BPI-R64 + Armbian
I ported (almost) Armbian to BPI-64, see https://github.com/muravjov/armbian-build .
The images are being built Travis and you may find them at https://github.com/muravjov/armbian-build/releases .
In fact now is only one release with kernel built by @frank-w at https://github.com/frank-w/BPI-R2-4.14/releases/download/CI-BUILD-20200225_203315-c075525e6/linux-image-5.4.22-bpi-r64-main_5.4.22-bpi-r64-main-2_arm64.deb .
How to use:
# get the image
wget https://github.com/muravjov/armbian-build/releases/download/2020-03-02_c539c65/Armbian_20.05.0-trunk_Bananapir64_buster.img.zip
# write to SD card
unzip -p ./Armbian_20.05.0-trunk_Bananapir64_buster.img.zip | pv | sudo dd of=/dev/mmcblk0 bs=10M status=noxfer
# turn on BPI-R64 with the SD card
| __ )|  _ \(_) |  _ \ / /_ | || |
|  _ \| |_) | | | |_) | '_ \| || |_
| |_) |  __/| | |  _ <| (_) |__   _|
|____/|_|   |_| |_| \_\\___/   |_|
Welcome to Armbian buster with Linux 5.4.22-bpi-r64-main
No end-user support: built from trunk
System load:   0.39 0.17 0.06   Up time:       1 min
Memory usage:  5 % of 994MB     IP:
CPU temp:      42�°C
Usage of /:    4% of 15G
New to Armbian? Check the documentation first: https://docs.armbian.com
You are using an Armbian preview build !!!
This image is provided AS IS with NO WARRANTY and NO END USER SUPPORT!.
Login/password are standard for Armbian: root/1234
I attached logs:
journalctl -b > journalctl.txt
cp /var/log/armbian-hardware-monitor.log armbian-hardware-monitor.log
dmesg -t > dmesg.txt
armbian-hardware-monitor.log (28.9 KB) dmesg.txt (14.7 KB) journalctl.txt (58.6 KB)
What is missing ?
armbianmonitor -u tells the reader all the details about your Installation, like Kernel-Version and much more
Status:
Ideally, one should build u-boot in Armbian way and make use of /boot/armbianEnv.txt instead of /boot/bananapi/bpi-r64/linux/uEnv.txt .I am not so good at u-boot so it needs time to build it, i try later. But at the same time it is a feature: you can you Armbian and use kernels from @frank-w .
armbianmonitor -u : http://ix.io/2dcB
Also see:
https://github.com/frank-w/BPI-R2-4.14/issues/70
https://github.com/frank-w/BPI-R2-4.14/issues/71
Config options i can add when i’m at home…uboot you should use 2020-04-pwm because also ethernet driver is merged there
Edit: options added
Now with latest kernel update all armbian features works, including zram and wireguard.
Do you ise latest uboot (with switch driver and pwm/binman fix) from my repo?
Nope, I just use your old build u-boot-mtk_r64_sd_mt7531_gcc8.3.bin
I am short on time to do it.
Is it that important to use latest uboot?
This file is imho version 2014-04 from bpi-r64 branch.
As a first test you can use this branch (change build.conf to bpi-r64 first): https://github.com/frank-w/u-boot/tree/2020-04-bpi-pwm
I will rebase next days to remove reverted commits and to update uboot to rc3/rc4
And it will be similar for Bananapi-r2 ?
There is support for BPI R2 in Armbian, you may download image with kernel 4.19, https://www.armbian.com/bananapi-r2/
or build image with latest 5.4 kernel with command
./compile.sh BOARD="bananapir2" BRANCH="dev" RELEASE="buster" CARD_DEVICE="/dev/mmcblk0" \
KERNEL_ONLY="no" KERNEL_CONFIGURE="no" INSTALL_HEADERS="yes" BUILD_DESKTOP="no" BUILD_MINIMAL="yes"
Yes, but this kernel does not support hdmi and wifi
You can build image with latest 5.4 kernel with command
But still only mainline-kernel,right? So no hdmi and internal wifi…
No, that command “git clone”-s your repo, so there will be latest kernel I believe.
Ah ok, i was not aware that they include my repo…
It’s DEV & more or less entirely a community contribution. Currently broken in the packaging areas which we otherwise fix with one patch. Now … some rework is needed to get this working again.
But 4.19.y is functional again as/on the level it was before …
in 4.19 at least vlan is not working…have patched 5.4 to get this, but it’s not compatible with 4.19 (can be applied but does not work)
i have currently 5.4 running on my main-router and except a WARN_ONCE for mt7612e wifi-card and some hostapd-messages (need self-compiled hostapd on stretch) i have no problems
