Bpir2wrt Openwrt-Fork for BPI-R2
Hello, I am a novice just touching openwrt, I am using Google translation. I’ve inserted MT7612E MiniPCIE. I’m brushing bpir2wrt and restarting indefinitely. I don’t know why the
bpi-r2.log (108.8 KB)
set_p2p_mode_handler [wlan_gen2]
Looks like internal wifi-driver.have you same problem without pcie-card?
I still can’t find ‘mtk-bpi-r2-SD.img’ and ‘mtk-bpi-r2-EMMC.img’ files in whole build directory. Only what I can find is ‘openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-squashfs-sysupgrade-sd.img’ and ‘openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-squashfs-sysupgrade-sd.img’
Regards.
That’s is the 17.0x lede branch. Thus, very old.
Isn’t there anything from the OpenWrt 18.06.x branch available … which works?
Yeah, these are the files to use with sd card or emmc on bpir2. Its not a router its a SBC so we stick to “images”(img) not to “binaries”(bin). Flash image to sdcard and boot. it should run out of the box
! No hdmi you need a serial to usb adapter or connect via ethernet to luci! Choose luci admin full in make menuconfig to have it included into image( “*” not “m” ) then you can connect via browser to your openwrt bpir2.
No its 18.06.01 source and kernel 4.14.75. You shouldnt use openwrt when you are not used to it. BPI-R2 is not greatly supported!
I am cloning the repository again to see if i missed to commit something. My last image 14 days ago is running with wmt.
What i have done today:
mkdir bpi-r2
cd bpi-r2
mkdir testing
git clone https://github.com/eliasmagn/bpir2wrt.git
cd bpir2wrt
./scripts/feeds update -a && ./scripts/feeds install -a
make menuconfig
this is my config: https://pastebin.com/fauk6xyY
ionice -c 3 nice -n15 make -j18
now i am waiting and will post the result and further steps later…
later is now:
dd if=/home/($whoami)/bpi-r2/testing/bpir2wrt/bin/targets/mediatek/mt7623-7623n-bananapi-bpi-r2-squashfs-sysupgrade-sd.img of=/dev/sdk
now i am starting the bpi-r2 it is running i have a error in wlan0 device naming and wmt but no kernel panic!
Hi, Iv’ve tried to make my own img and done as like you but i’had error:
“package/Makefile:107: recipe for target ‘package/feeds/packages/jool/compile’ failed” Don’t know whats happened. Thanks if you can help me. regards
Can you post the content of net/jool/Makefile and try a
make V=s
and post error massage
edit: dont post the complete output, only the errors for jool, perhaps 10 to 20 lines!
Thank you. Installing on EMMC working fine, but memory limited to 512M:
free -m
             total       used       free     shared    buffers     cached
Mem:        517232      99276     417956       1292      46776      18300
And root on EMMC 256M only:
df -h  |grep overlay
/dev/mtdblock7          251.1M     12.1M    239.1M   5% /overlay
overlayfs:/overlay      251.1M     12.1M    239.1M   5% /
please check below patch has applied to your code base, thanks.
