BPI-R2 new image: BPI-R2 OpenWrt(LEDE) Souce code : 2018-05-09
Then it also cannot work in lede where lanpprts are bridged. There is a br-section in prerouting. Here no tag is appended (wifi gets invalid) but in postrouting there are checks only for lan/wan
Can we make it work also with bridges and wifi?
@silverfox i do not know lede much,but there must be a tool for checking filesystem https://openwrt.org/docs/guide-user/storage/filesystems-and-partitions but i heard that package-install does not work correctly on some lede-images
yes, this is what I want to do, I will find time to support HNAT and Switch function on R2.
by the way, have you ever met this problem before?
Not till now,but i have only connected usb2-devices directly…i have no usb3-hub…
But you can try different kernel-versions and look if the problem happens on all. You’ll find kernel-versions 4.14,4.16,4.17 and 4.18 on my repo working so far on r2
My modified uboot allows booting different kernels (different filename)
Hello,frank,I tried kernel 4.14,it also has the same problem, usb3.0 is limited.
I think the next step is to check the code.
Can you try also 4.17(-main)/4.18(-rc) maybe its fixed in newer kernel
We found out the usb port of soc only support 32 endpoints, so is limited. I want to figure out how to change the endpoint.
usb-port of soc? i thought usb3 was connected via pcie
btw. do you use a powered usb-hub? is the problem also occour if no devices are connected to hub? maybe it’s a powering issue
I have put first image from this post than tried to sysupgrade to your
(tried by webgui but I cannot get 192.168.1.1 by browser)
lede-mediatek-32-bananapi,bpi-r2-sysupgrade.tar
file and after reboot I have: can’t get kernel image!
enclosed log from upgrade
finally I would like to use that image:
https://downloads.openwrt.org/releases/18.06.0/targets/mediatek/mt7623/
but I don’t know how to install it to SD
log.txt (29,4 KB)
Hello,frank,I checked,I use 4 4G modules and they have their own power supply.
I changed code to decrease some useless EPs(endpoint), so I can support 4 4G modules now.
Hello, I saw your log, your boot could not load kernel because doesn’t support kernel format .
Images Link:
Google Drive: https://drive.google.com/open?id=1D6qPs73AXINarqFKFXuIMOr3-D6RmZAQ
Baidu Drive: https://pan.baidu.com/s/19Yu11pDFPa9UGdIdrQu3-A
This is my .config, you could use it built openwrt code.
CONFIG_ (152.5 KB)
Thank you very much. Your image is working fine. Only the problem is when I want to install by opkg package ath10k for my pcie wlan card it needs kernel 4.14.xx. Can I just replace kernel 4.14.62 made by Frank-W? Or will you point me some other way to install ath10k drivers …
(great that other packages from official repo works)
if you could not use opkg, you could build these packages in your project by yourself, then install them to your image.
Hostapd is now running successfully, but this ssid is not found on both the phone and the computer. I don’t know why.
The terminal will output every ten minutes: ap0: WPA rekeying GTK
root@LEDE:~# cat /etc/hostapd/hostapd.conf
interface=ap0
bridge=br-lan
ssid=hw3
driver=nl80211
country_code=CN
hw_mode=g
channel=1
max_num_sta=9
wpa=2
auth_algs=1
rsn_pairwise=CCMP
wpa_key_mgmt=WPA-PSK
wpa_passphrase=xxyyzz
logger_stdout=-1
logger_stdout_level=2
root@LEDE:~# hostapd -d /etc/hostapd/hostapd.conf &
root@LEDE:~# Configuration file: /etc/hostapd/hostapd.conf
ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Using interface ap0 with hwaddr 02:08:22:04:56:13 and ssid "hw3"
ap0: interface state COUNTRY_UPDATE->ENABLED
ap0: AP-ENABLED
root@LEDE:~# dmesg|tail -n 3
[1087910.108733] device ap0 entered promiscuous mode
[1087910.113542] br-lan: port 5(ap0) entered blocking state
[1087910.118813] br-lan: port 5(ap0) entered forwarding state
root@LEDE:~#
Please drop bridge setting and try again
It’s okay after rebooting the system.
Why limit such a small bandwidth? The speed seems too slow.
It has nothing to do with bandwidth…wifi-chip seems to have problems with bridging
yes, because the ap mode is not stable,so I limit the speed to avoid the problem.
Where can I download the available tc packages? Opkg installation prompt kernel version does not match.
root@LEDE:~# opkg install tc
Installing tc (4.17.0-4) to root...
Downloading http://openwrt.proxy.ustclug.org/snapshots/packages/arm_cortex-a7_neon-vfpv4/base/tc_4.17.0-4_arm_cortex-a7_neon-vfpv4.ipk
Collected errors:
 * satisfy_dependencies_for: Cannot satisfy the following dependencies for tc:
 * 	kernel (= 4.14.42-1-71fb0e651a6aa044cd9eb86c91f17d9c) *
 * opkg_install_cmd: Cannot install package tc.
root@LEDE:~#
Can you please point me some instructions?
