I have a pre-installed Android in the onborard emmc and a current version of Armbian Linux on SD.
Please show the necessary steps to configure U-boot in Linux to be able to boot from emmc without physically removing SD.
Why not change mmc-partition (for kernel) and root-var (rootfs). If you post your uenv.txt (better both with info which one is used first) i maybe can show you the changes
Here is my partition table for emmc. Which partition needs to be changed?
And my /boot directory has “armbianEnv.txt”.
the current “rootdev” should be the SD card that I burned.
What steps should I take to “chain load” emmc, by booting with this SD card ?