https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/arch/arm/boot/dts/mt7623n-bananapi-bpi-r2.dts?h=next-20181214&id=acf09966c6ff6bbbb9900812529a4a355b250327
Thanks for Answer her is the code
Error Code of net/jool
/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/mod/stateful/fragment_db.c:96:14: note: each undeclared identifier is reported only once for each function it appears in /home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/mod/stateful/fragment_db.c:97:1: warning: control reaches end of non-void function [-Wreturn-type] } ^ scripts/Makefile.build:328: recipe for target ‘/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/mod/stateful/fragment_db.o’ failed make[5]: *** [/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/mod/stateful/fragment_db.o] Error 1 Makefile:1525: recipe for target ‘module/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/mod/stateful’ failed make[4]: *** [module/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/mod/stateful] Error 2 make[4]: Leaving directory ‘/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/linux-4.14.75’ Makefile:113: recipe for target ‘/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/.built’ failed make[3]: *** [/home/michael/bpi-r2/bpir2wrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/jool-9dfaf22e49f7905d94af9b73f9bee22c26d7dd4a/.built] Error 2 make[3]: Leaving directory ‘/home/michael/bpi-r2/bpir2wrt/feeds/packages/net/jool’ Command exited with non-zero status 2 time: package/feeds/packages/jool/compile#0.76#0.25#1.64 package/Makefile:107: recipe for target ‘package/feeds/packages/jool/compile’ failed make[2]: *** [package/feeds/packages/jool/compile] Error 2 make[2]: Leaving directory ‘/home/michael/bpi-r2/bpir2wrt’ package/Makefile:103: recipe for target ‘/home/michael/bpi-r2/bpir2wrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.package_compile’ failed make[1]: *** [/home/michael/bpi-r2/bpir2wrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.package_compile] Error 2 make[1]: Leaving directory ‘/home/michael/bpi-r2/bpir2wrt’ /home/michael/bpi-r2/bpir2wrt/include/toplevel.mk:216 : la recette pour la cible « world » a échouée make: *** [world] Erreur 2
please set
LANG=C
before running build-script and use code-indentation (select your output and press “<>”-button)
No, it didn’t help. I think trouble in vmalloc parameter in boot config.
I committed small build helper. You can try it https://github.com/Mihail-samoylov/openwrt-bpir2-build-helper
Thx, for your work. I myself always work with debian. Its the de facto standard for compiling in my perspective. Ubuntu is a debian derivate, i always use a minmal debian stable to minimize errors and ssh into it! Docker is fine, Virtual Machines are less powerfull, but better to maintain and they are easily portable to a new machine or a diffrent host os! of course … my opinion. I would recommend to use a debian vm, like i do!
Your Dockerfile is NICE! I like it very much!
Samoylov changed it in dockerfile… but the others should not use
if they do not have enough ram and threads or cpus in their system. better use
ionice -c 3 nice -n15 make -j3
this can cause errors as well!
@samoylov You could take a look at your patched DTS file in some (dont know which it was, take a look in the kernel sources or you’ll find the directory with a cat build.log | grep dts ) subdirectory of build_dir to see if the RAM patch was merged correctly take a look–> after the build process and before the
make dirclean
I did’nt configured uboot for emmc boot so you wont have more than 256mb as root. i Take a look into it. I need to know how you booted to emmc and how you flashed the image to automate the process ?
Regards
ok i have to admit the patch directory is quite messy!! i should clean it up… should be patch 0229-fix-memory-size…
--- a/arch/arm/boot/dts/mt7623n-bananapi-bpi-r2.dts
+++ b/arch/arm/boot/dts/mt7623n-bananapi-bpi-r2.dts
@@ -22,7 +22,7 @@
 	memory {
-		reg = <0 0x80000000 0 0x20000000>;
+		reg = <0 0x80000000 0 0x80000000>;
cpus {
Just following official instructions. Flash sd with openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-squashfs-sysupgrade-sd.img,insert sd into BPI, boot (don’t forget insert additional mini-usb, connected to any power source)
  1. Connect ethernet to any lan port, set IP 192.168.1.2/24 on your computer and ssh [email protected] without password Run commands:
dd if=/openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-squashfs-sysupgrade-emmc.img of=/dev/mmcblk0
dd if=/openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-squashfs-sysupgrade-emmc.img of=/dev/mmcblk0boot0 bs=1M count=1
mmc bootpart enable 1 1 /dev/mmcblk0
mmc extcsd read /dev/mmcblk0 | grep PARTITION_CONFIG
Last command should show [PARTITION_CONFIG: 0x48] Power off, remove SD-card and power on. Then switch your computer to dhcp and you should receive IP from BPI
I’ve tried build https://github.com/eliasmagn/bpir2wrt/pull/5 , but with no success, still 512M.
Hi Bialy39.
I’m having the same issue, after compiling i can not find any .img file. Could you solve this?
