30000
MESSAGE: [0x0] TEE-CORE:tee_otp_get_hw_unique_key:75: ************************
tee_otp_get_hw_unique_key used Kf
INFO: TEE-CORE: teecore inits done
INFO: Core_0 TEESMC_OPTEED_RETURN_ENTRY_DONE
INFO: Core_0 got optee_vectors (0x1020093c)
INFO: BL31: Initialized BL32
INFO: EXIT BL31
INFO: bl31_to_kernel: kernel_resume_entry = 0x1e000
INFO: bl31 jumps to EL2: LK entry
U-Boot 2015.07 (May 15 2018 - 22:44:59 +0800)
CPU : Cortex-A53 Quad Core - AARCH64
Board: Realtek QA Board
DRAM: 2 GiB
Watchdog: Disabled
mapping memory 0x20000000-0x40000000 non-cached
flushing dcache successfully.
nor flash id [0x00ef4018]
sector 256k en: 0
sector 64k en: 1
sector 32k en: 1
sector 4k en: 1
page_program : 1
max capacity : 0x01000000
spi type name : WINBOND_W325Q128BV_128Mbit
MMC: Initialize eMMC in traditional mmc flow.
RTD1295 eMMC: 0
rsp[0]=0x15010038,
rsp[1]=0x474d4534,
rsp[2]=0x520165dd,
rsp[3]=0x497854e9
The cid_val is 15.
rsp[0]=0xd0270132,
rsp[1]=0x0f5903ff,
rsp[2]=0xf6dbffef,
rsp[3]=0x8e40400d
mmc->version=0x40000000
version=0x00000004
[LY] cardtype=57, mmc->card_caps=0f
[LY] freq = 00464388, clk diver = 00000080
[LY] speed up emmc at HS-200
[LY] HS-200 bus width=2
[LY] mmc->boot_caps = 20b
TEMP TX_WINDOW=0xffffffde, TX_best=0x12
RX_WINDOW=0xfffffc03, RX_best=0x15
TX1_WINDOW=0x7fffff80, TX_best=0x12
[LY] hs200 : 0
[HC] ERASE Unit Size = 524288 bytes
[HC] WPG_SIZE = 8388608 bytes
Device: RTD1295 eMMC
Manufacturer ID: 15
OEM: 100
Tran Speed: 200000000
Rd Block Len: 512
MMC version 4.0
High Capacity: No
Capacity: 7.3 GiB
User Capacity: 7.3 GiB
Boot Capacity: 4 MiB
RPMB Capacity: 512 KiB
Bus Width: 8-bit
Speed: HS200
SD:
SD device index# 0
Factory: MMC
Factory: pp:1, seq#:0x1a, size:0x22000
------------can't find tmp/factory/000BootParam.h
In: serial
Out: serial
Err: serial
HDMITx_HPD=False
------------tmp/factory/video_rpc.bin found
EDID checksum: read 00 00, last 8e 00
Sink changed, skip ONE_STEP_RPC
tv_system=25 mode=1
Net: Realtek PCIe GBE Family Controller mcfg = 0024
dev->name=r8168#0
Checking default environment
Hit Esc or Tab key to enter console mode or rescue linux: 0
------------can't find tmp/factory/recovery
Press Esc Key
Enter console mode, disable watchdog ...
BPI-W2> mmcinfo
Manufacturer ID: 15
OEM: 100
Rd Block Len: 512
MMC version 4.0
High Capacity: No
Capacity: 7.3 GiB
Bus Width: 8-bit
Erase Group Size: 256 MiB
BPI-W2>
