BPI-R2 New image : Openwrt/LEDE 2017-09-08
Hi Peter
The HDMI doesn’t work if you’re using LEDE image.
Thanks Gary
HDMI is not working. You can see and use terminal when you’re using the debugging uart port/pins.
Thank you. I guess I should buy a UART-adapter. Did you solve the issue with package source?
you can access bpi-r2 via ssh on 192.168.1.1 over LAN-Ports, maybe http(s)-interface is accessable via this ip too
Yes. I thought about it. But this will happen only if everything will work without unexpected problems. And even if it will work by default I will certainly break network doing experiments with interface confuration and firewall :slight_smile: Anyway, thank you
for this case you’ll need http://wiki.fw-web.de/doku.php?id=en/bpi-r2/debug-uart till hdmi is working (not working in 4.14 yet)
no, I didn’t. But I didn’t try it again… I dont know how to fix it. In other version (self compiled images for example) it works…
It works with R2 and LEDE? Which images?
Hdmi works only with kernel 4.4 (default in ubuntu-images),lede uses 4.9
sorry, I mean the luci package works; not HDMI.
Hi, i have problem with opkg. I am not able to doeload any packages (luci, etc…) console says: “[package] has no valid architecture, ignoring” Is there some advice for me how to download and install packages?
I also met the same problem,It seems like architecture doesn’t suit。
here are some discussions:https://forum.openwrt.org/viewtopic.php?id=57733
we need to find the right arch,and then modify /etc/opkg.conf to suit it, but I am still trying ……
Why not complie packages yourself?
sorry,I’m newer for openwrt, I also find someone said we could build our owe package, but he didn’t show the steps,I’ll serach for this ,thank you.
We can select a package that we want by running command “make menuconfig”, if it’s configured as ‘M’, we can see the package in bin/targets/mediatek/32/packages/ after building lede project.
nice, thank you gary.
Is link http://pan.baidu.com/s/1eS1pRCA working? It’s not working for me
Also https://drive.google.com/open?id=1oP7jy1KrrIOifvImo2nQ59wx3_9hHkgk there is no image for LEDE.
the image on my gdrive is named mtk-bpi-r2-SD.img (or EMMC)…this name come from lede build-script…
Ok. I will try it. Thank you very much.
EDIT: Working :slight_smile:
Hello.
Do somebody have proble when compiling luci? I have missing dependencies:
  • satisfy_dependencies_for: Cannot satisfy the following dependencies for luci:
  • libuci-lua (>= 2018-01-01)
  • opkg_install_cmd: Cannot install package luci.
My feeds.conf.default:
src-git packages https://git.lede-project.org/feed/packages.git
src-git luci https://git.lede-project.org/project/luci.git
src-git routing https://git.lede-project.org/feed/routing.git
src-git telephony https://git.lede-project.org/feed/telephony.git
I found same problem here https://forum.lede-project.org/t/solved-issues-compiling/10755, but looks like i’m using correct repository.
Can somedoby help me wich this?
Regards.
