Hotspot sharing wifi (access point)
Hello
Am a Banana’s Neewbe ! :blush:
I would like to create a wifi hotspot (sharing wifi to allow local access to my bpi)
I read a lot of topics about bpi R2 or m3 on it ! :anguished:
…but nothing about bpi-m2u (ultra) aka R40 (if am not wrong)
So, I would like to clarify myself on it.
Do the BpiM2U allow to creat local wifi hotspot ?
Do the Access Point is working on it ?
Do you have informations ? A good topic for me ?
Thanks :upside_down_face:
Hello
Have you find a solution? I try too without success!
Best regards
Hello, I succeed to create an AP on M2U on Ubuntu,but it is very strange I can’t find the ssid signal which was I created when I use my laptop or phone to search wifi.
Here are the steps:
  1. apt-get update
  2. apt-get upgrade
  3. apt-get install hostapd
  4. vim /etc/hostapd/hostapd.conf
    input these to hostapd.conf:
    interface=wlan0
    ssid=test_m2p
    driver=nl80211
    country_code=US
    hw_mode=g
    channel=1
    max_num_sta=5
    wpa=2
    auth_algs=1
    rsn_pairwise=CCMP
    wpa_key_mgmt=WPA-PSK
    wpa_passphrase=12341234
  5. hostapd -d /etc/hostapd/hostapd.conf image
How did you install the driver? I have extreme problems with the current kernel… Bildschirmfoto%20von%20%C2%BB2018-06-09%2015-44-03%C2%AB
Any Idea how to fix this?
I use Ubuntu system,which system did you use?
could you share me the link?
The Debian 9.1 Image,
https://drive.google.com/file/d/0B_YnvHgh2rwjeTh4TmlnMGl5X3M/view?usp=drivesdk
Hello, I created ap successfully, here are steps:
  1. download hostapd packages( I’m using hostapd-2.6.tar.gz )
  2. install hostapd in debian
  3. after you installed, execute these commands:
  • nmcli radio wifi off
  • rfkill unblock wlan
  1. start hostapd: hostapd -B /etc/hostapd.conf
Ok, but that is not the problem. The Problem is I can not install the driver for my Wifi Adapter. (Rocketek 600).
I want to use this adapter, because the dual band wifi support.
