BPI-R2 new image: BPI-R2 OpenWrt(LEDE) Souce code : 2018-05-09
Yes
ap0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 02:08:22:14:22:47 brd ff:ff:ff:ff:ff:ff
Thank you. I will check it out.
Then it seems to be hostapd which does not support the (standard) driver nl80211
Can something else be used to start wifi?
imho not, but maybe you can replace your hostapd with hostapd-binaries from ubuntu/debian
https://packages.debian.org/us/jessie/armhf/hostapd/filelist
here you see depencies which you maybe need also (for armhf): https://packages.debian.org/us/jessie/hostapd
after you make menuconfig to choose nl80211, you will build the driver to image when you are compiling.
openwrt will download code, when compile.
At this point i had continuously errors, guess server was not available for download. @nomadbeni i cannot testing until the TP-Link that i ordered arrived, cause bpi is now with alpinelinux my AP. @Jackzeng could you upload the sysupgrage somewhere else ? From Baidu i have always interrupts, its not possible to download from Europe… Thanks…
Hello , here is the google drive: https://drive.google.com/open?id=1UPDwVauZ59K5A83ydHH9x4gbeiq-nffi
Thank you. I installed this, and managed to start wifi. I also installed LuCI and a new Wireless menu appeared. In it there are couple of radios and default wifi networks. I can search other wifi networks, but the access points that I enable from LuCI are not working. It says: Wireless is disabled or not associated
If I start the wifi using SSH it works, and when I close the SSH connection wifi still works. Also every time I start the wireles from SSH a new radio shows up in LuCI.
Hi Jack. I create wifi with your command. And it work.
But for some reason i don’t know. All devices disconnect a few minute later.
And hostapd print this:
ap0: STA (private MAC address) WPA: sending 1/4 msg of 4-Way Handshake
ap0: STA (private MAC address) WPA: EAPOL-Key timeout
ap0: STA (private MAC address) WPA: PTKSTART: Retry limit 4 reached
ap0: STA (private MAC address) WPA: event 3 notification
ap0: STA (private MAC address) IEEE 802.1X: unauthorizing port
ap0: STA (private MAC address) MLME: MLME-DEAUTHENTICATE.indication((private MAC address), 2)
ap0: STA (private MAC address) MLME: MLME-DELETEKEYS.request((private MAC address))
ap0: STA (private MAC address) IEEE 802.11: disassociated
ap0: STA (private MAC address) WPA: event 2 notification
What’s the problem? Could you help me?
Hello, I still don’t find the solution for this problem,but I find we can limit the speed to avoid this problem, here is my test command:
Thx Jack.
BTW. On my devices, stateless Ipv6 doesn’t work. Do you have same problem?
Hello, Could you tell me how do you config stateless ipv6?
I use ipv6 ping other device , it works fine
emm…
Our stateless ipv6 is config by an Ruijie S12010 switch.
Here is the config
ipv6 address (private Ipv6 address)::1/64
ipv6 enable
no ipv6 nd suppress-ra
So… I don’t know how it work. But other except R2.
I catch some packages and upload them in this topic
maybe it can help you
@Jackzeng I use your image, but I can’t start wifi:
root@LEDE:/mnt# cat hostapd.conf
interface=ap0
bridge=br-lan
ssid=hw3
driver=nl80211
country_code=CN
hw_mode=g
channel=1
max_num_sta=5
wpa=2
auth_algs=1
rsn_pairwise=CCMP
wpa_key_mgmt=WPA-PSK
wpa_passphrase=xxyyzz
logger_stdout=-1
logger_stdout_level=2
root@LEDE:/mnt# ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr 00:08:22:00:04:FC
          BROADCAST MULTICAST  MTU:1500  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
root@LEDE:/mnt# hostapd -d hostapd.conf
Configuration file: hostapd.conf
'ine 4: invalid/unknown driver 'nl80211
'ine 6: unknown hw_mode 'g
'.ne 11: invalid cipher 'CCMP
'ine 12: invalid key_mgmt 'WPA-PSK
4 errors found in configuration file 'hostapd.conf'
Failed to set up interface with hostapd.conf
Failed to initialize interface
root@LEDE:/mnt# ifconfig ap0
ap0       Link encap:Ethernet  HWaddr 02:08:22:00:04:FC
root@LEDE:/mnt#
Hello, Did you try here?
I am using your sysupgrade image, and above problem is in your sysupgrade image.
looks strange…have your checked your filesystem?
Btw. @jackzeng is hnat working over br-lan?
how to check filesystem, there is no fsck command.
Hello,frank, I think hnat is probably not over br-lan.
