Bpir2wrt Openwrt-Fork for BPI-R2
You must find file named:
openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-squashfs-sysupgrade-sd.img
Thanks for publishing this image. I’ve installed it to EMMC on my BPI-R2 and it works great. The only problem is that I can’t configure /etc/fw_env.config correctly. Can anyone share a working copy of this config file? Right now mine is:
# Notice, that the "Number of sectors" is ignored on NOR and SPI-dataflash.
# Futhermore, if the Flash sector size is ommitted, this value is assumed to
# be the same as the Environment size, which is valid for NOR and SPI-dataflash
# NOR example
# MTD device name       Device offset   Env. size       Flash sector size       Number of sectors
/dev/mtd1               0xc0000         0x2000          0x1000
When I run fw_printenv I get: root@OpenWrt:/# fw_printenv Unsupported flash type 1 on /dev/mtd1 Too few good blocks within range
