How can i change resolution and rootfs?
hey, where and how can i change the resolotiuon of hdmi-output? i have changed the uenv.txt, nothing happends. i have edited the script.bin nothing happends. pls tell me how can i change to 1080p
also o have a problem with rootfs i have changed the line root=/dev/mmcblk0p2 to root=/dev/sda3 in the uenv.txt.
but nothing happends. the bpi rootfs stayed on mmcblk0p2
i have downloaded the image from here
thx
Hi Daniel
With the Raspbian OS image, I followed these steps
With the Ubuntu 16.04 OS image, I followed these steps:
List the installed bananapi packages
dpkg -l | grep bananapi
If you don’t see the bpi-tools package then download it from here and then install it as follows
The path shown below is wherever you downloaded the package to
For me, I downloaded the package to this path: /home/pi/Downloads/bananapi-bpi-tools_1.0.3_armhf.deb
sudo dpkg -i /home/pi/Downloads/bananapi-bpi-tools_1.0.3_armhf.deb
List the installed bananapi packages again, if the install was successful, you’ll now see the bpi-tools package
Check that you have the following file
/usr/lib/u-boot/bananapi/bpi-m3/BPI_M3_1080P.img.gz
To check, run the following command
ls -la /usr/lib/u-boot/bananapi/bpi-m3
Once confirmed that you have the file, then run the following command from the command shell to change resolution to 1080
sudo bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m3/BPI_M3_1080P.img.gz
Once complete then run
sudo reboot now
You should now have 1080 resolution once the Pi boots back up
The steps above were carried out with the Pi plugged into a monitor via HDMI
Hope this helps
thanks for your reply
the steps to change the resolution are helpful. now the bpi runs in 1080p.
but how can i move the root-partition from mmcblk0p2 to sda3?
regards
