how to install opencv on BPI-M2 Berry.
The first is to install the various dependencies of opencv and the library of image video.
update at first:
sudo apt-get update
1.install build-essential、cmake、git and pkg-config tool
sudo apt-get install build-essential cmake git pkg-config
2.:Install the various image packages required.
sudo apt-get install libjpeg8-dev (jpeg lib)
sudo apt-get install libtiff5-dev (tif lib)
sudo apt-get install libjasper-dev (JPEG-2000 lib)
sudo apt-get install libpng12-dev (png lib)
3.:The package for video.
sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev
- install gtk2.0:
sudo apt-get install libgtk2.0-dev
5.Optimize package installation.:
sudo apt-get install libatlas-base-dev gfortran
At this point, various toolkits are installed successfully.
https://github.com/opencv/opencv/releases download opencv sorce code (tar.gz file ),
unzip tar.gz file
1.cd ~
enter opencv dir
2.create build dir
mkdir build
3.cd build
enter build dir
4.install to /urs/local
cmake -D CMAKE_BUILD_TYPE=RELEASE \ -D CMAKE_INSTALL_PREFIX=/usr/local ..
5.Start Compilation:
sudo make
sudo make install
sudo ldconfig
opencv install finished.
write cod to test
create test.cpp
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
using namespace cv;
int main()
Mat img=imread("1.jpg");
imshow("test",img);
waitKey(0);
return 0;
create CMakeLists.txt and write
cmake_minimum_required(VERSION 2.8)
project( test)
find_package( OpenCV REQUIRED )
add_executable( test test.cpp )
target_link_libraries( test${OpenCV_LIBS} )
Put a picture named 1.jpg in this file directory.
cd
cmake .
make
./test
If the output image is configured correctly.
